MSR36-20 Serial1/0 协议DOWN,
2018-05-29提问
  • 1收藏,2324浏览
MSR36-20 Serial1/0 协议DOWN,但改为其它在改回来就会UP一会。过一会又DOWN,
使用的是HDLC,物理层是UP的。协议起不来,但我把接口改为PPP后,在改回来时就UP了,但过一会就DOWN了,
这是什么 情况,
粉丝:10人 关注:1人
先排查错包,更换H3C原厂的线缆,然后设备一定要接地地排,保持和直连的设备电压差一定要为0,错包解决后,这个问题应该也就解决了
粉丝:7人 关注:3人
接口有错包增长么
收发都有增长
zhiliao_GUEIV 发表时间:2018-05-29
错包有增长
zhiliao_GUEIV 知了小白
Serial1/0 Current state: UP Line protocol state: DOWN Description: To DHDD_OCS Bandwidth: 2048 kbps Maximum transmission unit: 1500 Hold timer: 10 seconds, retry times: 5 Physical layer is E1-F, baudrate is 2048000 bps fe1 unframed Internet address: 172.30.249.194/30 (primary) Link layer protocol: HDLC Port priority: 0 Output queue - Urgent queuing: Size/Length/Discards 0/100/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 Last link flapping: 0 hours 0 minutes 26 seconds Last clearing of counters: Never Last 300 seconds input rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec Last 300 seconds output rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec Input: 143 packets, 6646 bytes 38 errors, 0 runts, 35 giants 1 CRC, 2 align errors, 0 overruns 0 aborts, 0 no buffers, 0 frame errors Output: 143 packets, 3076 bytes 0 errors, 0 underruns, 0 collisions 0 deferred
Input: 155 packets, 6910 bytes 38 errors, 0 runts, 35 giants 1 CRC, 2 align errors, 0 overruns 0 aborts, 0 no buffers, 0 frame errors Output: 156 packets, 3362 bytes 0 errors, 0 underruns, 0 collisions 0 deferred
zhiliao_y0vx8W 知了小白
接口成帧模式问题,fel unframed
