堆叠
2021-03-03提问
  • 1收藏,910浏览
两台核心交换机做好堆叠后,都断电了,重新上电后备交换机的接口配置没有了,这个怎么解决?
粉丝:17人 关注:5人
是不是之前忘记保存配置了。
也可以参考下下面的举例。
需确认下IRF部署后是否保存了配置。
以下是IRF的配置举例,请参考:
https://zhiliao.h3c.com/theme/details/96463
1、1号设备关键配置如下:
[H3C]irf member 1 renumber 1     //将1号设备设定为成员1
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]:y
[H3C]int range Ten-GigabitEthernet 1/0/50 to Ten-GigabitEthernet 1/0/51
[H3C-if-range]shutdown
[H3C-if-range]quit
[H3C]irf-port 1/1  //将物理端口绑定到IRF端口
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/1]quit
[H3C-if-range]undo shutdown
[H3C-if-range]quit
[H3C]irf-port-configuration active  //激活IRF
[H3C]save
2、2号设备关键配置点如下:
[H3C]irf member 1 renumber 2  //将2号设备设定为成员2
[H3C-if-range]quit
[H3C]irf-port 1/2  //将物理端口绑定到IRF端口
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/2]quit
[H3C-if-range]quit
[H3C]save
3、分别将成员1设备、成员2设备重启
4、测试
<H3C>dis irf  //查看IRF的信息,看到成员1和成员2的设备信息都在一起
MemberID    Role    Priority  CPU-Mac         Description
 *+1        Master  1         30bd-490a-0104  ---
   2        Standby 1         30bd-525e-0204  ---
 The bridge MAC of the IRF is: 30bd-490a-0100
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
<H3C>
<H3C>dis irf link  //查看成员1、成员2 IRF链路的状态均为UP
Member 1
 IRF Port  Interface                             Status
 1         Ten-GigabitEthernet1/0/50             UP
           Ten-GigabitEthernet1/0/51             UP
 2         disable                               --
Member 2
 1         disable                               --
 2         Ten-GigabitEthernet2/0/50             UP
           Ten-GigabitEthernet2/0/51             UP
<H3C>
<H3C>dis irf configuration  //查看IRF的配置信息
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        Ten-GigabitEthernet1/0/50     disable
 2        2        disable                       Ten-GigabitEthernet2/0/50
<H3C>
<H3C>dis irf topology  //查看IRF的拓扑信息
                              Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 2           DIS        ---           UP         1           30bd-490a-0104
 1           UP         2             DIS        ---         30bd-490a-0104
<H3C>
如果已经确认了保存了配置还是不行,可考虑升级软件版本到最新后再重新配置看下。
粉丝:42人 关注:0人
应该是之前配置没有保存导致的。
粉丝:38人 关注:3人
只能重新配置一下肯定是没保存啊
