WA4320I ACN V7转V5升级BIN版本时出问题
2021-06-11提问
  • 1收藏,613浏览
请教各位:V7转V5升级BIN版本时在第二次更新BIN版本,Server IP Address      :自动打出了192.168.1.1,我网卡设置了192.168.0.1,所以在后面输入了192.168.0.1,Local IP Address       :自动打印192.168.1.253,我在后输入了192.168.0.19,更新不成功,请问要如何解决?谢谢! ==================================================== |Note:       '.' = Clear field.                                            | |            '-' = Go to previous field.                                   | |          Ctrl+D = Quit.                                                  | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name         :host                        :wa4300-fat.bin Target File Name       :target                        :wa4300-fat.bin Server IP Address      :192.168.1.1 192.168.0.1 Local IP Address       :192.168.1.253 192.168.0.19 Gateway IP Address     :0.0.0.0  BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fit.bin! The main application file does not exist--flash:/wa4300_fit.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin!
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.Compiled Date : Feb 27 2019CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : DDR2 SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to access EXTENDED-BOOTWARE MENU...Password recovery capability is enabled.Note: The current operating device is flashEnter < Storage Device Operation > to select device.====================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Skip Authentication for Console Login ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENUCtrl+F: Format File SystemCtrl+C: Display CopyrightEnter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y...................................................................................................Format success.====================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Skip Authentication for Console Login ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENUCtrl+F: Format File SystemCtrl+C: Display CopyrightEnter your choice(0-9): 3====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 5====================================================|Note: '.' = Clear field. || '-' = Go to previous field. || Ctrl+D = Quit. |============================================================================Protocol (FTP or TFTP) :tftp Load File Name :wa4300-fat.bin :Target File Name :wa4300-fat.bin :Server IP Address :192.168.0.1 Local IP Address :192.168.0.19 Subnet Mask :255.255.255.0 Gateway IP Address :0.0.0.0 ====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 1Loading...Failed!====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 1Loading...Failed!====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 0====================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Skip Authentication for Console Login ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENUCtrl+F: Format File SystemCtrl+C: Display CopyrightEnter your choice(0-9): System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing.......................................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 7.13 ** *****************************************************************************Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.Compiled Date : Feb 27 2019CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : DDR2 SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to access EXTENDED-BOOTWARE MENU...Loading the main boot and system image files...The system image does not exist!Loading the backup boot and system image files...The image does not exist!Booting image fails!Trying to get the IP address from the DHCP server......System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing.......................................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 7.13 ** *****************************************************************************Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.Compiled Date : Feb 27 2019CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : DDR2 SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to access EXTENDED-BOOTWARE MENU...Loading the main boot and system image files...The system image does not exist!Loading the backup boot and system image files...The image does not exist!Booting image fails!Trying to get the IP address from the DHCP server......System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing.......................................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 7.13 ** *****************************************************************************Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.Compiled Date : Feb 27 2019CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : DDR2 SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to access EXTENDED-BOOTWARE MENU...Password recovery capability is enabled.Note: The current operating device is flashEnter < Storage Device Operation > to select device.====================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Skip Authentication for Console Login ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENUCtrl+F: Format File SystemCtrl+C: Display CopyrightEnter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y...................................................................................................Format success.====================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Skip Authentication for Console Login ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENUCtrl+F: Format File SystemCtrl+C: Display CopyrightEnter your choice(0-9): 3====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 5====================================================|Note: '.' = Clear field. || '-' = Go to previous field. || Ctrl+D = Quit. |============================================================================Protocol (FTP or TFTP) :tftp Load File Name :wa4300-fat.bin :Target File Name :wa4300-fat.bin :Server IP Address :192.168.0.1 Local IP Address :192.168.0.19 Subnet Mask :255.255.255.0 Gateway IP Address :0.0.0.0 ====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 1Loading............................................................................................................................................................................................................................Done.11120640 bytes downloaded!Extended BootWare Version is not equal,updating? [Y/N]Updating Extended BootWare..........Done.BootWare updated,System is rebooting now.System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing...............................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 1.17 ** *****************************************************************************Copyright (c) 2004-2020 New H3C Technologies Co., Ltd.Compiled Date : Apr 14 2020CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CRead net params from bootrom failed, use the default valueBootWare Validating...Press Ctrl+B to enter extended boot menu...Starting to get the main application file--flash:/wa4300_fit.bin!The main application file does not exist--flash:/wa4300_fit.bin!Starting to get the backup application file--flash:/backup.bin!The backup application file does not exist--flash:/backup.bin!Starting to get the secure application file--flash:/secure.bin!The secure application file does not exist--flash:/secure.bin!Booting App fails!Trying to get the IP address from the DHCP server......Getting IP Address Failed, the system will reboot. [State : Idle] Reset request, rebooting the APRebooting......System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing...............................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 1.17 ** *****************************************************************************Copyright (c) 2004-2020 New H3C Technologies Co., Ltd.Compiled Date : Apr 14 2020CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to enter extended boot menu...BootWare password: Not required. Please press Enter to continue.Password recovery capability is enabled.Note: The current operating device is flashEnter < Storage Device Operation > to select device.======================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Clear Super Password ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+C: Display CopyrightCtrl+Y: Change AP ModeCtrl+F: Format File SystemEnter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y...................................................................................................Format success.======================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Clear Super Password ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+C: Display CopyrightCtrl+Y: Change AP ModeCtrl+F: Format File SystemEnter your choice(0-9): 3====================================================|Note:the operating device is flash ||<1> Download Application Program To SDRAM And Run ||<2> Update Main Application File ||<3> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-3): 3====================================================|Note: '.' = Clear field. || '-' = Go to previous field. || Ctrl+D = Quit. |============================================================================Protocol (FTP or TFTP) :tftp Load File Name :host :wa4300-fat.binTarget File Name :target :wa4300-fat.binServer IP Address :192.168.1.1 192.168.0.1Local IP Address :192.168.1.253 192.168.0.19Gateway IP Address :0.0.0.0 ====================================================|Note:the operating device is flash ||<1> Download Application Program To SDRAM And Run ||<2> Update Main Application File ||<3> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-3): 0======================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Clear Super Password ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+C: Display CopyrightCtrl+Y: Change AP ModeCtrl+F: Format File SystemEnter your choice(0-9): 0System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing...............................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 1.17 ** *****************************************************************************Copyright (c) 2004-2020 New H3C Technologies Co., Ltd.Compiled Date : Apr 14 2020CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to enter extended boot menu...Starting to get the main application file--flash:/wa4300_fit.bin!The main application file does not exist--flash:/wa4300_fit.bin!Starting to get the backup application file--flash:/backup.bin!The backup application file does not exist--flash:/backup.bin!Starting to get the secure application file--flash:/secure.bin!The secure application file does not exist--flash:/secure.bin!Booting App fails!Trying to get the IP address from the DHCP server...
4 个回答
粉丝:199人 关注:0人
您好,我记得V7转V5需要过度版本,过渡版本上传了吗
zhiliao_Qqacjx 知了小白
你好,降级成功了的,到第二次更新BIN版本时,Server IP Address      :自动输出192.168.1.1,我网卡设置了192.168.0.1,改不了地址,Local IP Address       :自动输出192.168.1.253
粉丝:16人 关注:9人
您好,请参考案例https://zhiliao.h3c.com/Theme/details/6184
zhiliao_Qqacjx 知了小白
解决了,最后一步典型案例里是选<0> Reboot,失败了,而选<1>Boot System ,成功了。
