stp
2021-04-27提问
  • 1收藏,822浏览
61990 二段
交换机一直报错
TE: Instance 0's port Bridge-Aggregation38 received an inferior BPDU from a designated port which is in forwarding or learning state. %Apr 27 13:42:38:568 2021 SZ8-SC-1F104-A01-CS01 STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation38 received an inferior BPDU from a designated port which is in forwarding or learning state. %Apr 27 13:42:40:569 2021 SZ8-SC-1F104-A01-CS01 STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation38 receiv
这是啥原因
粉丝:143人 关注:1人
received an inferior BPDU含义为是交换机上收到低优先级的BPDU,同时该BPDU携带learning或forwarding标志,即认为自己为根端口;查看abnormal-port时发现该端口被disputed,该功能是保护根桥,防止下层网络震荡,一般产生原因为链路单通,对端收不到根桥发送的BPDU报文,从而对端一直发送低优先级的BPDU
从Bridge-Aggregation38接口收到了次优的BPDU,导致对应接口被dispute阻塞掉了,建议现场排查下与聚合38互联的设备是否能收到本设备发出的BPDU,是否存在单通等情况。
粉丝:68人 关注:0人
received an inferior BPDU含义为是交换机上收到低优先级的BPDU ,需确保根桥的优先级在网络中最高,其次在根桥的下联端口开启根保护看下。
