只能使用瘦模式 客户现在那边只有一个这个,所以只要单独的独立模式就行,看网上说可以改成胖模式
(0)
首先需要console线登陆进入设备,进入设备之后
电脑用网线和AP相连,电脑ip地址配置为192.168.0.1
瘦AP切换为胖AP之bootrom菜单TFTP升级步骤
升级有风险,切记不要断电,整个过程记录下来
帐号名:yx800 密码:01230123
(1)从官网下载WA4320-ACN-E的软件版本,将压缩包解压,将里面的文件名称为
XXXX-CMW520-XXX-FAT.bin修改为wa4320_fat.bin
链接:http://www.h3c.com/cn/d_201805/1083983_30005_40.htm
(2)搭建TFTP服务器,将软件版本从服务器上传到设备(下载3CD软件)
(3)在AP重启的时候按住ctrl+B进入设备的bootroom菜单
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Clear Super Password |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Update Backup Application File |
|<4> Update Secure Application File |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) : tftp
Load File Name :wa2600a_fat.bin
Target File Name :wa2600a_fat.bin
Server IP Address :192.168.0.1 //电脑主机的 IP
Local IP Address :192.168.0.50
Gateway IP Address :0.0.0.0
//注意给电脑手动配置一个与AP同网段的IP地址,保证电脑与AP路由可达,能ping通
Enter your choice(0-5): 2 //此时可以看到TFTP服务器上数据上传的滚动
Loading.....................................................................
....................................Done!
返回主菜单,查看设备上是否真的已经上传了该软件版本
Enter your choice(0-5): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 4
===============================<File CONTROL>===============================
|<1> Display All File(s) |
|<2> Set Application File type |
|<3> Delete File |
Enter your choice(0-3): 1
Display all file(s) in flash:
'M' = MAIN 'B' = BACKUP 'S' = SECURE 'N/A' = NOT ASSIGNED
|NO. Size(B) Time Type Name |
|1 9124864 Aug/08/2008 20:00:00 M wa2600a_fat.bin |
上传成功
(4)返回主菜单,将设备进行重启
|<3> Delete File |
Enter your choice(0-3): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 0
System is starting...
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
我这个没有配置口
