f1000-ak135防火墙配置网桥模式 怎么配
2021-02-03提问
  • 1收藏,2249浏览
粉丝:0人 关注:3人
粉丝:121人 关注:6人
以下是防火墙透明模式的配置案例,请参考:
组网说明:
本案例采用H3C HCL模拟器的F1060防火墙来模拟防火墙的透明模式典型组网配置1。为了实现PC之间相互PING通,因此需要在SW1、R1之间通过路由指向来实现路由可达。F1060处在R1、SW1之间,所以将F1060配置为透明模式,采用access的方式为R1、SW1透传业务。
配置步骤
1、按照网络拓扑图正确配置IP地址
2、R1与SW1之间运行ospf路由协议
3、将F1060防火墙配置为透明模式,采用access的方式为R1、SW1透传业务。
配置关键点
SW1:
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 100
[SW1-vlan100]quit
[SW1]int vlan 100
[SW1-Vlan-interface100]ip address 172.16.1.1 24
[SW1-Vlan-interface100]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-type access
[SW1-GigabitEthernet1/0/1]port access vlan 100
[SW1-GigabitEthernet1/0/1]quit
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-mode route
[SW1-GigabitEthernet1/0/2]des <connect to FW1>
[SW1-GigabitEthernet1/0/2]ip address 10.0.0.1 30
[SW1-GigabitEthernet1/0/2]quit
[SW1]int loopback 0
[SW1-LoopBack0]ip address 1.1.1.1 32
[SW1-LoopBack0]quit
[SW1]ospf 1 router-id 1.1.1.1
[SW1-ospf-1]area 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 10.0.0.1 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 1.1.1.1 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 172.16.1.0 0.0.0.255
[SW1-ospf-1-area-0.0.0.0]quit
[SW1-ospf-1]quit
[SW1]
R1:
<H3C>sys
[H3C]sysname R1
[R1]int loopback 0
[R1-LoopBack0]ip address 2.2.2.2 32
[R1-LoopBack0]quit
[R1]int gi 0/1
[R1-GigabitEthernet0/1]ip address 192.168.1.1 24
[R1-GigabitEthernet0/1]quit
[R1]int gi 0/0
[R1-GigabitEthernet0/0]des <connect to FW1>
[R1-GigabitEthernet0/0]ip address 10.0.0.2 30
[R1-GigabitEthernet0/0]quit
[R1]ospf 1 router-id 2.2.2.2
[R1-ospf-1]area 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 10.0.0.2 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 2.2.2.2 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 192.168.1.0 0.0.0.255
[R1-ospf-1-area-0.0.0.0]quit
[R1-ospf-1]quit
FW1 透明模式配置关键点:
<H3C>sys
[H3C]sysname FW1
[FW1]vlan 10
[FW1-vlan10]quit
[FW1]int range gi 1/0/2 to gi 1/0/3
[FW1-if-range]port link-mode bridge
[FW1-if-range]port link-type access
[FW1-if-range]port access vlan 10
[FW1-if-range]quit
[FW1]security-zone name Trust
[FW1-security-zone-Trust]import interface GigabitEthernet 1/0/3 vlan 10
[FW1-security-zone-Trust]quit
[FW1]security-zone name Untrust
[FW1-security-zone-Untrust]import interface GigabitEthernet 1/0/2 vlan 10
[FW1-security-zone-Untrust]quit
[FW1]acl basic 2002
[FW1-acl-ipv4-basic-2002]rule 0 permit source any
[FW1-acl-ipv4-basic-2002]quit
[FW1]
[FW1]zone-pair security source trust destination untrust
[FW1-zone-pair-security-Trust-Untrust]packet-filter 2002
[FW1-zone-pair-security-Trust-Untrust]quit
[FW1]
[FW1]zone-pair security source untrust destination trust
[FW1-zone-pair-security-Untrust-Trust]packet-filter 2002
[FW1-zone-pair-security-Untrust-Trust]quit
[FW1]
[FW1]zone-pair security source trust destination local
[FW1-zone-pair-security-Trust-Local]packet-filter 2002
[FW1-zone-pair-security-Trust-Local]quit
[FW1]
[FW1]zone-pair security source local destination trust
[FW1-zone-pair-security-Local-Trust]packet-filter 2002
[FW1-zone-pair-security-Local-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination local
[FW1-zone-pair-security-Untrust-Local]packet-filter 2002
[FW1-zone-pair-security-Untrust-Local]quit
[FW1]
[FW1]zone-pair security source local destination untrust
[FW1-zone-pair-security-Local-Untrust]packet-filter 2002
[FW1-zone-pair-security-Local-Untrust]quit
[FW1]
[FW1]zone-pair security source trust destination trust
[FW1-zone-pair-security-Trust-Trust]packet-filter 2002
[FW1-zone-pair-security-Trust-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination untrust
[FW1-zone-pair-security-Untrust-Untrust]packet-filter 2002
[FW1-zone-pair-security-Untrust-Untrust]quit
测试:
所有PC都填写IP地址:
PC之间可以相互PING通:
分别查看SW1、R1的OSPF邻居信息:
分别查看SW1、R1的路由表:
查看FW1的zone-pair:
温馨提示:如果要实现防火墙的远程登陆管理,建议新增一条链路连接到交换机或者路由器,做带外管理即可。
粉丝:8人 关注:1人
web.界面里有一个快速配置  让你选模式 透明还是路由  选完透明,然后下一步  下一步配就完了
粉丝:18人 关注:1人
如下配置
防火墙透明部署 (命令行).docx
防火墙透明部署案例
防火墙透明部署案例... 1
1 配置需求或说明... 1
1.1 适用的产品系列... 1
1.2 配置需求... 1
2 组网图... 2
3 配置步骤... 2
3.1配置连接路由器接口... 2
3.2配置连接核心交换机接口... 2
3.1 安全策略配置... 3
3.4保存配置... 4
3.5查看与验证... 4
1 配置需求或说明
1.1  适用的产品系列
本案例适用于软件平台为Comware V7系列防火墙:F100-X-G2F1000-X-G2F100-WiNetF1000-AKF10X0
注:本案例是在F100-C-G2Version 7.1.064, Release 9510P08版本上进行配置和验证的。
1.2  配置需求
如下组网图所示,在原有的网络中增加防火墙来提高网络安全性,但又不想对原有网络配置进行改动,所以需要防火墙采用透明模式部署;其中GigabitEthernet 1/0/1接口接原有路由器的下联口,GigabitEthernet 1/0/3接口接原有的交换机上联口。
2 组网图
3 配置步骤
3.1配置连接路由器接口
#1/0/1端口设置成二层模式
<H3C>system-view
[H3C]interface GigabitEthernet 1/0/1
[H3C-GigabitEthernet1/0/1]port link-mode bridge
[H3C-GigabitEthernet1/0/1]quit
#1/0/1端口加入到Untrust
[H3C]security-zone name Untrust
[H3C-security-zone-Untrust]import interface GigabitEthernet1/0/1 vlan 1 to 4094
[H3C-security-zone-Untrust]quit
3.2配置连接核心交换机接口
#1/0/3端口设置成二层模式
[H3C]interface GigabitEthernet 1/0/3
[H3C-GigabitEthernet1/0/3]port link-mode bridge
[H3C-GigabitEthernet1/0/3]quit
#1/0/3端口加入到Trust
[H3C]security-zone name Trust
[H3C-security-zone-Trust]import interface GigabitEthernet1/0/3 vlan 1 to 4094
[H3C-security-zone-Trust]quit
3.1  安全策略配置
防火墙目前版本存在两套安全策略,请在放通安全策略前确认设备运行那种类型的安全策略?以下配置任选其一。
1. 通过命令“display cu | in security-policy”如果查到命令行存在“security-policy disable”或者没有查到任何信息,则使用下面策略配置。
[H3C]display cu | in security-policy
配置安全策略将TrustUntrust域内网数据放通
#创建对象策略pass
[H3C]object-policy ip pass
[H3C-object-policy-ip-pass] rule 0 pass
[H3C-object-policy-ip-pass]quit
创建TrustUntrust域的域间策略调用pass策略。
[H3C]zone-pair security source Trust destination Untrust
[H3C-zone-pair-security-Trust-Untrust]object-policy apply ip pass
[H3C-zone-pair-security-Trust-Untrust]quit
配置安全策略将TrustLocal域、LocalTrustLocalUntrust域数据全放通策略
#创建TrustLocal域的域间策略调用pass策略。
[H3C]zone-pair security source Trust destination Local
[H3C-zone-pair-security-Trust-Local]object-policy apply ip pass
[H3C-zone-pair-security-Trust-Local]quit
#创建LocalTrust域的域间策略调用pass策略。
[H3C]zone-pair security source Local destination Trust
[H3C-zone-pair-security-Local-Trust]object-policy apply ip pass
[H3C-zone-pair-security-Local-Trust]quit
#创建LocalUntrust域的域间策略调用pass策略。
[H3C]zone-pair security source Local destination Untrust
[H3C-zone-pair-security-Local-Untrust]object-policy apply ip pass
[H3C-zone-pair-security-Local-Untrust]quit
2. 通过命令“display cu | in security-policy”如果查到命令行存在“security-policy ip”并且没有查到“security-policy disable”,则使用下面策略配置。
security-policy ip
创建安全策略并放通localtrusttrustlocal的安全策略。
[H3C]security-policy ip
[H3C-security-policy-ip]rule 10 name test
[H3C-security-policy-ip-10-test]action pass
[H3C-security-policy-ip-10-test]source-zone local
[H3C-security-policy-ip-10-test]source-zone Trust
[H3C-security-policy-ip-10-test]source-zone Untrust
[H3C-security-policy-ip-10-test]destination-zone local
[H3C-security-policy-ip-10-test]destination-zone Trust
[H3C-security-policy-ip-10-test]destination-zone Untrust
[H3C-security-policy-ip-10-test]quit
3.4保存配置
<H3C>save force
3.5查看与验证
配置完成后终端可以上网,路由器和交换机不需要更改配置
