对根叔知了社区有害的内容 >
对根叔知了社区有害的内容
无线(WLAN)跨互联网场景本地转发
2021-08-12发布
场景:(总部AC+分公司AP场景+本地转发+Portal认证)
存在影响:(无线Portal逃生影响,分公司审计影响)
组网拓扑:
基本原理:
AC给AP下发MAP文件中对于AP的上行口开启NAT,并下发集中转发策略,NAT的作用给用户访问分部资源与互联网资源,集中转发策略给无线用户访问总部资源时匹配集中转发策略实现双网关转发场景。
AC配置:
(创建总部资源)
acl advanced 3001
rule 1 permit udp source-port eq bootpc
rule 2 permit udp destination-port eq bootps
rule 5 permit udp source-port eq dns
rule 6 permit udp destination-port eq dns
rule 100 permit ip destination 10.0.0.0 0.255.255.255
rule 101 permit ip destination 192.168.0.0 0.0.255.255
wlan forwarding-policy test
client behavior-local network-flow-forwarding enable //开启本地转发模式下的外网流量转发功能
classifier acl 3001 behavior remote //调用总部资源匹配集中转发策略
radius scheme portal
primary authentication 192.168.x.x
primary accounting 192.168.x.x
key authentication cipher $c$3$Nm3UeBXZs/yUB64YL4pXGehCRz6O/Q==
key accounting cipher $c$3$L3nrrIMzn5kZO4t7ma7oOdrPPdeG3w==
user-name-format without-domain
nas-ip 192.168.x.x
domain portal
authentication portal radius-scheme portal
authorization portal radius-scheme portal
accounting portal radius-scheme portal
portal server portal ip 192.168.x.x key cipher $c$3$FAiPyGAFJntgua/903+KwgTSfuhcrw==
server-detect timeout 30 log trap
portal web-server portal
url http://192.168.x.x:8080/portal
server-detect retry 2 log trap
url-parameter apmac ap-mac
url-parameter ssid ssid
url-parameter userip source-address
url-parameter usermac source-mac
url-parameter userurl original-url
portal mac-trigger-server mst
ip 192.168.0.250
portal host-check enable
portal free-rule 5 destination ip 192.168.x.x 255.255.255.255 //IMC资源
portal free-rule 10 destination ip 192.168.x.x 255.255.255.255 //总部DNS注意如果总部没有DNS则填写分公司或互联网DNS
wlan service-template 10
ssid h3c
client forwarding-location ap //修改转发模式为本地转发模式
client forwarding-policy-name test //调用无线转发策略
client forwarding-policy enable //开启无线转发策略
portal enable method direct
portal domain portal
portal bas-ip 192.168.x.x
portal apply web-server portal
portal apply mac-trigger-server mst
portal fail-permit web-server
service-template enable
(完)
存在影响解释:
无线Portal逃生影响:Portal逃生是Portal接入设备定时探测Portal服务器是否可达判断Portal逃生是否触发,由于本地转发跨公网情况下无线用户的Portal认证需要绑定在AC的服务模板中下发给AP,所以这里的Portal接入设备是无线AP,跨互联网情况下AP无法对Portal服务器的8080端口进行探测。该环境是替换无线使用IPsec vpn/SSL VPN场景无线AP注册的替换方案,所以除非将AC的8080端口映射到互联网,否则AP无法探测到Portal服务器的8080端口则Portal逃生实时触发。
分公司审计影响:双网关的原理是将用户通过AP的NAT进行本地转发且无线用户地址不会与其它区域的无线用户地址冲突,但是因为该原因,本地存在审计设备时,审计到用户行为异常所存在的源IP则是AP的IP地址,因为AP进行过NAT转换,所有用户的源都会变成AP的出口IP地址
0个回复
该话题暂时没有网友回复过
回复
