S5120
2021-03-05提问
  • 1收藏,1706浏览
[H3C-Bridge-Aggregation1]port trunk permit vlan 1
 Please wait... Done.
 Error: Failed to configure on interface GigabitEthernet1/0/49!
Error: Failed to configure on interface GigabitEthernet1/0/50!
 Error: Failed to configure on interface GigabitEthernet1/0/51!
 Error: Failed to configure on interface GigabitEthernet1/0/52!
端口组配置下发失败,端口组状态如下,如何做成Select?
[H3C]dis link-aggregation verbose Loadsharing Type: Shar -- Loadsharing, NonS -- Non-Loadsharing Port Status: S -- Selected, U -- Unselected Flags: A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation, D -- Synchronization, E -- Collecting, F -- Distributing, G -- Defaulted, H -- Expired Aggregation Interface: Bridge-Aggregation1 Aggregation Mode: Static Loadsharing Type: Shar
 Port               Status      Oper-Key --------------------------------------------------------------------------------
 GE1/0/49            U               1
 GE1/0/50            U               1
 GE1/0/51            U               1
 GE1/0/52            U               1
粉丝:124人 关注:6人
检查下这几个端口是否有其他的特殊配置。
其次看下这个聚合组是否有在其他物理端口中应用,如果有,可以将其他物理端口中删除聚合组的应用后再调用聚合组到新的物理成员端口。
另外dis logbuffer看下是否有相应的日志反馈。
<H3C>dis cur # version 5.20, Feature 2209P01 # sysname H3C # domain default enable system # telnet server enable # vlan 1 # vlan 150 # radius scheme system server-type extended primary authentication 127.0.0.1 1645 primary accounting 127.0.0.1 1646 user-name-format without-domain # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system # interface Bridge-Aggregation1 port link-type trunk port trunk permit vlan 1 100 150 # interface NULL0 # interface GigabitEthernet1/0/1 port access vlan 150 # interface GigabitEthernet1/0/2 port access vlan 150 # interface GigabitEthernet1/0/3 port access vlan 150 # interface GigabitEthernet1/0/4 port access vlan 150 # interface GigabitEthernet1/0/5 # interface GigabitEthernet1/0/6 # interface GigabitEthernet1/0/7 # interface GigabitEthernet1/0/8 # interface GigabitEthernet1/0/9 # interface GigabitEthernet1/0/10 # interface GigabitEthernet1/0/11 # interface GigabitEthernet1/0/12 # interface GigabitEthernet1/0/13 # interface GigabitEthernet1/0/14 # interface GigabitEthernet1/0/15 # interface GigabitEthernet1/0/16 # interface GigabitEthernet1/0/17 # interface GigabitEthernet1/0/18 # interface GigabitEthernet1/0/19 # interface GigabitEthernet1/0/20 # interface GigabitEthernet1/0/21 # interface GigabitEthernet1/0/22 # interface GigabitEthernet1/0/23 # interface GigabitEthernet1/0/24 # interface GigabitEthernet1/0/25 # interface GigabitEthernet1/0/26 # interface GigabitEthernet1/0/27 # interface GigabitEthernet1/0/28 # interface GigabitEthernet1/0/29 # interface GigabitEthernet1/0/30 # interface GigabitEthernet1/0/31 # interface GigabitEthernet1/0/32 # interface GigabitEthernet1/0/33 # interface GigabitEthernet1/0/34 # interface GigabitEthernet1/0/35 # interface GigabitEthernet1/0/36 # interface GigabitEthernet1/0/37 # interface GigabitEthernet1/0/38 # interface GigabitEthernet1/0/39 # interface GigabitEthernet1/0/40 # interface GigabitEthernet1/0/41 # interface GigabitEthernet1/0/42 # interface GigabitEthernet1/0/43 # interface GigabitEthernet1/0/44 # interface GigabitEthernet1/0/45 shutdown # interface GigabitEthernet1/0/46 shutdown # interface GigabitEthernet1/0/47 shutdown # interface GigabitEthernet1/0/48 shutdown # interface GigabitEthernet1/0/49 port link-aggregation group 1 # interface GigabitEthernet1/0/50 port link-aggregation group 1 # interface GigabitEthernet1/0/51 port link-aggregation group 1 # interface GigabitEthernet1/0/52 port link-aggregation group 1 # ip route-static 0.0.0.0 0.0.0.0 192.168.100.254 # load xml-configuration # user-interface aux 0 user-interface vty 0 15 # return <H3C>
宁普记-18178973300 发表时间:2021-03-05
粉丝:2人 关注:8人
看下要加入聚合组的接口是否有配置
接口都清空配置了,现在就只有一个聚合组
[H3C-GigabitEthernet1/0/52]dis this # interface GigabitEthernet1/0/52 port link-aggregation group 1
米多 六段
粉丝:3人 关注:0人
根据你的配置,聚合组是trunk 口,物理口是access口,trunk配置下发不下去是对的
再刷一遍下面的命令
然后再放行vlan
或者 修改物理口为trunk口
