H3C F100-A-SI防火墙如下配置:不能从外网web管理15.26.3.3,内网可以web管理10.100.37.1,不知什么原因
sysname XXX
super password level 3 cipher xxx
ike local-name zhejiang
firewall packet-filter enable
firewall packet-filter default permit
undo insulate
nat address-group 2 15.26.3.3 15.26.3.3
firewall statistic system enable
radius scheme system
server-type extended
domain system
local-user admin
password simple XXXX
service-type telnet
level 3
ike peer zhejiang
exchange-mode aggressive
pre-shared-key zhejiang
id-type name
remote-name center
remote-address 2.2.9.1
nat traversal
ipsec proposal zhejiang
esp authentication-algorithm sha1
esp encryption-algorithm 3des
ipsec policy zhejiang 10 isakmp
security acl 3000
ike-peer zhejiang
proposal zhejiang
acl number 2000
rule 2000 permit source 10.100.37.0 0.0.0.255
acl number 3000
rule 0 permit ip source 10.100.37.0 0.0.0.63 destination 10.100.0.0 0.0.0.255
rule 255 deny ip
acl number 3002
rule 0 deny ip source 10.100.37.0 0.0.0.63 destination 10.100.0.0 0.0.0.255
rule 10 permit icmp
rule 20 permit tcp
rule 30 permit udp
nat server-group protocol
interface Aux0
async mode flow
interface Ethernet0/0
description WCN_INTERFACE_LAN
ip address 10.100.37.1 255.255.255.0
interface Ethernet1/0
description WCN_INTERFACE_WAN
ip address 15.26.3.3 255.255.255.128
nat outbound 3002 address-group 2
interface Ethernet1/1
interface Bridge-template1
interface NULL0
firewall zone local
set priority 100
firewall zone trust
add interface Ethernet0/0
set priority 85
firewall zone untrust
add interface Ethernet1/0
set priority 5
firewall zone DMZ
set priority 50
firewall interzone local trust
firewall interzone local untrust
firewall interzone local DMZ
firewall interzone trust untrust
firewall interzone trust DMZ
firewall interzone DMZ untrust
ip route-static 0.0.0.0 0.0.0.0 15.26.3.1 preference 60
ip route-static 10.100.0.0 255.255.255.0 15.26.3.1 preference 60
ip rpf-longest-match
user-interface con 0
user-interface aux 0
user-interface vty 0 4
return
防火墙H3C F100-A-SI一端接内网一端接外网
外网口E1/0 地址15.26.3.3
内网口E0/0 地址10.100.37.1
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
那我应该怎么配置,才能实现可以从外网web管理
试试有没有ip http port xxx,然后登录时使用类似http://x.x.x.x:xxx登录,或者找运营商打开80端口
联系运营商放通80端口即可
不是吧,运营商还会关了这个地址的80端口?我说以前都正常使用的,最近怎么不能访问了,也没更改过配置啊!
不会跟运营商有关系,我直接笔记本接外网口也是不能访问的
