通常交换机和防火墙单口连接的时候,交换机端口这端划access的vlan,防火墙端口设置同网段的IP就可以,现在要做链路聚合两端应该如何设置
(0)
你好,正常做三层聚合和二层聚合即可,静态的二层聚合三层聚合是正常跑起来的:
聚合配置参考链接:
https://www.h3c.com/cn/d_202004/1284821_30005_0.htm#_Toc37772090
(0)
交换机配置
version 7.1.075, Alpha 7571
sysname hx-1
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 10
irf member 2 priority 1
dhcp enable
lldp global enable
system-working-mode standard
xbar load-single
password-recovery enable
lpu-type f-series
vlan 1
vlan 10
vlan 20
vlan 253 to 254
irf-port 1/2
port group interface Ten-GigabitEthernet1/0/49
port group interface Ten-GigabitEthernet1/0/50
irf-port 2/1
port group interface Ten-GigabitEthernet2/0/49
port group interface Ten-GigabitEthernet2/0/50
stp global enable
interface Bridge-Aggregation10
port link-type trunk
port trunk permit vlan all
interface Bridge-Aggregation11
interface Bridge-Aggregation12
port access vlan 254
interface NULL0
interface Vlan-interface10
ip address 192.168.10.1 255.255.255.0
dhcp select relay
dhcp relay server-address 192.168.254.254
interface Vlan-interface20
ip address 192.168.20.1 255.255.255.0
dhcp select relay
interface Vlan-interface253
mad bfd enable
mad ip address 192.168.253.1 255.255.255.0 member 1
mad ip address 192.168.253.2 255.255.255.0 member 2
interface Vlan-interface254
ip address 192.168.254.1 255.255.255.0
interface FortyGigE1/0/53
port link-mode bridge
interface FortyGigE1/0/54
interface FortyGigE2/0/53
interface FortyGigE2/0/54
combo enable fiber
combo enable fiber
combo enable fiber
interface GigabitEthernet1/0/4
combo enable fiber
interface GigabitEthernet1/0/5
combo enable fiber
interface GigabitEthernet1/0/6
combo enable fiber
interface GigabitEthernet1/0/7
combo enable fiber
interface GigabitEthernet1/0/8
combo enable fiber
interface GigabitEthernet1/0/9
combo enable fiber
interface GigabitEthernet1/0/10
combo enable fiber
interface GigabitEthernet1/0/11
combo enable fiber
interface GigabitEthernet1/0/12
combo enable fiber
interface GigabitEthernet1/0/13
combo enable fiber
interface GigabitEthernet1/0/14
combo enable fiber
interface GigabitEthernet1/0/15
combo enable fiber
interface GigabitEthernet1/0/16
combo enable fiber
interface GigabitEthernet1/0/17
combo enable fiber
interface GigabitEthernet1/0/18
combo enable fiber
interface GigabitEthernet1/0/19
combo enable fiber
interface GigabitEthernet1/0/20
combo enable fiber
interface GigabitEthernet1/0/21
combo enable fiber
interface GigabitEthernet1/0/22
combo enable fiber
interface GigabitEthernet1/0/23
combo enable fiber
interface GigabitEthernet1/0/24
combo enable fiber
interface GigabitEthernet1/0/25
combo enable fiber
interface GigabitEthernet1/0/26
combo enable fiber
interface GigabitEthernet1/0/27
combo enable fiber
interface GigabitEthernet1/0/28
combo enable fiber
interface GigabitEthernet1/0/29
combo enable fiber
interface GigabitEthernet1/0/30
combo enable fiber
interface GigabitEthernet1/0/31
combo enable fiber
interface GigabitEthernet1/0/32
combo enable fiber
interface GigabitEthernet1/0/33
combo enable fiber
interface GigabitEthernet1/0/34
combo enable fiber
interface GigabitEthernet1/0/35
combo enable fiber
interface GigabitEthernet1/0/36
combo enable fiber
interface GigabitEthernet1/0/37
combo enable fiber
interface GigabitEthernet1/0/38
combo enable fiber
interface GigabitEthernet1/0/39
combo enable fiber
interface GigabitEthernet1/0/40
combo enable fiber
interface GigabitEthernet1/0/41
combo enable fiber
interface GigabitEthernet1/0/42
combo enable fiber
interface GigabitEthernet1/0/43
combo enable fiber
interface GigabitEthernet1/0/44
combo enable fiber
interface GigabitEthernet1/0/45
combo enable fiber
interface GigabitEthernet1/0/46
combo enable fiber
interface GigabitEthernet1/0/47
combo enable fiber
port link-aggregation group 10
interface GigabitEthernet1/0/48
combo enable fiber
port link-aggregation group 11
interface GigabitEthernet2/0/1
combo enable fiber
interface GigabitEthernet2/0/2
combo enable fiber
interface GigabitEthernet2/0/3
combo enable fiber
interface GigabitEthernet2/0/4
combo enable fiber
interface GigabitEthernet2/0/5
combo enable fiber
interface GigabitEthernet2/0/6
combo enable fiber
interface GigabitEthernet2/0/7
combo enable fiber
interface GigabitEthernet2/0/8
combo enable fiber
interface GigabitEthernet2/0/9
combo enable fiber
interface GigabitEthernet2/0/10
combo enable fiber
interface GigabitEthernet2/0/11
combo enable fiber
interface GigabitEthernet2/0/12
combo enable fiber
interface GigabitEthernet2/0/13
combo enable fiber
interface GigabitEthernet2/0/14
combo enable fiber
interface GigabitEthernet2/0/15
combo enable fiber
interface GigabitEthernet2/0/16
combo enable fiber
interface GigabitEthernet2/0/17
combo enable fiber
interface GigabitEthernet2/0/18
combo enable fiber
interface GigabitEthernet2/0/19
combo enable fiber
interface GigabitEthernet2/0/20
combo enable fiber
interface GigabitEthernet2/0/21
combo enable fiber
interface GigabitEthernet2/0/22
combo enable fiber
interface GigabitEthernet2/0/23
combo enable fiber
interface GigabitEthernet2/0/24
combo enable fiber
interface GigabitEthernet2/0/25
combo enable fiber
interface GigabitEthernet2/0/26
combo enable fiber
interface GigabitEthernet2/0/27
combo enable fiber
interface GigabitEthernet2/0/28
combo enable fiber
interface GigabitEthernet2/0/29
combo enable fiber
interface GigabitEthernet2/0/30
combo enable fiber
interface GigabitEthernet2/0/31
combo enable fiber
interface GigabitEthernet2/0/32
combo enable fiber
interface GigabitEthernet2/0/33
combo enable fiber
interface GigabitEthernet2/0/34
combo enable fiber
interface GigabitEthernet2/0/35
combo enable fiber
interface GigabitEthernet2/0/36
combo enable fiber
interface GigabitEthernet2/0/37
combo enable fiber
interface GigabitEthernet2/0/38
combo enable fiber
interface GigabitEthernet2/0/39
combo enable fiber
interface GigabitEthernet2/0/40
combo enable fiber
interface GigabitEthernet2/0/41
combo enable fiber
interface GigabitEthernet2/0/42
combo enable fiber
interface GigabitEthernet2/0/43
combo enable fiber
interface GigabitEthernet2/0/44
combo enable fiber
interface GigabitEthernet2/0/45
combo enable fiber
interface GigabitEthernet2/0/46
combo enable fiber
interface GigabitEthernet2/0/47
combo enable fiber
interface GigabitEthernet2/0/48
combo enable fiber
interface M-GigabitEthernet0/0/0
interface Ten-GigabitEthernet1/0/51
port access vlan 253
combo enable fiber
undo stp enable
interface Ten-GigabitEthernet1/0/52
combo enable fiber
port link-aggregation group 12
interface Ten-GigabitEthernet2/0/51
combo enable fiber
undo stp enable
interface Ten-GigabitEthernet2/0/52
combo enable fiber
combo enable fiber
combo enable fiber
combo enable fiber
combo enable fiber
scheduler logfile size 16
line class aux
user-role network-operator
line class console
user-role network-admin
line class tty
line class vty
line aux 0 1
line con 0 1
line vty 0 63
radius scheme system
user-name-format without-domain
domain name system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
return
(0)
# version 7.1.064, Alpha 7164 # sysname firewall # context Admin id 1 # telnet server enable # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1 # dhcp enable dhcp server forbidden-ip 192.168.10.240 192.168.10.254 dhcp server forbidden-ip 192.168.20.240 192.168.20.254 # xbar load-single password-recovery enable lpu-type f-series # vlan 1 # dhcp server ip-pool vlan10 gateway-list 192.168.10.1 network 192.168.10.0 mask 255.255.255.0 dns-list 114.114.114.114 # dhcp server ip-pool vlan20 gateway-list 192.168.20.1 network 192.168.20.0 mask 255.255.255.0 dns-list 114.114.114.114 # interface Route-Aggregation12 ip address 192.168.254.254 255.255.255.0 # interface NULL0 # interface GigabitEthernet1/0/0 port link-mode route combo enable copper # interface GigabitEthernet1/0/1 port link-mode route combo enable copper ip address 192.168.0.1 255.255.255.0 # interface GigabitEthernet1/0/2 port link-mode route combo enable copper # interface GigabitEthernet1/0/3 port link-mode route combo enable copper # interface GigabitEthernet1/0/4 port link-mode route combo enable copper # interface GigabitEthernet1/0/5 port link-mode route combo enable copper # interface GigabitEthernet1/0/6 port link-mode route combo enable copper # interface GigabitEthernet1/0/7 port link-mode route combo enable copper # interface GigabitEthernet1/0/8 port link-mode route combo enable copper # interface GigabitEthernet1/0/9 port link-mode route combo enable copper # interface GigabitEthernet1/0/10 port link-mode route combo enable copper # interface GigabitEthernet1/0/11 port link-mode route combo enable copper # interface GigabitEthernet1/0/12 port link-mode route combo enable copper # interface GigabitEthernet1/0/13 port link-mode route combo enable copper # interface GigabitEthernet1/0/14 port link-mode route combo enable copper # interface GigabitEthernet1/0/15 port link-mode route combo enable copper # interface GigabitEthernet1/0/16 port link-mode route combo enable copper # interface GigabitEthernet1/0/17 port link-mode route combo enable copper # interface GigabitEthernet1/0/18 port link-mode route combo enable copper # interface GigabitEthernet1/0/19 port link-mode route combo enable copper # interface GigabitEthernet1/0/20 port link-mode route combo enable copper # interface GigabitEthernet1/0/21 port link-mode route combo enable copper # interface GigabitEthernet1/0/22 port link-mode route combo enable copper port link-aggregation group 12 # interface GigabitEthernet1/0/23 port link-mode route combo enable copper port link-aggregation group 12 # security-zone name Local # security-zone name Trust import interface GigabitEthernet1/0/22 import interface GigabitEthernet1/0/23 # security-zone name DMZ # security-zone name Untrust # security-zone name Management # zone-pair security source Local destination Trust packet-filter 3000 # zone-pair security source Trust destination Local packet-filter 3000 # scheduler logfile size 16 # line class aux user-role network-operator # line class console user-role network-admin # line class tty user-role network-operator # line class vty user-role network-operator # line aux 0 user-role network-admin # line con 0 authentication-mode scheme user-role network-admin # line vty 0 4 authentication-mode scheme user-role network-admin # line vty 5 63 user-role network-operator # ip route-static 192.168.10.0 24 192.168.254.1 ip route-static 192.168.20.0 24 192.168.254.1 # acl advanced 3000 rule 0 permit ip # domain system # aaa session-limit ftp 16 aaa session-limit telnet 16 aaa session-limit ssh 16 domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ== service-type telnet terminal http authorization-attribute user-role level-3 authorization-attribute user-role network-admin authorization-attribute user-role network-operator # ip http enable ip https enable # return
防火墙配
就正常配置聚合然后把地址配置在三层聚合口或者vlan-if接口上即可。
另外要主要下由于V7平台默认拒绝所有业务流,因此要放通策略否则可能严重结果或测试业务不正常。
另外如果不熟悉命令或者操作方式请参考配置手册
防火墙
交换机
H3C S5830V2[S5820V2]系列以太网交换机 配置指导-Release 243x-6W100_配置指导导读-新华三集团-H3C
(0)
防火墙:
sys |
int Route-Aggregation 1 |
int range g1/0/22 to g1/0/23 |
port link-aggregation group 1 |
int Route-Aggregation1 |
ip add 192.168.1.1 24 |
security-zone name Trust |
import int g1/0/22 |
import int g1/0/23 |
acl advanced 3000 |
rule 0 permit ip |
zone-pair security source Trust destination Local |
packet-filter 3000 |
zone-pair security source Local destination Trust |
sa f |
交换机 (假设已经做了IRF)
sys |
vlan 2 |
int vlan 2 |
ip add 192.168.1.2 24 |
int Bridge-Aggregation 1 |
int g1/0/52 |
int g2/0/52 |
port link-type access |
port access vlan 2 |
sa f |
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
