display interface [ interface-type | interface-type interface-number ]
interface-type:端口类型。
interface-number:端口编号。
参数的具体说明请参见interface命令中的参数解释。
【描述】
display interface命令用来显示端口的配置信息。
在显示端口信息时:
l 如果不指定端口类型和端口号,则显示交换机上所有的端口信息;
l 如果仅指定端口类型,则显示该类型端口的所有端口信息;如果同时指定端口类型和端口号,则显示指定的端口信息。
# 显示以太网端口GigabitEthernet1/0/1的配置信息。
<Sysname> display interface GigabitEthernet1/0/1
GigabitEthernet1/0/1 current state : DOWN
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 0012-a990-2240
Media type is twisted pair, loopback not set
Port hardware type is 100_BASE_TX
100Mbps-speed mode, full-duplex mode
Link speed type is force link, link duplex type is force link
Flow-control is enabled
The Maximum Frame Length is 9216
Broadcast MAX-ratio: 100%
Unicast MAX-ratio: 100%
Multicast MAX-ratio: 100%
Allow jumbo frame to pass
PVID: 1
Mdi type: auto
Port link-type: access
Tagged VLAN ID : none
Untagged VLAN ID : 1
Last 300 seconds input: 0 packets/sec 0 bytes/sec
Last 300 seconds output: 0 packets/sec 0 bytes/sec
Input(total): 0 packets, 0 bytes
0 broadcasts, 0 multicasts, 0 pauses
Input(normal): - packets, - bytes
- broadcasts, - multicasts, - pauses
Input: 0 input errors, 0 runts, 0 giants, - throttles, 0 CRC
0 frame, - overruns, 0 aborts, 0 ignored, - parity errors
Output(total): 0 packets, 0 bytes
Output(normal): - packets, - bytes
0 lost carrier, - no carrier
表1-4 display interface命令显示信息描述表
字段 | 描述 |
GigabitEthernet1/0/1 current state | 以太网端口的当前状态,可以为UP、DOWN或ADMINISTRATIVELY DOWN |
IP Sending Frames' Format | 以太网帧格式 |
Hardware address | 端口硬件地址 |
Media type | 介质类型 |
Port hardware type | 端口硬件类型 |
100Mbps-speed mode, full-duplex mode | 当前的速率和双工模式 |
Link speed type is force link, link duplex type is force link | 连接速率和双工的状态(强制状态或自动协商状态) |
Flow-control is enabled | 端口流控功能的状态 |
The Maximum Frame Length | 端口允许通过的最大以太网帧长度 |
Broadcast MAX-ratio | 端口广播风暴抑制比 |
Unicast MAX-ratio | 端口未知单播风暴抑制比 |
Multicast MAX-ratio | 端口组播风暴抑制比 |
Allow jumbo frame to pass | 端口允许长帧通过 |
PVID | 端口缺省VLAN ID |
Mdi type | 网线类型 |
Port link-type | 端口链路类型 |
Tagged VLAN ID | 标识该端口在转发哪些VLAN的报文时需要保留Tag标记 |
Untagged VLAN ID | 标识该端口在转发哪些VLAN的报文时不需要保留Tag标记 |
Last 300 seconds input: 0 packets/sec 0 bytes/sec Last 300 seconds output: 0 packets/sec 0 bytes/sec | 端口在最近300秒接收和转发报文的平均速率,单位分别为数据包/秒和字节/秒 |
Input(total): 0 packets, 0 bytes 0 broadcasts, 0 multicasts, 0 pauses | 端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数 端口接收的广播报文、组播报文和PAUSE帧的数量 |
Input(normal): - packets, - bytes - broadcasts, - multicasts, - pauses | 端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数 端口接收的正常广播报文、组播报文和PAUSE帧的数量 其中“-”表示不支持该统计项 |
input errors | 各种接收错误的总数 |
runts | 接收到的超小帧的数量 超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧 |
giants | 接收到的超大帧的数量 超大帧是指有效长度大于1518字节(如果不带VLAN Tag)或大于1522字节(如果带VLAN Tag报文)的帧 |
- throttles | 端口出现throttles的次数 当缓存或CPU过载时,设备将端口关闭情况称为throttle |
CRC | 接收到的CRC校验错误、长度正常的帧的数量 |
frame | 接收到的CRC校验错误、且长度不是整字节数的帧的数量 |
- overruns | 当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃 |
aborts | 接收到的非法报文总数,非法报文包括: 报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧 jabber帧:大于1518或1522字节,且CRC校验错误(报文字节可以为整数或非整数) 符号错误帧:报文中至少包含1个错误的符号 操作码未知帧:报文是MAC控制帧,但不是Pause帧 长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配 |
ignored, | 由于端口接收缓冲区不足等原因而丢弃的报文数量 |
- parity errors | 接收到的奇偶校验错误的帧的数量 |
Output(total): 0 packets, 0 bytes 0 broadcasts, 0 multicasts, 0 pauses | 端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数 端口发送的广播报文、组播报文和PAUSE帧的数量 |
Output(normal): - packets, - bytes - broadcasts, - multicasts, - pauses | 端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数 端口发送的正常广播报文、组播报文和PAUSE帧的数量 其中“-”表示不支持该统计项 |
output errors | 各种发送错误的报文总数 |
- underruns | 当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常 |
- buffer failures | 由于端口发送缓冲区不足而丢弃的报文数量 |
aborts | 发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败 |
deferred | 延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文 |
collisions | 冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文 |
late collisions | 延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送 |
lost carrier | 载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一 |
- no carrier | 无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一 |
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
