F100-C60-WiNet 和msr3660配置ipsec vpn,始终不通。
2020-10-14提问
  • 1收藏,809浏览
F100-C60-WiNet和h3c msr3660配置ipsec vpn。
检测:display ike sa  状态rd,
检测:   display ipsec sa brief,
但是ping的时候:还是不通
ping -a 10.161.2.65 192.168.28.252测试的时候,acl 前后反应
出口网络nat outbound 3000引用acl 3000,ipsec vpn引用 acl 3261
附件是F100-C60-WiNet的配置
另外一端H3C msr3660  ipsec vpn接了多个地方的ipsec vpn都没问题。
acl advanced 3001
rule 137 deny ip source 192.168.200.0 0.0.0.255 destination 10.161.2.64 0.0.0.63
rule 138 deny ip source 192.168.28.0 0.0.0.255 destination 10.161.2.64 0.0.0.63
rule 139 deny ip source 192.168.28.0 0.0.0.255 destination 10.61.2.0 0.0.0.255
rule 140 deny ip source 192.168.200.0 0.0.0.255 destination 10.61.2.0 0.0.0.255
acl advanced 3261
rule 0 permit ip source 192.168.28.0 0.0.0.255 destination 10.161.2.64 0.0.0.63
rule 5 permit ip source 192.168.200.0 0.0.0.255 destination 10.161.2.64 0.0.0.63
rule 10 permit ip source 192.168.200.0 0.0.0.255 destination 10.61.2.0 0.0.0.255
rule 15 permit ip source 192.168.28.0 0.0.0.255 destination 10.61.2.0 0.0.0.255
ipsec policy 1048576 3261 isakmp
transform-set yijunzcy01_ike_t
security acl 3261
remote-address 113.113.113.113
ike-profile yijunzcy01_ike_p
ipsec transform-set yijunzcy01_ike_t
esp encryption-algorithm 3des-cbc
esp authentication-algorithm md5
ike profile yijunzcy01_ike_p
keychain yijunzcy01_ike_k
local-identity address 117.172.29.11
match remote identity address 113.113.113.113 255.255.255.252
proposal 3261
ike proposal 3261
ike keychain yijunzcy01_ike_k
pre-shared-key address 113.113.113.113 255.255.255.252 key cipher $c$3$9pmU65syKrqqXZL95vj/modGRPgEDvXl4G/EAN0=
ping前后对比
有对端配置嘛
千年菜鸟 知了小白
F100-c60-winnet配置如下,目前还是没找到原因。。
dis cu
version 7.1.064, Release 9524P31
sysname
clock timezone beijing add 08:00:00
context Admin id 1
ip vpn-instance management
route-distinguisher 1000000000:1
vpn-target 1000000000:1 import-extcommunity
vpn-target 1000000000:1 export-extcommunity
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
password-recovery enable
vlan 1
vlan 33
vlan 77
vlan 333
object-group ip address fuwuqi-ip
0 network subnet 10.161.2.96 255.255.255.224
object-group ip address jiankong-ip
0 network subnet 10.61.2.0 255.255.255.0
object-group ip address qianduankongzhi-ip
0 network subnet 10.161.2.64 255.255.255.224
object-group ip address wifi-ip
0 network subnet 10.161.2.192 255.255.255.224
object-group ip address yjzcy-ip
0 network subnet 10.161.2.0 255.255.255.248
controller Cellular1/0/0
interface Bridge-Aggregation1
port link-type trunk
port trunk permit vlan all
interface NULL0
interface Vlan-interface33
ip address 10.161.2.65 255.255.255.224
interface Vlan-interface77
ip address 10.161.2.1 255.255.255.248
nat outbound 3100
nat server protocol tcp global 113.113.113.113 9001 inside 10.161.2.5 9001 rule ServerRule_1
nat server protocol tcp global 113.113.113.113 9002 inside 10.161.2.5 9002 rule ServerRule_2
nat server protocol tcp global 113.113.113.113 9003 inside 10.161.2.5 9003 rule ServerRule_3
interface Vlan-interface333
ip address 10.244.1.65 255.255.255.192
interface GigabitEthernet1/0/0
port link-mode route
ip address 113.113.113.113 255.255.255.252
dns server 61.134.1.4
dns server 114.114.114.114
tcp mss 1304
nat outbound 3000
nat server protocol tcp global current-interface 554 inside 10.61.2.11 554 rule ServerRule_4
nat server protocol tcp global current-interface 9001 inside 10.161.2.5 9001 rule ServerRule_5
nat server protocol tcp global current-interface 9002 inside 10.161.2.5 9002 rule ServerRule_6
nat server protocol tcp global current-interface 9003 inside 10.161.2.5 9003 rule ServerRule_7
nat server protocol tcp global current-interface 50022 inside 10.161.2.98 22 rule ServerRule_8
nat server protocol tcp global current-interface 63389 inside 10.161.2.5 3389 rule ServerRule_9
ipsec apply policy to-center
ip binding vpn-instance management
port link-mode bridge
port access vlan 77
interface GigabitEthernet1/0/4
port access vlan 77
interface GigabitEthernet1/0/5
port access vlan 77
interface GigabitEthernet1/0/6
port link-aggregation group 1
interface GigabitEthernet1/0/7
security-zone name Local
security-zone name Trust
import interface Vlan-interface33
import interface Vlan-interface77
import interface Bridge-Aggregation1 vlan 1 to 4094
import interface GigabitEthernet1/0/3 vlan 77
import interface GigabitEthernet1/0/4 vlan 77
import interface GigabitEthernet1/0/5 vlan 77
security-zone name DMZ
security-zone name Untrust
import interface GigabitEthernet1/0/0
security-zone name Management
import interface GigabitEthernet1/0/2
zone-pair security source Local destination Trust
packet-filter 3334
zone-pair security source Local destination Untrust
packet-filter 3334
zone-pair security source Trust destination Local
packet-filter 3334
zone-pair security source Trust destination Trust
packet-filter 3334
zone-pair security source Trust destination Untrust
packet-filter 3334
zone-pair security source Untrust destination Local
packet-filter 3334
zone-pair security source Untrust destination Trust
packet-filter 3334
scheduler logfile size 16
line class aux
user-role network-operator
line class console
user-role network-admin
line class usb
line class vty
line aux 0
authentication-mode scheme
line con 0
line vty 0 63
ip route-static 0.0.0.0 0 GigabitEthernet1/0/0 113.113.113.112
ip route-static 10.61.2.0 24 Vlan-interface33 10.161.2.66
ip route-static 10.161.2.96 27 Vlan-interface33 10.161.2.66
ip route-static 10.161.2.192 27 Vlan-interface33 10.161.2.66
ip route-static 192.168.28.0 24 GigabitEthernet1/0/0 113.113.113.112
ip route-static 192.168.200.0 24 GigabitEthernet1/0/0 113.113.113.112
snmp-agent
snmp-agent local-engineid 800063A280703D15DD853C00000001
snmp-agent community read public
snmp-agent sys-info version all
ssh server enable
ssh server acl 3333
ssh server port 56181
acl advanced 3000
rule 0 permit ip source 10.161.2.64 0.0.0.63 destination 192.168.28.0 0.0.0.255
rule 5 deny ip source 10.161.2.64 0.0.0.63 destination 192.168.200.0 0.0.0.255
rule 10 deny ip source 10.244.1.64 0.0.0.63 destination 192.168.28.0 0.0.0.255
rule 51 permit ip source 10.161.2.192 0.0.0.31
rule 52 permit ip source 10.161.2.0 0.0.0.7
rule 53 permit ip source 10.161.2.64 0.0.0.31
rule 54 permit ip source 10.161.2.96 0.0.0.31
acl advanced 3100
rule 0 permit ip source 10.161.2.0 0.0.0.7
rule 5 permit ip source 10.161.2.64 0.0.0.63
rule 10 permit ip source 10.61.2.0 0.0.0.255
acl advanced 3261
rule 5 permit ip source 10.161.2.64 0.0.0.63 destination 192.168.200.0 0.0.0.255
rule 10 permit ip source 10.61.2.0 0.0.0.255 destination 192.168.200.0 0.0.0.255
rule 15 permit ip source 10.61.2.0 0.0.0.255 destination 192.168.28.0 0.0.0.255
rule 20 permit ip source 10.244.1.64 0.0.0.63 destination 192.168.28.0 0.0.0.255
acl advanced 3333
rule 25 permit ip source 192.168.0.0 0.0.255.255
acl advanced 3334
rule 0 permit ip
domain system
aaa session-limit ftp 16
aaa session-limit telnet 16
aaa session-limit ssh 16
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user fire-admin class manage
password hash $h$6$IvhYwFcdzoxp5YUC$wPAdZWVxnoEAXgT55J7o/FOsA/PrDHR9lJFG5Fa3DDy1MUktABE8DK47SHod/5kO+HyiG5kOY4/SSSlA6eamQg==
service-type terminal
local-user fire-root class manage
password hash $h$6$EWDuvDugJNY1SPVm$xm1yVPxBDtwYpRK9DsY9CUkCOrRMfxVxNAGtVVXw1qHhV6NyCBPU76/0hzOc/oePpGnhQ7+6Uw7vQ/l9izNkRw==
service-type ssh https
local-user ftpuser class manage
password hash $h$6$7+OfojdbOLXM9Vo8$Bvg6StKqP5WLrOMG+0iQnFx5HgSDg0aLlfLRsWlFDmuMM7cWPx+O4wVm6SN277mK0TIDFGEFAI/f0cqjjr3fig==
service-type ftp
authorization-attribute work-directory flash:/
local-user yijun class manage
password hash $h$6$2ev7TrBCaTlIpsD+$PPFMwRF9OM3t1XpDaSRjECIvVHadu4iL3Ul+H8vtbwrWa4jWiPqjHS1312vSYi6krFgchPC6BEU9QK2tJ/DPOA==
service-type ssh terminal https
ftp server enable
ipsec transform-set yijunzcy_ike_t
ipsec policy to-center 1 isakmp
security acl 3261
local-address 113.113.113.113
remote-address 117.172.29.11
ike-profile yijunzcy02_ike_p
ike profile yijunzcy01ឩke_p
ike profile yijunzcy02_ike_p
keychain yijunzcy02_ike_k
local-identity address 113.113.113.113
match remote identity address 117.172.29.11 255.255.255.255
proposal 3261
ike proposal 3261
ike keychain yijunzcy02_ike_k
pre-shared-key address 117.172.29.11 255.255.255.255 key cipher $c$3$D3OkecL32/e2pcWhLSEptHHDDFONY9E7e8TrYm0=
ip https port 50443
ip https enable
webui log enable
security-policy ip
rule 0 name Local-Trust-0
action pass
logging enable
counting enable
source-zone Local
destination-zone Trust
rule 1 name Local-Untrust-1
action pass
counting enable
source-zone Local
destination-zone Untrust
rule 2 name Trust-Local-2
action pass
source-zone Trust
destination-zone Local
rule 3 name Trust-Trust-3
action pass
logging enable
counting enable
source-zone Trust
rule 4 name Trust-Untrust-4
action pass
counting enable
source-zone Trust
rule 5 name Untrust-Local-5
action pass
counting enable
source-zone Untrust
rule 6 name Untrust-Trust-6
action pass
counting enable
source-zone Untrust
