H3C NS228输入任何命令出现 发现无法识别的命令
2021-03-31提问
  • 1收藏,1886浏览
设置列表
  • 有序列表
  • 无序列表
 NS228输入任何命令出现 % unrecognized command found at '^' position.是怎么回事啊
Startup configuration file does not exist. Started automatic configuration, press CTRL_C or CTRL_D to break.
启动时报错:启动配置文件不存在。 已启动自动配置,按CTRL\u C或CTRL\u D可中断
想恢复出厂:reset saved-configuration
H3C NS228 BOOTROM, Version 124 * * * ******************************************************************************** Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd. Creation Date : Apr 13 2015, 14:45:33 CPU Clock Speed : 400MHz Memory Size : 1024MB Flash Size : 512MB CPLD Version : 002 PCB Version : Ver.B Mac Address : 741f4aa8dccc Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/ns200-cmw710-system-r3109p05.bin............................ ................................Done. Loading file flash:/ns200-cmw710-boot-r3109p05.bin............Done. Image file flash:/ns200-cmw710-boot-r3109p05.bin is self-decompressing.......... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ...................................Done. System is starting... Cryptographic algorithms tests passed. Startup configuration file does not exist. Started automatic configuration, press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration is aborted. Line aux0 is available. Press ENTER to get started.
login: admin Password:
<H3C>%Jan 1 01:26:20:542 2013 H3C SHELL/5/SHELL_LOGIN: admin logged in from aux 0.
 <H3C>reset saved-configuration
 ^ % Unrecognized command found at '^' position.
<H3C>
粉丝:10人 关注:1人
这个是低端设备,不支持cli,不能命令行配置,只能支持web管理
https://www.h3c.com/cn/d_201711/1044587_30005_0.htm
粉丝:3人 关注:0人
命令你没敲对吧
粉丝:8人 关注:1人
NS228 本身就是web网管型设备 只支持简单的几条命令  如果真的想配成可以用console调的那种  你需要根400要 有那种受限的版本 但是不知道会不会给你
zhiliao_IsszA1 知了小白
命令initialize   作用初始化设备
