策略路由
2020-10-22提问
  • 1收藏,1415浏览
场景是这样,msr5060型号的路由器核心是7006E,然后路由器上做策略路由出去,但是策略应用上以后,打开网页非常慢,上午速度,策略路由取消就回复正常,但是客户的场景只能做策略路由,所有大神解答一下。  对了,核心上连路由做的聚合,本来是动态的现在啊我改成静态的了,下边有配置文件
场景是这样,msr5060型号的路由器核心是7006E,然后路由器上做策略路由出去,但是策略应用上以后,打开网页非常慢,上午速度,策略路由取消就回复正常,但是客户的场景只能做策略路由,所有大神解答一下。  本来是动态的现在啊我改成静态的了,下边有配置文件
[router]dis cu
version 7.1.064, Release 0707P16
sysname router
telnet server enable
qos carl 1 destination-ip-address subnet 192.168.160.0 23 per-address
qos carl 2 destination-ip-address subnet 192.168.170.0 23 per-address
qos carl 3 destination-ip-address subnet 192.168.160.0 23 per-address
qos carl 4 destination-ip-address range 192.168.21.1 to 192.168.24.254 per-address
qos carl 5 destination-ip-address range 192.168.61.1 to 192.168.64.254 per-address
qos carl 6 destination-ip-address range 192.168.101.1 to 192.168.104.254 per-address
dialer-group 1 rule ip permit
dialer-group 2 rule ip permit
dialer-group 3 rule ip permit
dialer-group 4 rule ip permit
undo nat alg dns
dhcp enable
dns proxy enable
dns server 202.96.134.133
dns server 114.114.114.114
password-recovery enable
vlan 1
policy-based-route aaa permit node 5
if-match acl 3995
apply default-next-hop 121.15.131.169
policy-based-route aaa permit node 10
if-match acl 3999
apply default-output-interface Dialer1
policy-based-route aaa permit node 15
if-match acl 3998
apply default-output-interface Dialer2
policy-based-route aaa permit node 20
if-match acl 3997
apply default-output-interface Dialer3
policy-based-route aaa permit node 25
if-match acl 3996
apply default-output-interface Dialer4
controller Cellular2/0/0
interface Route-Aggregation1
ip address 192.168.10.1 255.255.255.0
link-aggregation mode dynamic
ip policy-based-route aaa
interface Dialer1
mtu 1492
ppp chap password cipher $c$3$RDST1FoMV9OpOn7k7tVtv7QyLP85FUllOpzH
ppp chap user 07551200913543@163.gd
ppp ipcp dns admit-any
ppp ipcp dns request
ppp pap local-user 07551200913543@163.gd password cipher $c$3$mIQMPaDmEtglFGW1LgRXYWHTTmnpUwNMMhoj
dialer bundle enable
dialer-group 1
dialer timer idle 0
ip address ppp-negotiate
tcp mss 1024
nat outbound
interface Dialer2
mtu 1492
ppp chap password cipher $c$3$Uegz3AcKXy3a5/uHtKVD0thTm+Nt7M5p0iN/
ppp pap local-user 075506827101@163.gd password cipher $c$3$iJ4JSlVxeq0JB0GMdpQOjuTXGk2Lpz5J61CS
dialer-group 2
dialer timer idle 0
tcp mss 1024
nat outbound
interface Dialer3
mtu 1492
ppp pap local-user 07551200909992@163.gd password cipher $c$3$iJ+lRMvlKdLsMfipBUU5LkVY5qYHQk27VUWr
dialer-group 3
dialer timer idle 0
tcp mss 1024
nat outbound
interface Dialer4
mtu 1492
ppp pap local-user 07554201886857@163.gd password cipher $c$3$dVY6tJBfk28m69bUrQ6t4CHrDVZ6poKb67V1
dialer-group 4
dialer timer idle 0
tcp mss 1024
nat outbound
interface NULL0
interface GigabitEthernet2/0/0
port link-mode route
combo enable copper
ip address 121.15.131.171 255.255.255.248
ip last-hop hold
nat outbound
nat server protocol tcp global current-interface 88 inside 192.168.5.56 80
nat server protocol tcp global current-interface 3890 inside 192.168.5.56 389
nat server protocol tcp global current-interface 6360 inside 192.168.5.56 636
nat server protocol tcp global current-interface 8888 inside 192.168.5.56 8888
nat server protocol tcp global current-interface 53389 inside 192.168.5.56 3389
interface GigabitEthernet2/0/1
combo enable copper
mtu 1492
tcp mss 1024
ip last-hop hold
pppoe-client dial-bundle-number 2
interface GigabitEthernet2/0/2
combo enable copper
mtu 1492
tcp mss 1024
ip last-hop hold
pppoe-client dial-bundle-number 1
interface GigabitEthernet2/0/3
combo enable copper
mtu 1492
tcp mss 1024
ip last-hop hold
pppoe-client dial-bundle-number 3
interface GigabitEthernet2/0/4
combo enable copper
mtu 1492
tcp mss 1024
ip last-hop hold
pppoe-client dial-bundle-number 4
interface GigabitEthernet2/0/5
combo enable copper
interface GigabitEthernet2/0/6
combo enable copper
port link-aggregation group 1
interface GigabitEthernet2/0/7
combo enable copper
interface GigabitEthernet2/0/8
combo enable copper
interface GigabitEthernet2/0/9
combo enable copper
interface M-GigabitEthernet0
scheduler logfile size 16
line class console
user-role network-admin
line class tty
user-role network-operator
line class vty
line con 0
line vty 0 63
authentication-mode scheme
ip route-static 192.168.0.0 16 192.168.10.2
acl advanced 3000
rule 10 permit ip source 192.168.100.0 0.0.3.255
acl advanced 3995
rule 0 permit ip source 192.168.5.0 0.0.0.255
rule 5 permit ip source 192.168.23.60 0
rule 10 permit ip source 192.168.23.61 0
rule 15 permit ip source 192.168.23.62 0
rule 20 permit ip source 192.168.23.63 0
rule 25 permit ip source 192.168.23.64 0
rule 30 permit ip source 192.168.23.65 0
rule 35 permit ip source 192.168.23.66 0
rule 40 permit ip source 192.168.23.67 0
rule 45 permit ip source 192.168.23.68 0
rule 50 permit ip source 192.168.23.69 0
rule 55 permit ip source 192.168.23.70 0
rule 60 permit ip source 192.168.24.60 0
rule 65 permit ip source 192.168.24.61 0
rule 70 permit ip source 192.168.24.62 0
rule 75 permit ip source 192.168.24.63 0
rule 80 permit ip source 192.168.24.64 0
rule 85 permit ip source 192.168.24.65 0
rule 90 permit ip source 192.168.24.66 0
rule 95 permit ip source 192.168.24.67 0
rule 100 permit ip source 192.168.24.68 0
rule 105 permit ip source 192.168.24.69 0
rule 110 permit ip source 192.168.24.70 0
acl advanced 3996
rule 0 permit ip source 192.168.150.0 0.0.0.255
rule 5 permit ip source 192.168.170.0 0.0.0.255
acl advanced 3997
rule 0 permit ip source 192.168.101.0 0.0.0.255
rule 5 permit ip source 192.168.102.0 0.0.0.255
rule 10 permit ip source 192.168.103.0 0.0.0.255
rule 15 permit ip source 192.168.104.0 0.0.0.255
acl advanced 3998
rule 0 permit ip source 192.168.61.0 0.0.0.255
rule 5 permit ip source 192.168.62.0 0.0.0.255
rule 10 permit ip source 192.168.63.0 0.0.0.255
rule 15 permit ip source 192.168.64.0 0.0.0.255
rule 20 permit ip source 192.168.160.0 0.0.0.255
acl advanced 3999
rule 0 permit ip source 192.168.21.0 0.0.0.255
rule 5 permit ip source 192.168.22.0 0.0.0.255
rule 60 permit ip source 192.168.23.0 0.0.0.255
rule 120 permit ip source 192.168.24.0 0.0.0.255
rule 125 permit ip source 192.168.25.0 0.0.0.255
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$TIvYzbtAa9yTiGt7$OCG+9VsxF6nt2AJPSW6zpDfICMJXqeL/duNZpELJ49z8wAda5TsyrJqS1o939DBohiNfuO14rETBr8sLsw+oZQ==
service-type ssh telnet terminal http https
return
粉丝:95人 关注:1人
看下这个案例,重新做一下,没看到你PBR相关配置
 基于报文源地址的转发策略路由配置举例
通过策略路由控制从Router A的以太网接口GigabitEthernet2/0/1接收的报文:
·     源地址为192.168.10.2的报文以4.1.1.2/24作为下一跳IP地址;
·     其它源地址的报文以5.1.1.2/24作为下一跳IP地址。
图1-4 基于报文源地址的转发策略路由的配置举例组网图
(1)     配置Router A
配置接口GigabitEthernet2/0/2和GigabitEthernet2/0/3的IP地址。
[RouterA] interface gigabitethernet 2/0/2
[RouterA-GigabitEthernet2/0/2] ip address 4.1.1.1 24
[RouterA-GigabitEthernet2/0/2] quit
[RouterA] interface gigabitethernet 2/0/3
[RouterA-GigabitEthernet2/0/3] ip address 5.1.1.1 24
[RouterA-GigabitEthernet2/0/3] quit
定义访问控制列表ACL 2000,用来匹配源地址为192.168.10.2的报文。
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule 10 permit source 192.168.10.2 0
[RouterA-acl-ipv4-basic-2000] quit
定义0号节点,指定所有源地址为192.168.10.2的报文的下一跳为4.1.1.2。
[RouterA] policy-based-route aaa permit node 0
[RouterA-pbr-aaa-0] if-match acl 2000
[RouterA-pbr-aaa-0] apply next-hop 4.1.1.2
[RouterA-pbr-aaa-0] quit
[RouterA] policy-based-route aaa permit node 1
[RouterA-pbr-aaa-1] apply next-hop 5.1.1.2
[RouterA-pbr-aaa-1] quit
在以太网接口GigabitEthernet2/0/1上应用转发策略路由,处理此接口接收的报文。
[RouterA] interface gigabitethernet 2/0/1
[RouterA-GigabitEthernet2/0/1] ip address 192.168.10.1 24
[RouterA-GigabitEthernet2/0/1] ip policy-based-route aaa
[RouterA-GigabitEthernet2/0/1] quit
(2)     配置Router B
配置GigabitEthernet接口的IP地址。
<RouterB> system-view
[RouterB] interface gigabitethernet 2/0/2
[RouterB-GigabitEthernet2/0/2] ip address 4.1.1.2 24
[RouterB-GigabitEthernet2/0/2] quit
配置到网段192.168.10.0/24的静态路由。
[RouterB] ip route-static 192.168.10.0 24 4.1.1.1
(3)     配置Router C
<RouterC> system-view
[RouterC] interface gigabitethernet 2/0/3
[RouterC-GigabitEthernet2/0/3] ip address 5.1.1.2 24
[RouterC-GigabitEthernet2/0/3] quit
[RouterC] ip route-static 192.168.10.0 24 5.1.1.1
将Host A的IP地址配置为192.168.10.2/24,网关地址配置为192.168.10.1;将Host B的IP地址配置为192.168.10.3/24,网关地址配置为192.168.10.1。
从Host A上ping Router B,结果成功。
从Host B上ping Router B,结果失败。
从Host A上ping Router C,结果失败。
从Host B上ping Router C,结果成功。
以上结果可证明:从Router A的以太网接口GigabitEthernet2/0/1接收的源地址为192.168.10.2的报文的下一跳为4.1.1.2,所以Host A能ping通Router B,源地址为192.168.10.3的下一跳5.1.1.2,所以Host B能ping通Router C,由此表明策略路由设置成功。
