怎么关闭NTP的日志输出-SR6608-V7:
设备有大量NTP的日志输出,影响看日志,怎么关闭?
%Jun 5 01:04:43:052 2018 ******* NTP/5/NTP_CLOCK_CHANGE: System clock changed from 01:04:38:181 06/05/2018 to 01:04:43:042 06/05/2018, the NTP server's IP address is
%Jun 5 01:04:52:057 2018
NTP/5/NTP_LEAP_CHANGE: System Leap Indicator changed from 3 to 0 after clock update.
%Jun 5 01:04:52:058 2018 ******* NTP/5/NTP_STRATUM_CHANGE: System stratum changed from 16 to 12 after clock update.
(0)
undo info-center source NTP logbuffer
配置这个试试
(1)
测试没有效果,谢谢
除非关闭NTP配置,否则没办法单独关闭NTP告警,建议不要配置多个NTP服务器,建议配置一个稳定的NTP服务器
(0)
谢谢,TAC给出方法了,今天做下测试,看有没有效果。
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
能生效吗?
