策略路由问题
2020-10-15提问
  • 1收藏,1151浏览
对齐方式
  • 靠左
  • 居中
  • 靠右
结构为er路由器,核心,现在vlan92上有一个92段的,核心现在两条外线,一条连锐捷连着教育网,另外一条连着er路由器连新的电信专线,客户说想要原本的教室网段改ip就可以用电信专线上网了,我就想到在核心上面的92段加个sub,192.168.8.1上去,之后做条策略路由,指向到路由器上面去嘛,然而现在核心交换机上面带源192.168.8.1ping192.168.10.1这个路由器ipping不通,路由器上面已经写了回包路由回来了,后来尝试在原本的教室电脑上面改ip,发现发现问题是,在终端,93段的ip可以ping通93.1,但是8.100却ping不通8.1。这个应该怎么排?我看了看核心上虽然有acl,但是没有应用,192.168.8.1是sub的,192.168.10.1是路由器的,192.168.10.2是核心交换机上与路由互联的。下面发一份core的配置文件,想问这是怎么回事?为什么会ping不通sub的ip。
粉丝:11人 关注:1人
8.100这个终端ip掩码配置没问题吧,你的配置没看出有问题
<dsfgsdgt>dis cu
version 5.20, Release 6708P10
sysname dsfgsdgt
domain default enable system
telnet server enable
lldp enable
ip http enable
switch-mode standard
switch-mode normal slot 2
switch-mode route-normal
password-recovery enable
acl number 2000
rule 0 permit source 10.21.93.0 0.0.0.255
rule 1 permit source 10.21.94.0 0.0.0.255
acl number 3100
rule 0 permit ip source 10.21.0.0 0.0.255.255 destination 10.21.0.0 0.0.255.255
rule 100 deny ip
acl number 3200
rule 0 permit ip source 192.168.8.0 0.0.0.255
vlan 1
vlan 2
vlan 20 to 21
vlan 32
description ϞПWIFI
vlan 93 to 95
vlan 1000
description ADSL-2
vlan 1115
vlan 2000
vlan 2088
description µ蘓°ᆆ
vlan 2093
description ׇ»ۿό
vlan 2100
description dianxin
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
dhcp server ip-pool v20
network 20.21.94.0 mask 255.255.255.0
gateway-list 20.21.94.254
dns-list 202.96.128.86
policy-based-route to_adsl_policy permit node 10
if-match acl 2000
apply ip-address next-hop 192.168.2.100
policy-based-route dianxin permit node 1
if-match acl 3200
apply ip-address next-hop 192.168.10.1
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$FtUnO5oZdWs+TieA57/oTuSqfuBf+uy4LYeR18E=
authorization-attribute level 3
service-type telnet terminal
service-type web
interface NULL0
interface Vlan-interface1
interface Vlan-interface2
ip address 192.168.2.1 255.255.255.0
interface Vlan-interface20
ip address 20.21.94.254 255.255.255.0
interface Vlan-interface32
interface Vlan-interface93
ip address 10.21.93.1 255.255.255.0
ip address 192.168.8.1 255.255.255.0 sub
ip policy-based-route dianxin
interface Vlan-interface94
ip address 10.21.94.1 255.255.255.0
interface Vlan-interface95
ip address 10.21.95.1 255.255.255.0
interface Vlan-interface1115
ip address 10.21.88.254 255.255.248.0
interface Vlan-interface2000
ip address 10.10.10.2 255.255.255.0
interface Vlan-interface2100
ip address 192.168.10.2 255.255.255.0
interface GigabitEthernet2/0/1
port link-mode bridge
description 3ºƂ¥502A
port link-type trunk
port trunk permit vlan all
interface GigabitEthernet2/0/2
description 3ºƂ¥502B
interface GigabitEthernet2/0/3
description 3ºƂ¥502C
interface GigabitEthernet2/0/4
description 3ºƂ¥502D
interface GigabitEthernet2/0/5
description 1ºƂ¥307A
interface GigabitEthernet2/0/6
description 1ºƂ¥307B
interface GigabitEthernet2/0/7
description 1ºƂ¥307C
interface GigabitEthernet2/0/8
description 1ºƂ¥307D
interface GigabitEthernet2/0/9
description 1ºƂ¥؟HA
interface GigabitEthernet2/0/10
description 1ºƂ¥؟HB
interface GigabitEthernet2/0/11
description 1ºƂ¥؟HC
interface GigabitEthernet2/0/12
description 3ºƂ¥304A
interface GigabitEthernet2/0/13
description 2ºƂ¥301
interface GigabitEthernet2/0/14
description 3ºƂ¥304B
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
shutdown
interface GigabitEthernet2/0/18
shutdown
interface GigabitEthernet2/0/19
shutdown
interface GigabitEthernet2/0/20
shutdown
interface GigabitEthernet2/0/21
shutdown
interface GigabitEthernet2/0/22
shutdown
interface GigabitEthernet2/0/23
shutdown
interface GigabitEthernet2/0/24
shutdown
interface GigabitEthernet2/0/25
port access vlan 2100
interface GigabitEthernet2/0/26
port access vlan 2000
arp detection trust
interface GigabitEthernet2/0/27
port access vlan 1115
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
port access vlan 20
interface GigabitEthernet2/0/31
port access vlan 95
interface GigabitEthernet2/0/32
port access vlan 95
interface M-Ethernet0/0/0
ip route-static 0.0.0.0 0.0.0.0 10.10.10.1
undo info-center logfile enable
snmp-agent
snmp-agent local-engineid 800063A20370BAEF7C1097
snmp-agent sys-info version v3
dhcp enable
load xml-configuration
load tr069-configuration
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
user-interface vty 5 15
zhiliao_BR2Be 知了小白
加一个 vlan8 试试看
