对齐方式
防火墙现在配置不能访问外网
设备情况:防火墙(拨号上网加DHCP)---交换机---PC
情况配置如下: 哪位大师给看看问题在哪儿
version 5.20, Release 5142P08
sysname H3C
undo voice vlan mac-address 00e0-bb00-0000
interzone policy default by-priority
nat address-group 1 192.168.100.2 192.168.100.254
nat address-group 2 192.168.10.2 192.168.10.254
nat address-group 3 192.168.123.2 192.168.123.254
nat address-group 4 192.168.199.2 192.168.199.254
domain default enable system
port-security enable
undo alg dns
undo alg rtsp
undo alg h323
undo alg sip
undo alg sqlnet
undo alg pptp
undo alg ils
undo alg nbt
undo alg msn
undo alg qq
undo alg tftp
undo alg sccp
undo alg gtp
session synchronization enable
password-recovery enable
acl number 2001
rule 0 permit source 192.168.10.0 0.0.0.255 fragment logging
rule 5 permit source 192.168.100.0 0.0.0.255 logging
rule 10 permit source 192.168.123.0 0.0.0.255 fragment logging
rule 15 permit source 192.168.199.0 0.0.0.255 fragment logging
vlan 1
vlan 2 to 4
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
pki domain default
crl check disable
dhcp server ip-pool 10
network 192.168.10.0 mask 255.255.255.0
gateway-list 192.168.10.1
dns-list 218.2.2.2 218.4.4.4
domain-name home
dhcp server ip-pool 100
network 192.168.100.0 mask 255.255.255.0
gateway-list 192.168.100.1
domain-name boy
dhcp server ip-pool 123
network 192.168.123.0 mask 255.255.255.0
gateway-list 192.168.123.1
domain-name CCTV
dhcp server ip-pool 199
network 192.168.199.0 mask 255.255.255.0
gateway-list 192.168.199.1
domain-name any
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$pgBJwykwzLdmo5QoVqOptho6ButQoL2Y
authorization-attribute level 3
service-type telnet
service-type web
cwmp
undo cwmp enable
interface Dialer1
nat outbound 2001
link-protocol ppp
ppp chap user 18115816050
ppp chap password cipher $c$3$If6EV7LLQ2HI+9kNdjR5gWto5WlUIXNS
ppp pap local-user 18115816050 password cipher $c$3$miktvzchWqHSWekDWu15WTXs9QkFpnzK
ppp ipcp dns request
ip address ppp-negotiate
dialer user pppoeclient
dialer-group 1
dialer bundle 1
interface NULL0
interface GigabitEthernet0/0
port link-mode route
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/1
pppoe-client dial-bundle-number 1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
nat outbound 2001
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/3.1
vlan-type dot1q vid 2
nat outbound 2001
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/3.2
vlan-type dot1q vid 3
nat outbound 2001
ip address 192.168.123.1 255.255.255.0
interface GigabitEthernet0/3.3
vlan-type dot1q vid 4
nat outbound 2001
ip address 192.168.199.1 255.255.255.0
interface GigabitEthernet0/4
vd Root id 1
zone name Management id 0
priority 100
import interface GigabitEthernet0/0
zone name Local id 1
priority 100
zone name Trust id 2
priority 85
import interface GigabitEthernet0/3
import interface GigabitEthernet0/3.1
import interface GigabitEthernet0/3.2
import interface GigabitEthernet0/3.3
zone name DMZ id 3
priority 50
zone name Untrust id 4
priority 5
import interface Dialer1
import interface GigabitEthernet0/1
switchto vd Root
object network subnet 192.168.10.0/0.0.0.0
subnet 192.168.10.0 0.0.0.0
object network subnet 192.168.100.0/0.0.0.0
subnet 192.168.100.0 0.0.0.0
object network subnet 192.168.123.0/0.0.0.0
subnet 192.168.123.0 0.0.0.0
object network subnet 192.168.199.0/0.0.0.0
subnet 192.168.199.0 0.0.0.0
object network range 互通10
description 10.1
range 192.168.10.1 192.168.10.254
object network range 互通100
description 100.1
range 192.168.100.1 192.168.100.254
object network range 互通123
description 互通
range 192.168.123.1 192.168.123.254
object network range 互通199
description 互通
range 192.168.199.1 192.168.199.254
ip virtual-reassembly
zone name DMZ id 3
interzone source Local destination Trust
rule 0 permit
source-ip any_address
destination-ip any_address
service any_service
rule enable
interzone source Local destination Untrust
interzone source Trust destination Local
rule 0 permit logging
service any_service
rule enable
interzone source Trust destination Untrust
source-ip 互通10
source-ip 互通100
source-ip 互通123
source-ip 互通199
service any_service
rule enable
interzone source Untrust destination Trust
ip route-static 0.0.0.0 0.0.0.0 Dialer1
dhcp enable
dialer-rule 1 ip permit
load xml-configuration
load tr069-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
return
防火墙 拨号上网加DHCP加上网时间限制
交换机 VLAN(1-4)vlan_1---192.168.10.2 交换机2口trunk与防火墙3口连接
PC VLAN(3-4)DHCP自动获取
(0)
我的配置文件,不是很懂,求教高手
sysname H3C
undo alg dns
undo alg rtsp
undo alg h323
undo alg sip
undo alg sqlnet
undo alg pptp
undo alg ils
undo alg nbt
undo alg msn
undo alg qq
undo alg tftp
undo alg sccp
undo alg gtp
acl number 2001
vlan 1
vlan 2 to 4
domain system
state active
idle-cut disable
pki domain default
crl check disable
domain-name home
domain-name boy
domain-name CCTV
domain-name any
user-group system
local-user admin
service-type telnet
service-type web
cwmp
undo cwmp enable
interface Dialer1
nat outbound 2001
link-protocol ppp
dialer-group 1
dialer bundle 1
interface NULL0
nat outbound 2001
nat outbound 2001
nat outbound 2001
nat outbound 2001
vd Root id 1
priority 100
priority 100
priority 85
zone name DMZ id 3
priority 50
priority 5
switchto vd Root
description 10.1
description 100.1
description 互通
description 互通
zone name DMZ id 3
rule 0 permit
service any_service
rule enable
service any_service
rule enable
source-ip 互通10
source-ip 互通100
source-ip 互通123
source-ip 互通199
service any_service
rule enable
dhcp enable
return
(0)
看完头都晕了,为什么你每个接口都要做nat呢?其实只需要在互连网出口的地方做nat就可以了,把其它接口的 nat outbound 2001这个配置删除试试。
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
