交换机板卡
2021-05-09提问
  • 1收藏,258浏览
61990 二段
S7003E 插了一块48口光板报错如下:板卡型号为LSQM2GP48SA0
mages. %May 9 15:52:58:849 2021 H3C DRVPLAT/2/DrvDebug: Warning: The LPU board on slot 1 is not compatible with MPU board, its board type is 106.7. %May 9 15:53:17:875 2021 H3C DEV/4/BOARD_LOADING: Board in slot 1 is loading software images. %May 9 15:53:59:349 2021 H3C DEV/5/LOAD_FINISHED: Board in slot 1 has finished loading software images. %May 9 15:54:23:966 2021 H3C DRVPLAT/2/DrvDebug: Warning: The LPU board on slot 1 is not compatible with MPU board, its board type is 106.7. %May 9 15:54:43:001 2021 H3C DEV/4/BOARD_LOADING: Board in slot 1 is loading software images. %May 9 15:55:24:478 2021 H3C DEV/5/LOAD_FINISHED: Board in slot 1 has finished loading software images.
S7003E 是分销型号,配置的板卡应该是 LSQM2GP48SA8   , LSQM2GP48SA0这个板卡是配在行业型号的交换机上的,板卡和交换机不匹配
粉丝:3人 关注:0人
查看S7003E版本说明,没有宣称支持添加板卡型号为LSQM2GP48SA0
粉丝: 关注:
需确认下安装的板卡是否适配这个型号的交换机。建议查看下软件版本说明书。
