华三交换v5和v7分别怎么配置端口汇聚,vrrp 怎么配置
  • 1收藏,1429浏览
华三交换v5和v7分别怎么配置端口汇聚,vrrp 怎么配置,还有就是核心交换和路由能做ospf吗?一般网络是由核心+路由+ 防火墙 (边界) 由下至上吗
华三交换v5和v7分别怎么配置端口汇聚,vrrp 怎么配置华三交换v5和v7分别怎么配置端口汇聚,vrrp 怎么配置,还有就是核心交换和路由能做ospf吗?一般网络是由核心+路由+ 防火墙 (边界) 由下至上吗
粉丝:121人 关注:6人
以下是VRRP的配置案例,请参考:
组网说明:
本案例采用H3C HCL模拟器来模拟IPV6 VRRP典型组网配置。为了确保网络的冗余,将SW2和SW3开启VRRP作为网关冗余。SW2为主设备,SW3为备用设备。SW2、SW3与R1的互联采用ospf路由协议互通。当断开SW2的GI1/0/2上联口是,物理机能走SW3方向去往R1。
配置步骤
1、按照网络拓扑图正确配置IP地址和VLAN划分
2、SW2和SW3配置VRRP
3、SW2配置track,方便VRRP的检测与切换
4、SW2、SW3、R1运行OSPF路由协议
配置关键点
SW1:
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]int range gi 1/0/1 to gi 1/0/2
[SW1-if-range]port link-type trunk
[SW1-if-range]undo port trunk permit vlan 1
[SW1-if-range]port trunk permit vlan 10
[SW1-if-range]quit
[SW1]int gi 1/0/3
[SW1-GigabitEthernet1/0/3]port link-type access
[SW1-GigabitEthernet1/0/3]port access vlan 10
[SW1-GigabitEthernet1/0/3]quit
[SW1]ip unreachables enable
[SW1]ip ttl-expires enable
SW2:
<H3C>sys
[H3C]sysname SW2
[SW2]vlan 10
[SW2-vlan10]quit
[SW2]int range gi 1/0/1 gi 1/0/3
[SW2-if-range]port link-type trunk
[SW2-if-range]undo port trunk permit vlan 1
[SW2-if-range]port trunk permit vlan 10
[SW2-if-range]quit
[SW2]track 1 interface GigabitEthernet 1/0/2
[SW2-track-1]quit
[SW2]int gi 1/0/2
[SW2-GigabitEthernet1/0/2]port link-mode route
[SW2-GigabitEthernet1/0/2]des <connect to R1>
[SW2-GigabitEthernet1/0/2]ip address 10.0.0.1 30
[SW2-GigabitEthernet1/0/2]quit
[SW2-track-1]quit
[SW2]int vlan 10
[SW2-Vlan-interface10]ip address 192.168.1.252 24
[SW2-Vlan-interface10]vrrp vrid 1 virtual-ip 192.168.1.254
[SW2-Vlan-interface10]vrrp vrid 1 priority 120
[SW2-Vlan-interface10]vrrp vrid 1 track 1 priority reduced 30
[SW2-Vlan-interface10]quit
[SW2]int loopback 0
[SW2-LoopBack0]ip address 1.1.1.1 32
[SW2-LoopBack0]quit
[SW2]ospf 1 router-id 1.1.1.1
[SW2-ospf-1]silent-interface Vlan-interface 10
[SW2-ospf-1]area 0.0.0.0
[SW2-ospf-1-area-0.0.0.0]network 10.0.0.1 0.0.0.0
[SW2-ospf-1-area-0.0.0.0]network 1.1.1.1 0.0.0.0
[SW2-ospf-1-area-0.0.0.0]network 192.168.1.0 0.0.0.255
[SW2-ospf-1-area-0.0.0.0]quit
[SW2-ospf-1]quit
[SW2]ip unreachables enable
[SW2]ip ttl-expires enable
SW3:
<H3C>sys
[H3C]sysname SW3
[SW3]int loopback 0
[SW3-LoopBack0]ip address 2.2.2.2 32
[SW3-LoopBack0]quit
[SW3]vlan 10
[SW3-vlan10]quit
[SW3]int range gi 1/0/1 gi 1/0/3
[SW3-if-range]port link-type trunk
[SW3-if-range]undo port trunk permit vlan 1
[SW3-if-range]port trunk permit vlan 10
[SW3-if-range]quit
[SW3]int gi 1/0/2
[SW3-GigabitEthernet1/0/2]port link-mode route
[SW3-GigabitEthernet1/0/2]des <connect to R1>
[SW3-GigabitEthernet1/0/2]ip address 10.0.0.5 30
[SW3-GigabitEthernet1/0/2]ospf cost 200
[SW3-GigabitEthernet1/0/2]quit
[SW3]int vlan 10
[SW3-Vlan-interface10]ip address 192.168.1.253 24
[SW3-Vlan-interface10]vrrp vrid 1 virtual-ip 192.168.1.254
[SW3-Vlan-interface10]quit
[SW3]ospf 1 router-id 2.2.2.2
[SW3-ospf-1]silent-interface Vlan-interface 10
[SW3-ospf-1]area 0.0.0.0
[SW3-ospf-1-area-0.0.0.0]network 10.0.0.5 0.0.0.0
[SW3-ospf-1-area-0.0.0.0]network 2.2.2.2 0.0.0.0
[SW3-ospf-1-area-0.0.0.0]network 192.168.1.0 0.0.0.255
[SW3-ospf-1-area-0.0.0.0]quit
[SW3-ospf-1]quit
[SW3]ip unreachables enable
[SW3]ip ttl-expires enable
R1:
<H3C>sys
[H3C]sysname R3
[R3]int loopback 0
[R3-LoopBack0]ip address 3.3.3.3 32
[R3-LoopBack0]quit
[R3]int gi 0/0
[R3-GigabitEthernet0/0]des <connect to SW2>
[R3-GigabitEthernet0/0]ip address 10.0.0.2 30
[R3-GigabitEthernet0/0]quit
[R3]int gi 0/1
[R3-GigabitEthernet0/1]des <connect to SW3>
[R3-GigabitEthernet0/1]ip address 10.0.0.6 30
[R3-GigabitEthernet0/1]ospf cost 200
[R3-GigabitEthernet0/1]quit
[R3]ospf 1 router-id 3.3.3.3
[R3-ospf-1]area 0.0.0.0
[R3-ospf-1-area-0.0.0.0]network 10.0.0.2 0.0.0.0
[R3-ospf-1-area-0.0.0.0]network 3.3.3.3 0.0.0.0
[R3-ospf-1-area-0.0.0.0]quit
[R3-ospf-1]quit
[R3]ip unreachables enable
[R3]ip ttl-expires enable
查看SW2的VRRP显示信息为master:
查看SW3的VRRP显示信息为backup:
查看SW2的OSPF邻居信息:
查看SW3的OSPF邻居信息:
查看R1的OSPF邻居信息:
查看SW2的路由表:
查看SW3的路由表:
查看R1的路由表:
物理机设置IP地址:
物理机能PING通3.3.3.3
路由追踪,走SW2方向去往3.3.3.3
关闭SW2的GI 1/0/2端口:
[SW2]int gi 1/0/2
[SW2-GigabitEthernet1/0/2]shutdown
查看SW2和SW3的VRRP状态:
SW2的VRRP状态为backup
SW3的VRRP状态为main
此时物理机依然可以PING通3.3.3.3
使用trecert -d 3.3.3.3,物理机去往3.3.3.3已经走SW3方向:
根据测试结果得知,VRRP能正常切换,同时在切换后VLAN10走的是SW3方向去往3.3.3.3。
粉丝:36人 关注:1人
端口聚合和VRRP命令行应该没有变化
粉丝:7人 关注:2人
链路聚合:05-以太网链路聚合配置-新华三集团-H3C
vrrp:08-VRRP配置-新华三集团-H3C
核心和路由器之间可以做ospf的,看您实际规划
