分支单外网链路与总部双外网链路形成IPSec VPN主备,无法实现主备
2021-03-17提问
  • 1收藏,1258浏览
z6Kl9 九段
粉丝:66人 关注:2人
环境:
某大型互联网企业在全国各地都有分支机构,为提高业务的可靠性需要分支单位与总部单位建立互为主备的IPSEC隧道,
总部为双互联网出口、分支为单互联网出口;
需求:
1、当总部出口链路其中一条出现故障,可以实现IPSec备份确保业务不中断;
2、当两条链路均为正常时候实现IPSec流量负载,根据链路质量进行切换;
3、由于分支设备不支持tunnel隧道,不采用tunnel方式建立IPSec隧道。
问题:采用点到多点模式,总部侧采用策略方式,分部侧采用策略模板方式,现阶段是第一阶段无法建立连接,初步猜测采用的IPSec模式不对,IPSec建立不起来
配置文件:
总部配置:
 version 7.1.075, Alpha 7571
 sysname MSR1
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 1.1.1.1 255.255.255.0
 nat outbound 3001
 ipsec apply policy zb
interface GigabitEthernet0/1
 combo enable copper
 ip address 2.2.2.1 255.255.255.0
 nat outbound 3001
 ipsec apply policy zb2
 ip route-static 0.0.0.0 0 1.1.1.2
 ip route-static 0.0.0.0 0 2.2.2.2
acl advanced 3000
 rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
acl advanced 3001
 rule 0 deny ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
 rule 10000 permit ip
 ipsec transform-set 1
 esp encryption-algorithm des-cbc
 esp authentication-algorithm sha1
ipsec policy zb 1 isakmp
 transform-set 1 security
acl 3000 ike-profile 1
ipsec policy zb2 1 isakmp
 transform-set 1
 security acl 3000
 ike-profile 2
ike profile 1
 keychain 1
 local-identity address 1.1.1.1
 match remote identity address 3.3.3.3 255.255.255.255
 proposal 1
ike profile 2
 keychain 1
 local-identity address 2.2.2.1
 proposal 1
ike proposal 1
 encryption-algorithm 3des-cbc
 authentication-algorithm sha256
ike keychain 1
 pre-shared-key address 3.3.3.3 255.255.255.255 key cipher 12345678
return
分部侧配置:
 sysname MSR2
 lldp global enable
 combo enable copper
 ip address 3.3.3.3 255.255.255.0
 nat outbound 3001
 ipsec apply policy fz
 combo enable copper
 ip address 192.168.2.1 255.255.255.0
 ip route-static 0.0.0.0 0 3.3.3.1
acl advanced 3000
 rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
acl advanced 3001
 rule 0 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
 rule 1000 permit ip
 esp encryption-algorithm 3des-cbc esp
ipsec policy-template zb 1
 transform-set 1
 security acl 3000
 ike-profile 1
ipsec policy-template zb2 1
 transform-set 1
 security acl 3000
 ike-profile 2
ipsec policy fz 1 isakmp template zb
ipsec policy fz 2 isakmp template zb2
ike profile 1
 keychain 1
 local-identity address 3.3.3.3
 match remote identity address 1.1.1.1 255.255.255.255
 proposal 1
ike profile 2
 keychain 1
 match remote identity address 2.2.2.1 255.255.255.255
 proposal 1
ike proposal 1
ike keychain 1 pre-shared-key address 1.1.1.1 255.255.255.255 key cipher 12345678
 pre-shared-key address 2.2.2.1 255.255.255.255 key cipher 12345678
return
ISP侧配置:
粉丝:226人 关注:0人
分部测应该配以下,ike-profile 2不是ike-profile 1
 transform-set 1
 security acl 3000
 ike-profile 2
总部双出口呀,分部肯定也要和总部建立IPSec连接的,肯定要配置双模板
z6Kl9 发表时间:2021-03-17
你这个和总部没对应
无名之辈 发表时间:2021-03-17
回复无名之辈:
我总部用的是策略方式,分部用的是策略模板,因为总部是双出口,需要在两个外网口引用IPSec策略
粉丝:36人 关注:10人
两个接口都应用ipsec policy,用路由实现切换。两条隧道都建立,指路由优先级,优先走第一条链路。
那总部用IPSec策略方式是没问题的是吧,分部 ike keychain 分开写?
