S5500V3-24P-SI 接口收到大量的ARP报文
2021-04-29提问
  • 1收藏,1316浏览
交换机下联POE的接口收到大量的ARP报文,是不是有什么问题,怎么处理呢
粉丝:124人 关注:6人
大量接收到ARP报文,以下是排查要点,请参考:
1、检查上行端口内是否有其他特殊的配置。
2、检查物理链路是否有问题。
3、检查是否有可能存在ARP攻击。
4、dis logbuffer看下是否有其他日志反馈。
4 个回答
zhiliao_8NJl46 知了小白
PktType= ARP , srcMAC=8265-b6f8-6874, Drop From Interface=GE1/0/13 at Stage=63, StageCnt=189 TotalCnt=10970, Max Rate Interface=GE1/0/13 !! %Jan 12 15:55:31:124 2013 core LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/7 (IfIndex 7), neighbor's chassis ID is 8c16-4520-64a3, port ID is 8c16-4520-64a3. %Jan 12 16:13:24:170 2013 core DRVPLAT/4/SOFTCAR DROP: PktType= ARP , srcMAC=0c70-4af6-4583, Drop From Interface=GE1/0/13 at Stage=63, StageCnt=565 TotalCnt=11535, Max Rate Interface=GE1/0/13 !! %Jan 12 17:14:25:201 2013 core DRVPLAT/4/SOFTCAR DROP: PktType= ARP , srcMAC=9ce8-2b89-970d, Drop From Interface=GE1/0/13 at Stage=63, StageCnt=273 TotalCnt=11808, Max Rate Interface=GE1/0/13 !! %Jan 12 17:15:58:963 2013 core LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port GigabitEthernet1/0/5 (IfIndex 5), neighbor's chassis ID is 94c6-91bc-2b29, port ID is 94c6-91bc-2b29. %Jan 12 18:09:48:133 2013 core LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on port GigabitEthernet1/0/7 (IfIndex 7), neighbor's chassis ID is 8c16-4520-64a3, port ID is 8c16-4520-64a3. %Jan 12 19:13:50:711 2013 core LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/5 (IfIndex 5), neighbor's chassis ID is 94c6-91bc-2b29, port ID is 94c6-91bc-2b29. %Jan 12 19:23:13:350 2013 core DRVPLAT/4/SOFTCAR DROP: PktType= ARP , srcMAC=986f-6075-64e3, Drop From Interface=GE1/0/13 at Stage=63, StageCnt=992 TotalCnt=12800, Max Rate Interface=GE1/0/13 !! %Jan 12 19:29:38:190 2013 core LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on port GigabitEthernet1/0/5 (IfIndex 5), neighbor's chassis ID is 94c6-91bc-2b29, port ID is 94c6-91bc-2b29.
zhiliao_8NJl46 知了小白
这样的ARP报文正常么
粉丝:7人 关注:2人
看一下是否是正常发请求得arp,如果短时间收到大量同一源得arp怀疑是否存在攻击
粉丝:4人 关注:3人
您好,是不是上行端口配置有问题,或者线缆接错有异常。
