防火墙外网网口ping不通对面电脑
2020-10-07提问
  • 1收藏,531浏览
我做了许多配置,现在电脑接核心交换机接防火墙,可以ping到防火墙的外网网口,防火墙的外网网口接了一台电脑模拟外网,可是防火墙的外网网口ping不通这台电脑,我要怎么做?这台外网接的电脑已经关闭防火墙下面我会发配置。
<H3C>dis cu # version 7.1.064, Release 9510P12 # sysname H3C # context Admin id 1 # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1 # nat address-group 1 name zczwu address 172.27.107.252 172.27.107.252 # password-recovery enable # vlan 1 # object-group ip address any2 description 服务器 0 network range 192.168.1.1 192.168.1.254 # object-group ip address sourceIP description 源IP地址组 0 network range 172.10.192.1 172.10.199.254 # object-group ip address 内网 0 network subnet 10.147.198.0 255.255.255.252 # interface NULL0 # interface GigabitEthernet1/0/0 port link-mode route description GigabitEthernet1/0/0 Interface-IN combo enable copper ip address 10.147.198.2 255.255.255.252 undo dhcp select server # interface GigabitEthernet1/0/1 port link-mode route description GigabitEthernet1/0/1 Interface-OUT combo enable copper ip address 172.27.107.253 255.255.255.0 nat outbound undo dhcp select server # interface GigabitEthernet1/0/2 port link-mode route ip address 192.168.0.1 255.255.255.0 undo dhcp select server # interface GigabitEthernet1/0/3 port link-mode route description GigabitEthernet1/0/3 Interface-AP ip address 172.16.2.1 255.255.255.0 # interface GigabitEthernet1/0/4 port link-mode route undo dhcp select server # interface GigabitEthernet1/0/5 port link-mode route undo dhcp select server # interface GigabitEthernet1/0/6 port link-mode route undo dhcp select server # interface GigabitEthernet1/0/7 port link-mode route undo dhcp select server # interface GigabitEthernet1/0/8 port link-mode route undo dhcp select server # interface GigabitEthernet1/0/9 port link-mode route undo dhcp select server # interface GigabitEthernet1/0/10 port link-mode route description 服务器 ip address 192.168.1.1 255.255.255.0 undo dhcp select server # interface GigabitEthernet1/0/11 port link-mode route description GigabitEthernet1/0/11 Interface-ADSL ip address 58.62.159.230 255.255.255.248 undo dhcp select server # object-policy ip Local-Trust rule 0 pass rule 0 comment 互通1 # object-policy ip Trust-Local rule 0 pass rule 0 comment 互通 # object-policy ip Trust-Untrust rule 0 pass source-ip 内网 logging # security-zone name Local # security-zone name Trust import interface GigabitEthernet1/0/0 # security-zone name DMZ import interface GigabitEthernet1/0/10 attack-defense apply policy 1 # security-zone name Untrust import interface GigabitEthernet1/0/1 # security-zone name Management import interface GigabitEthernet1/0/2 # security-zone name ADSL import interface GigabitEthernet1/0/11 # security-zone name AP import interface GigabitEthernet1/0/3 # zone-pair security source Local destination Trust object-policy apply ip Local-Trust # zone-pair security source Trust destination Local object-policy apply ip Trust-Local # zone-pair security source Trust destination Untrust object-policy apply ip Trust-Untrust # scheduler logfile size 16 # line class aux user-role network-operator # line class console authentication-mode scheme user-role network-admin # line class vty user-role network-operator # line aux 0 user-role network-admin # line con 0 user-role network-admin # line vty 0 63 authentication-mode scheme user-role network-admin # ip route-static 172.10.192.0 24 10.147.198.1 ip route-static 172.27.107.0 24 172.27.107.254 # ssh server enable # acl basic 2003 rule 0 permit # domain system # aaa session-limit ftp 16 aaa session-limit telnet 16 aaa session-limit ssh 16 domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ== service-type ssh terminal https authorization-attribute user-role level-3 authorization-attribute user-role network-admin authorization-attribute user-role network-operator # ip https enable # attack-defense policy 1 scan detect level medium action drop logging syn-flood action logging ack-flood action logging syn-ack-flood action logging rst-flood action logging fin-flood action logging udp-flood action logging icmp-flood action logging icmpv6-flood action logging dns-flood action logging http-flood action logging syn-flood detect ip 192.168.1.13 syn-flood detect ip 192.168.1.118 # return
粉丝:12人 关注:0人
local到untrust加一下策略
加了之后防火墙能够ping通254了,但是接在核心交换机下面的电脑ping不通254,这台电脑可以通到防火墙的外网网口253,是通过防火墙nat到的。
zhiliao_ucrt4 发表时间:2020-10-07
怎么办
外网电脑网关指向253
zhiliao_pdGY6 发表时间:2020-10-07
<H3C>dis cu
sysname H3C
context Admin id 1
undo irf link-delay
vlan 1
description 服务器
description 源IP地址组
interface NULL0
combo enable copper
combo enable copper
nat outbound
description 服务器
rule 0 pass
rule 0 comment 互通1
rule 0 pass
rule 0 comment 互通
line class aux
line class console
line class vty
line aux 0
line con 0
line vty 0 63
ssh server enable
acl basic 2003
rule 0 permit
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
ip https enable
return
