现有华为防火墙E200S。下挂服务器,做端口映射。在公网上面可以访问映射出去的地址。http://222.189.212.198:8081/eGovaMIS/login.htm。
还有一台F5020,F5020下的pc均不能访问映射出的地址。
华为防火墙地址:222.189.212.194 默认路由到222.189.212.193
F5020:地址58.220.219.194 默认路由到58.220.219.193
华为上面做了端口映射,吧服务器的映射到公网。目前通过手机流量和酒店网络都可以正常访问http://222.189.212.198:8081/eGovaMIS/login.htm
但是在F5020下面的终端,可以正常上网,却不能访问华为防火墙映射出的地址。改地址不可ping,但可以个telnet登录
具体配置如下。望大神可以解决
F5020 :
[chukou-FW]dis cu
version 7.1.064, Release 9310P12
sysname chukou-FW
context Admin id 1
ip vpn-instance management
route-distinguisher 1000000000:1
vpn-target 1000000000:1 import-extcommunity
vpn-target 1000000000:1 export-extcommunity
telnet server enable
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 10
irf member 2 priority 1
ip pool l2tp 10.155.222.1 10.155.223.254
nat address-group 1
address 58.220.219.194 58.220.219.194
password-recovery enable
vlan 1
vlan 10
vlan 4001
irf-port 1/1
port group interface Ten-GigabitEthernet1/0/26
port group interface Ten-GigabitEthernet1/0/27
irf-port 2/2
port group interface Ten-GigabitEthernet2/0/26
port group interface Ten-GigabitEthernet2/0/27
object-group ip address myip
0 network host address 10.155.245.136
10 network host address 58.220.219.194
object-group service mysvr
0 service tcp destination eq 3389
10 service tcp destination eq 5901
20 service tcp destination eq 22
30 service tcp destination eq 8080
40 service tcp destination eq 8443
50 service udp destination eq 1701
60 service tcp destination eq 5900
interface Reth1
description to_zhenwuwaiwang_s105
ip address 10.155.253.254 255.255.255.252
member interface Ten-GigabitEthernet1/0/24 priority 255
member interface Ten-GigabitEthernet2/0/24 priority 50
packet-filter 2500 inbound
interface Reth2
description TO_S9810_hulian
ip address 10.155.241.254 255.255.255.252
member interface Ten-GigabitEthernet1/0/25 priority 255
member interface Ten-GigabitEthernet2/0/25 priority 50
interface Bridge-Aggregation1
port access vlan 10
link-aggregation mode dynamic
interface Bridge-Aggregation2
description waiwangjinxian
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 4001
interface Virtual-Template1
ppp authentication-mode chap
remote address pool l2tp
ip address 10.155.223.254 255.255.254.0
interface NULL0
interface Vlan-interface10
interface Vlan-interface4001
ip address 58.220.219.194 255.255.255.192
nat outbound 2000 address-group 1
nat server protocol tcp global 58.220.219.200 122 inside 10.155.245.132 22
nat server protocol tcp global 58.220.219.200 5901 inside 10.155.245.1 5901
nat server protocol tcp global 58.220.219.201 8443 inside 10.155.245.200 3389
nat server protocol tcp global current-interface 4422 inside 10.155.253.253 22
nat server protocol tcp global current-interface 5002 inside 10.155.245.1 8443
nat server protocol tcp global current-interface 5003 inside 10.155.245.129 3389
ipsec apply policy 1
interface GigabitEthernet1/0/0
port link-mode route
ip binding vpn-instance management
ip address 192.168.0.1 255.255.255.0
ip address 10.155.242.1 255.255.255.128
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet2/0/0
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
port link-mode bridge
port link-aggregation group 1
interface GigabitEthernet1/0/12
speed 1000
duplex full
port link-aggregation group 2
interface GigabitEthernet1/0/13
speed 1000
duplex full
interface GigabitEthernet1/0/14
speed 1000
duplex full
interface GigabitEthernet1/0/15
packet-filter 3000 inbound
object-policy ip Local-Untrust
rule 0 pass source-ip myip counting
object-policy ip all.pass
rule 0 pass counting
object-policy ip mypolicy
rule 0 pass service mysvr counting
rule 1 pass destination-ip myip counting
security-zone name Local
security-zone name Trust
import interface GigabitEthernet1/0/3
import interface Reth1
import interface Virtual-Template1
security-zone name DMZ
import interface Reth2
security-zone name Untrust
import interface Vlan-interface4001
import interface Bridge-Aggregation2 vlan 4001
import interface GigabitEthernet1/0/12 vlan 4001
import interface GigabitEthernet1/0/13 vlan 4001
import interface GigabitEthernet1/0/14 vlan 4001
security-zone name Management
import interface GigabitEthernet1/0/0
zone-pair security source Any destination Any
object-policy apply ip all.pass
zone-pair security source DMZ destination Trust
zone-pair security source Local destination Trust
zone-pair security source Local destination Untrust
object-policy apply ip Local-Untrust
zone-pair security source Trust destination Trust
zone-pair security source Untrust destination Local
object-policy apply ip mypolicy
zone-pair security source Untrust destination Trust
scheduler logfile size 16
line class console
user-role network-admin
line class vty
user-role network-operator
line con 0 1
authentication-mode scheme
line vty 0 4
user-role level-15
protocol inbound telnet
line vty 5 63
ip route-static 0.0.0.0 0 58.220.219.193
ip route-static 10.155.0.0 16 10.155.253.253
ip route-static 10.155.241.0 24 10.155.241.253
ip route-static 10.155.242.0 23 10.155.241.253
ip route-static 10.155.244.0 24 10.155.241.253
ip route-static 32.0.0.0 8 10.155.253.253
ip route-static 59.192.0.0 10 10.155.253.253
ip route-static 100.64.0.0 10 10.155.253.253
ip route-static 172.21.0.0 17 10.155.253.253
ip route-static 172.23.0.0 16 10.155.253.253
ip route-static 172.24.0.0 16 10.155.253.253
ip route-static 222.189.0.0 16 58.220.219.193
info-center loghost 10.155.245.129
snmp-agent
snmp-agent local-engineid 800063A2809C061BFC3E9200000001
snmp-agent community write Admin@2017.yz
snmp-agent community read Admin@2017.yzzww
snmp-agent community read yizheng
snmp-agent community write yzzww
snmp-agent sys-info version all
snmp-agent target-host trap address udp-domain 10.155.245.129 params securityname Admin@2017.yz
snmp-agent target-host trap address udp-domain 10.155.245.129 params securityname jscegn@yc
snmp-agent target-host trap address udp-domain 10.155.245.129 params securityname yizheng v2c
snmp-agent trap enable arp
snmp-agent trap enable radius
snmp-agent trap enable syslog
snmp-agent trap queue-size 500
snmp-agent trap life 600
ssh server enable
redundancy group aaa
member interface Reth1
member interface Reth2
node 1
bind slot 1
priority 100
track 1 interface Ten-GigabitEthernet1/0/24
track 3 interface Ten-GigabitEthernet1/0/25
node 2
bind slot 2
priority 50
track 2 interface Ten-GigabitEthernet2/0/24
track 4 interface Ten-GigabitEthernet2/0/25
acl basic 2000
rule 0 permit source 10.155.2.0 0.0.0.255
rule 5 permit source 10.155.222.0 0.0.1.255
rule 10 permit
acl basic 2500
rule 0 permit source 10.155.222.0 0.0.1.255
radius session-control enable
radius scheme l2tp
primary authentication 10.155.245.129
primary accounting 10.155.245.129
key authentication cipher $c$3$Ch8qoRL/xO4+0HkmONp0OkJDdJ8BY2mj
key accounting cipher $c$3$/a5gXRupGQYi8CwNyGhrHooHQIjo7T6B
user-name-format without-domain
nas-ip 10.155.253.254
domain l2tp
authentication portal radius-scheme l2tp
authorization portal radius-scheme l2tp
accounting portal radius-scheme l2tp
domain system
authentication ppp radius-scheme l2tp
authorization ppp radius-scheme l2tp
accounting ppp radius-scheme l2tp
aaa session-limit ftp 16
aaa session-limit telnet 16
aaa session-limit ssh 16
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$pKuRW2tehlA/EIWa$l/fHQ9bdhTNBEih59RC5pOVGwc06UqEyFxWguMDSzp6bgjTwSj+fgtqJzFwVwMVUkjYtGlNx3slJmNtCKnmlXw==
service-type ssh telnet terminal https
authorization-attribute user-role level-3
authorization-attribute user-role level-15
local-user h3c class manage
password hash $h$6$jLOMRMQpGDbBPmjq$Ub4NR+5jh3kVoMB07c5XdnqXdyOnKRTAb16XXEe7KMPgWrDWdCovlputGEB6oL3k9yhhnLL+27mpxYMtMAOnyA==
service-type telnet https
local-user zp class manage
password hash $h$6$ppXWGvgDjlbDxTWu$0Bdbzx+hNYvTGGy9jZB7pg/KFlfIraHrJdXjZfEdR9rHXcA3/8/+SJe5h8tK+QOBwOm5/i6pxDOa53LBsYfIIw==
service-type telnet http https
local-user ? class manage
local-user admi class network
local-user admin class network
password cipher $c$3$Hq7PSbHzKtZjhFVCy7T2KXPGRXw0IVbR
service-type ppp
local-user tk class network
password cipher $c$3$bkAuol9t9z5Plc87jJqRp7X42SxcaGhepOo9
service-type ppp
ssl server-policy king
session statistics enable
session synchronization enable
ipsec transform-set l2tp
esp encryption-algorithm 3des-cbc
esp authentication-algorithm sha1
ipsec policy-template l2tp 10
transform-set l2tp
ike-profile l2tp
ipsec policy 1 10 isakmp template l2tp
l2tp-group 1 mode lns
allow l2tp virtual-template 1 remote LAC
undo tunnel authentication
tunnel name LNS
l2tp enable
ike identity fqdn lns
ike profile l2tp
keychain l2tp
exchange-mode aggressive
local-identity fqdn lns
match remote identity fqdn l2tp
proposal 1
ike proposal 1
ike keychain l2tp
pre-shared-key hostname l2tp key cipher $c$3$HpDpx95Gi8AcwZDS+8+JKcmgi3GGKCfX2kWc
ip http enable
ip https enable
inspect block-source parameter-profile ips_block_default_parameter
inspect capture parameter-profile ips_capture_default_parameter
inspect logging parameter-profile ips_logging_default_parameter
inspect redirect parameter-profile av_redirect_default_parameter
inspect redirect parameter-profile ips_redirect_default_parameter
inspect redirect parameter-profile url_redirect_default_parameter
ips policy default
anti-virus policy default
track 1 interface Ten-GigabitEthernet1/0/24 physical
track 2 interface Ten-GigabitEthernet2/0/24 physical
track 3 interface Ten-GigabitEthernet1/0/25 physical
track 4 interface Ten-GigabitEthernet2/0/25 physical
return
Quidway E200S
<Eudemon> dis cu
sysname Eudemon
super password level 3 simple 123456
web-manager enable
l2tp enable
firewall packet-filter default permit interzone trust untrust direction inbound
firewall packet-filter default permit interzone trust untrust direction outbound
nat address-group 1 222.189.212.195 222.189.212.207
nat server protocol tcp global 222.189.212.195 3389 inside 192.168.2.100 3389
nat server protocol tcp global 222.189.212.200 www inside 192.168.2.101 www
nat server protocol tcp global 222.189.212.200 3389 inside 192.168.2.101 3389
nat server protocol tcp global 222.189.212.201 3389 inside 192.168.2.102 3389
nat server protocol tcp global 222.189.212.202 3389 inside 172.16.88.102 3389
nat server protocol tcp global 222.189.212.195 www inside 192.168.2.100 www
nat server protocol tcp global 222.189.212.195 7080 inside 192.168.2.100 7080
nat server protocol tcp global 222.189.212.195 8600 inside 192.168.2.100 8600
nat server protocol tcp global 222.189.212.200 2000 inside 192.168.2.101 2000
nat server global 222.189.212.196 inside 192.168.2.50
nat server protocol tcp global 222.189.212.195 2000 inside 192.168.2.100 2000
nat server protocol tcp global 222.189.212.197 3389 inside 192.168.2.105 3389
nat server protocol tcp global 222.189.212.197 www inside 192.168.2.105 www
nat server protocol tcp global 222.189.212.201 www inside 192.168.2.102 www
nat server protocol tcp global 222.189.212.198 3389 inside 192.168.2.20 3389
nat server protocol tcp global 222.189.212.198 www inside 192.168.2.20 www
nat server protocol tcp global 222.189.212.199 www inside 192.168.2.21 www
nat server protocol tcp global 222.189.212.199 3389 inside 192.168.2.21 3389
nat server protocol tcp global 222.189.212.198 8081 inside 192.168.2.20 8081
nat server protocol tcp global 222.189.212.198 8082 inside 192.168.2.20 8082
nat server protocol tcp global 222.189.212.198 8083 inside 192.168.2.20 8083
nat server protocol tcp global 222.189.212.198 8084 inside 192.168.2.20 8084
nat server protocol tcp global 222.189.212.198 8085 inside 192.168.2.20 8085
nat server protocol tcp global 222.189.212.198 8181 inside 192.168.2.20 8181
nat server protocol tcp global 222.189.212.198 telnet inside 192.168.2.20 telnet
nat server protocol tcp global 222.189.212.199 8399 inside 192.168.2.21 8399
nat server protocol tcp global 222.189.212.199 8081 inside 192.168.2.21 8081
nat server protocol tcp global 222.189.212.199 8082 inside 192.168.2.21 8082
nat server protocol tcp global 222.189.212.199 8083 inside 192.168.2.21 8083
nat server protocol tcp global 222.189.212.199 8084 inside 192.168.2.21 8084
nat server protocol tcp global 222.189.212.199 8085 inside 192.168.2.21 8085
nat server protocol tcp global 222.189.212.199 8181 inside 192.168.2.21 8181
nat alg enable ftp
nat alg enable dns
nat alg enable icmp
nat alg enable netbios
undo nat alg enable h323
undo nat alg enable hwcc
undo nat alg enable ils
undo nat alg enable pptp
undo nat alg enable qq
undo nat alg enable msn
undo nat alg enable user-define
undo nat alg enable sip
undo nat alg enable rtsp
firewall permit sub-ip
firewall blacklist enable
firewall blacklist item 187.58.63.5
firewall blacklist item 59.175.193.82
firewall defend ip-spoofing enable
firewall defend land enable
firewall defend smurf enable
firewall defend fraggle enable
firewall defend winnuke enable
firewall defend syn-flood enable
firewall defend udp-flood enable
firewall defend icmp-flood enable
firewall defend icmp-redirect enable
firewall defend icmp-unreachable enable
firewall defend ip-sweep enable
firewall defend port-scan enable
firewall defend source-route enable
firewall defend route-record enable
firewall defend tracert enable
firewall defend time-stamp enable
firewall defend ping-of-death enable
firewall defend teardrop enable
firewall defend tcp-flag enable
firewall defend ip-fragment enable
firewall defend large-icmp enable
firewall statistic system enable
interface Aux0
async mode flow
link-protocol ppp
interface Ethernet0/0/0
ip address 222.189.212.194 255.255.255.240
interface Ethernet0/0/1
ip address 192.168.2.1 255.255.255.0
ip address 172.16.88.1 255.255.255.0 sub
interface Ethernet0/0/2
interface Ethernet0/0/3
interface Ethernet0/0/4
ip address 172.16.87.1 255.255.255.0
remote address pool 1
interface Tunnel1
interface Secp0/0/0
interface NULL0
acl number 2012
rule 0 permit source 192.168.0.0 0.0.255.255
rule 1 permit source 172.16.88.0 0.0.0.255
acl number 2101
rule 0 permit source 192.168.2.0 0.0.0.255
acl number 3101
rule 1 permit tcp source 192.168.2.0 0.0.0.255 destination 202.102.112.14 0
rule 2 permit tcp source 172.16.88.0 0.0.0.255 destination 202.102.112.14 0
rule 5 permit ip source 192.168.2.101 0
acl number 3102
rule 0 permit tcp source 218.91.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 1 permit tcp source 221.229.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 2 permit tcp source 61.177.184.0 0.0.0.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 3 permit tcp source 58.220.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 4 permit tcp source 117.61.84.0 0.0.0.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 5 permit tcp source 117.61.87.0 0.0.0.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 6 permit tcp source 222.189.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 7 permit tcp source 121.233.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 8 permit tcp destination 192.168.2.100 0 destination-port eq 7080
rule 9 permit tcp destination 192.168.2.100 0 destination-port eq 8600
rule 10 permit tcp source 218.91.0.0 0.0.255.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 11 permit tcp source 221.229.0.0 0.0.255.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 12 permit tcp source 61.177.184.0 0.0.0.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 13 permit tcp source 58.220.0.0 0.0.255.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 14 permit tcp source 117.61.84.0 0.0.0.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 15 permit tcp source 117.61.87.0 0.0.0.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 16 permit tcp source 222.189.0.0 0.0.255.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 17 permit tcp source 121.233.0.0 0.0.255.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 18 permit tcp source 180.0.0.0 0.255.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 19 permit tcp source 180.0.0.0 0.255.255.255 destination 172.16.88.0 0.0.0.255 destination-port eq www
rule 20 permit tcp source 211.103.30.165 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 22 permit tcp destination 192.168.2.0 0.0.0.255 destination-port eq 3389
rule 24 permit tcp source 122.195.136.168 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 25 permit tcp source 121.229.89.213 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 26 permit tcp source 221.6.166.2 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 27 permit tcp source 198.17.120.227 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 29 permit tcp source 61.177.181.138 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 30 permit tcp source 221.130.68.99 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 31 permit tcp source 61.177.181.2 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 32 permit tcp source 58.220.231.2 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 33 permit tcp source 121.229.89.0 0.0.0.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 34 permit tcp source 202.102.23.0 0.0.0.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 35 permit tcp source 211.103.38.0 0.0.0.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 36 permit tcp source 114.230.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 39 permit tcp source 117.91.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 40 permit tcp source 58.241.129.90 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 41 permit tcp source 211.103.35.35 0 destination 192.168.2.0 0.0.0.255 destination-port eq www
rule 42 permit tcp source 61.132.36.18 0 destination 192.168.2.50 0 destination-port eq 3306
rule 43 permit tcp source 61.147.75.148 0 destination 192.168.2.50 0 destination-port eq 3306
rule 45 permit tcp source 122.194.0.0 0.0.255.255 destination 192.168.0.0 0.0.0.255 destination-port eq www
rule 46 permit tcp source 58.220.0.0 0.0.255.255 destination 192.168.0.0 0.0.0.255 destination-port eq www
rule 50 permit tcp source 58.220.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255
rule 52 permit tcp source 58.220.0.0 0.0.255.255 destination 192.168.0.0 0.0.255.255 destination-port eq www
rule 54 permit ip source 58.220.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255
rule 56 permit tcp source 58.220.0.0 0.0.255.255 destination 192.168.2.0 0.0.0.255 destination-port eq telnet
rule 100 permit ip source 202.102.112.14 0 destination 192.168.2.0 0.0.0.255
rule 101 permit ip source 202.102.112.14 0 destination 172.16.88.0 0.0.0.255
rule 102 permit ip source 61.147.75.143 0 destination 192.168.2.0 0.0.0.255
rule 200 permit ip destination 192.168.2.0 0.0.0.255
acl number 3103
rule 0 permit tcp source 202.102.112.14 0 destination 222.189.212.194 0
rule 1 permit udp destination 222.189.212.194 0 destination-port eq 1701
rule 3 permit tcp destination 222.189.212.194 0
acl number 3104
rule 0 permit tcp source 172.16.87.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
rule 1 permit tcp source 172.16.87.0 0.0.0.255 destination 172.16.88.0 0.0.0.255
firewall zone local
set priority 100
firewall zone trust
set priority 85
add interface Ethernet0/0/1
firewall zone untrust
set priority 5
add interface Ethernet0/0/0
firewall zone dmz
set priority 50
firewall zone name vpnzone
set priority 60
add interface Virtual-Template1
firewall interzone local trust
firewall interzone local untrust
packet-filter 3103 inbound
firewall interzone local dmz
firewall interzone local vpnzone
firewall interzone trust untrust
nat outbound 2101 address-group 1
detect ftp
detect http
firewall interzone trust dmz
firewall interzone trust vpnzone
packet-filter 3104 inbound
firewall interzone dmz untrust
firewall interzone vpnzone untrust
firewall interzone vpnzone dmz
l2tp-group 1
aaa
local-user vpn03 password simple jshxszcgvpn03
local-user vpn03 service-type ppp
local-user vpn04 password simple jshxszcgvpn04
local-user vpn04 service-type ppp
local-user awingsky password simple song-3332chaoqin
local-user awingsky service-type web
local-user awingsky level 3
local-user callcenter01 password simple callcenter01
local-user callcenter01 service-type ppp
local-user callcenter02 password simple callcenter01
local-user callcenter02 service-type ppp
local-user vpn05 password simple jshxszcgvpn05
local-user vpn05 service-type ppp
local-user admin password simple song-3332chaoqin
local-user admin service-type web telnet
local-user admin level 1
local-user vpn01 password simple jshxszcgvpn01
local-user vpn01 service-type ppp
local-user songchaoqin password simple song-3332chaoqin
local-user songchaoqin service-type web telnet ssh
local-user vpn06 password simple jshxszcgvpn06
local-user vpn06 service-type ppp
local-user vpn02 password simple jshxszcgvpn02
local-user vpn02 service-type ppp
local-user vpn07 password simple jshxszcgvpn07
local-user vpn07 service-type ppp
ip pool 1 172.16.87.50 172.16.87.254
authentication-scheme default
authentication-scheme login
authorization-scheme default
accounting-scheme default
domain default
ip route-static 0.0.0.0 0.0.0.0 222.189.212.193
ip route-static 58.220.0.0 255.255.0.0 222.189.212.193
ip route-static 58.220.0.0 255.255.0.0 58.220.219.193
user-interface con 0
user-interface aux 0
user-interface vty 0 4
authentication-mode aaa
user privilege level 1
return
(0)
公网能够正常访问,说明地址映射正常,F5020下的pc不能访问,还是要检查下防火墙域间策略的配置,pc能正常访问公网,应该是要能ping通222.189.212.194的。
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
但是我的F5020的域间策略是any-any全方通
