V7两台105做堆叠,现场做了BFD MAD检测,
vlan 1111
description "xintiao"
interface Vlan-interface1111
mad bfd enable
mad ip address 20.20.20.1 255.255.255.0 member 1
mad ip address 20.20.20.2 255.255.255.0 member 2
interface GigabitEthernet1/5/0/48
port link-mode bridge
description to_bfd
port access vlan 1111
interface GigabitEthernet2/5/0/48
description to_bfd
现在看到两个BFD接口下outpu流量跑满,
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 60da-83f7-0c00
Description: to_bfd
Bandwidth: 1000000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T
1000Mbps-speed mode, full-duplex mode
Flow-control is not enabled
Maximum frame length: 9216
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1111
MDI type: Automdix
Port link-type: Access
Tagged VLANs: None
Untagged VLANs: 1111
Port priority: 0
Last link flapping: 5 days 0 hours 6 minutes
Peak input rate: 982 bytes/sec, at 2017-07-18 15:24:14
Peak output rate: 95375255 bytes/sec, at 2017-07-19 12:15:55
Last 300 second input: 13 packets/sec 979 bytes/sec 0%
Last 300 second output: 1488334 packets/sec 95253501 bytes/sec 100%
Input (total): 4473991 packets, 313180463 bytes
0 unicasts, 21 broadcasts, 4473970 multicasts, 0 pauses
Input (normal): 4473991 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (total): 287938816307 packets, 18428116651015 bytes
0 unicasts, 287933913656 broadcasts, 4902651 multicasts, 0 pauses
Output (normal): 287938816307 packets, - bytes
0 lost carrier, - no carrier
Current state: UP
IP packet frame type: Ethernet II, hardware address: 1cab-34b9-5c00
Description: to_bfd
Loopback is not set
PVID: 1111
MDI type: Automdix
Tagged VLANs: None
Port priority: 0
Peak input rate: 95388827 bytes/sec, at 2017-07-19 02:20:21
Peak output rate: 982 bytes/sec, at 2017-07-18 15:25:04
Last 300 second input: 1487871 packets/sec 95223841 bytes/sec 99%
Last 300 second output: 14 packets/sec 980 bytes/sec 0%
Input (total): 287941459950 packets, 18428285844274 bytes
0 unicasts, 287936557276 broadcasts, 4902674 multicasts, 0 pauses
Input (normal): 287941459950 packets, - bytes
Output (total): 4474017 packets, 313182283 bytes
0 unicasts, 21 broadcasts, 4473996 multicasts, 0 pauses
Output (normal): 4474017 packets, - bytes
这个该怎么解决
(0)
BFD MAD与生成树功能互斥,关闭STP试试呢?
(0)
STP未开启
dis vlan 1111看下?是否还有别的端口放通vlan 1111了?
VLAN ID: 1111 VLAN type: Static Route interface: Configured IPv4 address: 20.20.20.1 IPv4 subnet mask: 255.255.255.0 Description: "xintiao" Name: VLAN 1111 Tagged ports: None Untagged ports: GigabitEthernet1/5/0/48 GigabitEthernet2/5/0/48 没有,就这两个端口
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
