一定要先配置相同的IRF域ID吗,比如:irf domain 10
我的配置:
[sw1]irf member 1 renumber 1
[sw1]int Ten-GigabitEthernet 1/0/49
[sw1-Ten-GigabitEthernet1/0/49]shutdown
[sw1]irf-port 1/1
[sw1-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/49
[sw1]int Ten-GigabitEthernet1/0/49
[sw1-Ten-GigabitEthernet1/0/49]undo shutdown
[sw1]irf-port-configuration active
[sw2]irf member 1 renumber 2
[sw2]int Ten-GigabitEthernet 1/0/49
[sw2-Ten-GigabitEthernet1/0/49]shutdown
[sw2]irf-port 1/2
[sw2-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/49
[sw2]int Ten-GigabitEthernet1/0/49
[sw2-Ten-GigabitEthernet1/0/49]undo shutdown
[sw2]irf-port-configuration active
(0)
1、irf 的domain默认是相同的,所以不用配置,如果多组irf2,就是要配置domain
2、最多四台irf2组网
(0)
谢谢
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
谢谢
