链路聚合
2020-12-09提问
  • 1收藏,1127浏览
粉丝:2人 关注:8人
这是我的拓扑图,ACG到防火墙是做的链路聚合,防火墙堆叠,核心-----ACG---防火墙这一段链路丢包,如果把备墙的聚合口shutdown,就不会丢包,请问这是什么原因
铁柱 九段
粉丝:21人 关注:1人
防火墙跨框了吧,需要开启会话同步:
session synchronization enable
session synchronization dns http
粉丝:29人 关注:0人
防火墙做出口建议配置成主备模式,若是双主模式存在一些限制。
若有要求必须双主模式,需要开启会话同步,NAT接口必须是逻辑接口。
粉丝:127人 关注:1人
冗余组配置了吗
参考配置:
H3C防火墙冗余备份组配置实验
基于H3C M9000配置的冗余备份
# failover group failover1 //创建备份组1 bind chassis 1 slot 6 cpu 1 primary //绑定1框6槽位CPU为主 bind chassis 2 slot 6 cpu 1 secondary //绑定2框6槽位CPU为备 # failover group failover2 //创建备份组2 bind chassis 1 slot 7 cpu 1 primary //绑定1框7槽位CPU为主 bind chassis 2 slot 7 cpu 1 secondary //绑定2框7槽位CPU为备 # session synchronization enable //启动会话热备 track 1 interface Blade1/6/0/1 physical //监控1框引擎口 # track 2 interface Blade1/6/0/3 physical # track 3 interface Blade1/7/0/1 physical # track 4 interface Blade1/7/0/3 physical # track 5 interface Ten-GigabitEthernet1/2/1/6 physical //监控1框业务口 # track 6 interface Ten-GigabitEthernet1/2/1/7 physical # track 7 interface Ten-GigabitEthernet1/3/1/6 physical # track 8 interface Ten-GigabitEthernet1/3/1/7 physical # track 11 interface Blade2/6/0/1 physical //监控2框引擎口 # track 12 interface Blade2/6/0/3 physical # track 13 interface Blade2/7/0/1 physical # track 14 interface Blade2/7/0/3 physical # track 15 interface Ten-GigabitEthernet2/2/1/6 physical //监控1框业务口 # track 16 interface Ten-GigabitEthernet2/2/1/7 physical # track 17 interface Ten-GigabitEthernet2/3/1/6 physical # track 18 interface Ten-GigabitEthernet2/3/1/7 physical interface Reth1 //创建上行以太网冗余口 member interface Ten-GigabitEthernet1/2/1/6 member interface Ten-GigabitEthernet1/3/1/6 member interface Ten-GigabitEthernet2/2/1/6 member interface Ten-GigabitEthernet2/3/1/6 interface Reth2 //创建下行以太网冗余口 member interface Ten-GigabitEthernet1/2/1/7 member interface Ten-GigabitEthernet1/3/1/7 member interface Ten-GigabitEthernet2/2/1/7 member interface Ten-GigabitEthernet1/3/1/7 redundancy group RG //创建冗余组 member interface Reth1 member interface Reth2 member failover group failover1 member failover group failover2 node 1 bind chassis 1 priority 255 track 1 interface Blade1/6/0/1 track 2 interface Blade1/6/0/3 track 3 interface Blade1/7/0/1 track 4 interface Blade1/7/0/3 track 5 interface Ten-GigabitEthernet1/2/1/6 track 6 interface Ten-GigabitEthernet1/2/1/7 track 7 interface Ten-GigabitEthernet1/3/1/6 track 8 interface Ten-GigabitEthernet1/3/1/7 node 2 bind chassis 2 priority 254 track 11 interface Blade2/6/0/1 track 12 interface Blade2/6/0/3 track 13 interface Blade2/7/0/1 track 14 interface Blade2/7/0/3 track 15 interface Ten-GigabitEthernet2/2/1/6 track 16 interface Ten-GigabitEthernet2/2/1/7 track 17 interface Ten-GigabitEthernet2/3/1/6 track 18 interface Ten-GigabitEthernet2/3/1/7
