IPSEC VPN建立不起来
2021-01-24提问
  • 1收藏,2170浏览
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
<H3C>dis cur
 version 5.20, Release 2516P19
 sysname H3C
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control password update interval 0 password-control login idle-time 0
 password-control complexity user-name check
 domain default enable system
 dns proxy enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
acl number 3000 rule 0 permit ip source 10.42.100.0 0.0.0.255 destination 10.42.1.0 0.0.0.255
 vlan 1
 # domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
ike proposal 1
 encryption-algorithm 3des-cbc
 dh group2
 authentication-algorithm md5
 sa duration 3600
 ike dpd vpn
# ike peer vpn
 exchange-mode aggressive
 proposal 1
 pre-shared-key cipher $c$3$Xgn679fXUp2MIXoNblsjF57VLCbX7SjoDl1EaKnqLBZe
 id-type name
 remote-name glsangfor
 remote-address 112.91.208.162
 local-name fqh3c
 nat traversal
 dpd vpn
 ipsec transform-set vpn
 encapsulation-mode tunnel
 transform esp esp
 esp encryption-algorithm 3des
 ipsec policy 720896 1 isakmp
 connection-name vpn
 security acl 3000
 ike-peer vpn
 transform-set vpn
 sa duration traffic-based 1843200
 sa duration time-based 3600
 dhcp server ip-pool vlan1 extended
 network ip range 10.42.100.21 10.42.100.220
 network mask 255.255.255.0
 gateway-list 10.42.100.1
 dns-list 114.114.114.114 8.8.8.8
user-group system
 group-attribute allow-guest
 local-user admin
 authorization-attribute level 3
 service-type telnet
 service-type web
local-user fengquan
 service-type telnet
 service-type web
 # cwmp
 undo cwmp enable
 interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
 interface Dialer10
 nat outbound
 link-protocol ppp
 ppp chap user CZ1376283481@16900.gd
 ppp chap password cipher $c$3$8Szg/akfkg8T7q1Yg8sjC0G/gZN5oEewrg==
 ppp pap local-user CZ1376283481@16900.gd password cipher $c$3$3Jp/TYT5VsWwT+8WGZD/cTmu8sBjx9vN2g==
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1492
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
 ipsec no-nat-process enable
 ipsec policy 720896
interface NULL0
interface Vlan-interface1
 ip address 10.42.100.1 255.255.255.0
 tcp mss 1024
 dhcp server apply ip-pool vlan1
interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 pppoe-client dial-bundle-number 10
interface GigabitEthernet0/4
 port link-mode
 route tcp mss 1024
interface GigabitEthernet0/1
 port link-mode bridge
 interface GigabitEthernet0/2
interface GigabitEthernet0/3
 ip route-static 0.0.0.0 0.0.0.0 Dialer10
 dhcp enable
 dialer-rule 10 ip permit
 nms primary monitor-interface Dialer10
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface tty 13
user-interface vty 0 4
 authentication-mode scheme
 # return
这是华三MSR810的的配置,请问下配置有没有问题,对端是深信服防火墙,使用野蛮模式隧道模式建立,目前建立不起来,这华三路由器配置哪里有问题呢
粉丝:122人 关注:6人
关于IPSEC VPN无法建立,以下是排查要点,请参考:
1、检查两端IPSEC VPN的加密算法、认证算法、认证密钥是否一致。
2、由于非固定IP端是在MSR830这里,检查下是否正确指向到了对端。
3、进一步检查到对端的路由是否可达。
4、另外在物理端口调用下IPSEC VPN看下。
5、确认两端是否都是野蛮模式。同时看下对端是否已指向到了本端的FQDN
粉丝:3人 关注:1人
IPSEC一般大部分都是配置问题,建议参考配置案例:https://www.h3c.com/cn/d_201807/1094144_30005_0.htm仔细核对一下,还有模式也要选择正确
不一定是华三设备配置问题,连不上有什么提示,一般都是IKE IPSEC 设置,感兴趣流不做nat 转换,分支路由这几个原因,要具体原因具体分析
在你的拨号口上的NAT去往对端的流量用ACL拒绝掉。
