MSR830
2020-11-30提问
  • 1收藏,743浏览
王XX 零段
MSR830软件版本:CMW520-R2516P13
用联通宽带的PPPOE拨号,D10接口能取得IPV6全球单播地址,但是局域网内的机子及手机都不能DHCP获得IPV6的地址。
用小米路由器拨号局域网内的机子就可以取得IPV6地址。
能帮忙提供一下H3C配置方法吗?是不是获取前缀的问题
路由器wan1接联通的宽带,PPPOE拨号上网。其他机子在LEN口就一个网段
想获取IPV6地址,是不是软件版本问题?
<H3C>dis cu
 version 5.20, Release 2516P13
 sysname H3C
 domain default enable system
 dns resolve
 dns proxy enable
 ipv6
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan1 extended
 network ip range 192.168.1.2 192.168.1.254
 network mask 255.255.255.0
 gateway-list 192.168.1.1
 dns-list 192.168.1.1
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$/0/eMRHFE3AeF06qCql3+Zs6Vibw19TQzM0x
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
ipv6 dhcp pool 1
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface Dialer10
 nat outbound
 nat server 1 protocol tcp global current-interface 81 inside 192.168.1.188 www
 nat server 2 protocol tcp global current-interface 3390 inside 192.168.1.188 3389
 nat server 3 protocol tcp global current-interface 5000 inside 192.168.1.100 5000
 ipv6 address auto
 ipv6 address auto link-local
 link-protocol ppp
 ppp chap user *010_63938072
 ppp chap password cipher $c$3$UlCpt3KQyw0yEhDzj+nzceNgeT5qHUytK7U=
 ppp pap local-user *010_63938072 password cipher $c$3$7H+RBJ62mY1AmIDtJ3MSKqWs5leguIHp/+E=
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1492
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
interface NULL0
interface Vlan-interface1
 ipv6 nd ra interval 60 10
 undo ipv6 nd ra halt
 ipv6 nd autoconfig other-flag
 ipv6 address auto
 ipv6 mtu 1280
 tcp mss 1024
 dhcp server apply ip-pool vlan1
 ipv6 dhcp server
 ip flow-ordering internal
interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 pppoe-client dial-bundle-number 10
 ipv6 address auto
 ip flow-ordering external
interface GigabitEthernet0/4
 tcp mss 1024
interface GigabitEthernet0/1
 port link-mode bridge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
 ip route-static 0.0.0.0 0.0.0.0 Dialer10
 dhcp enable
 arp static 192.168.1.100 0011-3295-1ef6
 dialer-rule 10 ip permit
 nms primary monitor-interface Dialer10
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface tty 13
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:22人 关注:1人
您好。
V5只支持无状态获取地址,但不能给内网分配地址实现上网。
V7设备可以用代理前缀实现。
有其他配置办法吗?只能换机子?
王XX 发表时间:2020-11-30
只能用V7设备。我的V5设备也没有办法实现。
江山青 发表时间:2020-11-30
