4320i acn v7转v5问题请教
2021-06-12提问
  • 1收藏,725浏览
按照 v7转v5典型案例操作到最后一步选择0.reboot重启设备后出现如下错误提示: BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fat.bin! The main application file does not exist--flash:/wa4300_fat.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails!   Protocol (FTP or TFTP) : ftp Load File Name         : wa4300_fat.bin Target File Name       : wa4300_fat.bin Server IP Address      : 192.168.1.1 Local IP Address       : 192.168.1.50 Gateway IP Address     : 0.0.0.0 FTP User Name          : admin FTP User Password      : password 请教各位,谢谢!
如果最后一步选1.boot system能进入web页面,保断电重启设备后,就不能进入web页面
粉丝:17人 关注:2人
V7转V5,需要将bootrom先降级,通俗点说升两次,方法如下:
第一步:进入V7boot Ctrl+F
第二步:进入V7boot 通过网卡口,传入V5 AP bin文件,提示更新boot版本的时候选择Y
第三步:再次Crtl+F格式化AP flash
第四步:导入V5 AP版本(从AC V5版本中获取,建议使用最新版本)
第五步:重启,降级完成
建议与总结
第一步:进入V7boot Ctrl+F
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Aug 17 2015
CPU Type            : ATHEROS AR9563
CPU L1 Cache        : 32KB
CPU Clock Speed     : 775MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 16MB
PCB Version         : Ver.A
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
第二步:
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :tftp
Load File Name         :wa4300_fit.bin
Target File Name       :wa4300_fit.bin
Server IP Address      :192.168.21.1
Local IP Address       :192.168.21.2
Subnet Mask            :255.255.255.0
Gateway IP Address     :0.0.0.0
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 1
Loading.....................................................................
........Done.
7715840 bytes downloaded!
The image is self-decompressing.............................................
Done.
Extended BootWare Version is not equal,updating? [Y/N]
Updating Extended BootWare..........Done.
BootWare updated,System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing..............................Done!
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
Enter your choice(0-3): 3
|          Ctrl+D = Quit.                                                  |
Load File Name         :host
                       :wa4300_fit.bin
Target File Name       :target
                       :wa4300_fit.bin
Server IP Address      :192.168.1.1 192.168.21.1
Local IP Address       :192.168.1.253 192.168.21.2
Enter your choice(0-3): 2
........Done!
Updating File flash:/wa4300_fit.bin.........................................
..Done!
第五步:重启,降级完成
zhiliao_Qqacjx 知了小白
是v7瘦转v5胖模式
zhiliao_Qqacjx 知了小白
我现在进入boot显示的是1.17
zhiliao_Qqacjx 知了小白
我也是按照典型案例的步骤①步一步做的,升级二次的,保存不了启动文件,设备断电重启后就提示找不到启动文件
