日志中出现这种告警是啥原因?网络中断了
2017-07-21提问
  • 1收藏,4645浏览
粉丝:19人 关注:2人
%Jul 17 00:15:15:795 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:15:31:298 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:15:40:776 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:15:56:277 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:16:05:838 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:16:33:837 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:16:34:035 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:16:49:617 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:17:02:199 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:17:24:197 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:17:27:476 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:17:42:978 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:17:49:356 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:18:04:957 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:18:08:236 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:18:36:338 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:18:42:716 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:18:58:217 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:19:04:596 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:19:20:197 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-GigabitEthernet3/0/1
%Jul 17 00:19:20:393 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is OSPF, nexthop address is 11.10.108.58, output interface is Vlan-interface12
%Jul 17 00:20:03:080 2017 YDPT-BJCP-YYQ-S7503E-01 RM/3/RMLOG: The default route has been changed or deleted, protocol is Static, nexthop address is 11.10.108.9, output interface is Ten-
知了小白
粉丝: 关注:
下一跳一直在变化,可以先检查下网络环境,做一下路径探测
恭喜你,凉席!
衡水老白干 发表时间:2017-07-21
墨峰 九段
粉丝:51人 关注:6人
翻译一下即可,网络震荡,下一跳存在问题。
端口没有UP/DOWN,怎么震荡呢、?
路由有震荡变化,非最优默认路由被删除导致的
墨峰 发表时间:2017-07-21
yangN 四段
缺省路由在改变,可能网络不稳定造成的
SRv6 五段
粉丝:4人 关注:2人
默认路由在从ospf学习到的下一跳为11.10.108.58的路由和静态路由之间来回切换,检查下网络状态
