多wan的网关(全是三层,没有二层网口)如何让多网口都可以自动获取ipv6地址?
2021-05-21提问
  • 1收藏,1310浏览
路由器是多wan的,全是三层,没有二层网口。
GE0、GE1、GE3 都是三层网口,GE0和GE1连接交换机,GE3连接光猫(光猫桥接模式),并PPPOE拨号。配置后,现在可以实现 GE0 成功获得联通宽带分配的ipv6地址,如何让 GE0、GE1和GE2等 都可以获得?
之前就是创建ipv6 地址池(本例名字是ge0ipv6)和前缀池(本例是1),通过 ipv6 dhcp client pd 1 rapid-commit option-group 1 把信息填充到池里面,但是我发现GE0用了这个池之后,GE1就无法再使用了。
  2. dhcp server ip-pool ge0
  3. gateway-list 10.28.0.1
  4. network 10.28.0.0 mask 255.255.255.0
  5. address range 10.28.0.101 10.28.0.200
  6. dns-list 10.28.0.1
  7. forbidden-ip-range 10.28.0.1 10.28.0.1
  8. static-bind ip-address 10.28.0.11 mask 255.255.255.0 hardware-address 085b-d6f4-8076 description ShenLiyang
  9. #
  10. dhcp server ip-pool ge1
  11. gateway-list 10.28.1.1
  12. network 10.28.1.0 mask 255.255.255.0
  13. address range 10.28.1.101 10.28.1.200
  14. dns-list 10.28.1.1
  15. forbidden-ip-range 10.28.1.1 10.28.1.1
  16. #
  17. ipv6 dhcp pool ge0ipv6
  18. option-group 1
  19. #
  20. controller Cellular0/0
  21. #
  22. interface Dialer3
  23. mtu 1492
  24. ppp chap password cipher $c$3$vGSdC5n8D1UDzqQNjCfKsdO3pSAgQ/48Aw==
  25. ppp chap user SL10012046@E
  26. ppp ipcp dns admit-any
  27. ppp ipcp dns request
  28. ppp pap local-user SL10012046@E password cipher $c$3$Rz99HEepvjJX4eNVVbYVTGAa/ZEkzzBBfg==
  29. dialer bundle enable
  30. dialer-group 4
  31. dialer timer idle 0
  32. dialer timer autodial 5
  33. ip address ppp-negotiate
  34. tcp mss 1280
  35. nat outbound
  36. ipv6 address auto link-local
  37. ipv6 address dhcp-alloc
  38. ipv6 dhcp client pd 1 rapid-commit option-group 1
  39. #
  40. interface NULL0
  41. #
  42. interface GigabitEthernet0/0
  43. port link-mode route
  44. description LAN-interface
  45. ip address 10.28.0.1 255.255.255.0
  46. tcp mss 1280
  47. ipv6 dhcp select server
  48. ipv6 dhcp server apply pool ge0ipv6
  49. ipv6 address 1 1::1/64
  50. ipv6 nd autoconfig other-flag
  51. undo ipv6 nd ra halt
  52. #
  53. interface GigabitEthernet0/1
  54. port link-mode route
  55. description LAN-interface
  56. ip address 10.28.1.1 255.255.255.0
  57. tcp mss 1280
  58. #
  59. interface GigabitEthernet0/2
  60. port link-mode route
  61. combo enable copper
  62. #
  63. interface GigabitEthernet0/3
  64. port link-mode route
  65. description Single_Line1
  66. combo enable copper
  67. pppoe-client dial-bundle-number 3
  68. #
  69. interface GigabitEthernet0/4
  70. port link-mode route
  71. #
  72. interface GigabitEthernet0/5
  73. port link-mode route
  74. #
粉丝:5人 关注:0人
只能一个口,不支持多个口,有多个PPPOE可以使用同样的方式获取
