H3Cwa2620
2021-06-12提问
  • 1收藏,648浏览
System is starting... Booting Normal Extend BootWare.... The Extend BootWare is self-decompressing...........................Done! **************************************************************************** * * * H3C WA2620 BootWare, Version 1.11 * * * **************************************************************************** Copyright (c) 2004-2012 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Jul 25 2012 CPU Type : AR9350 CPU L1 Cache : 32KB CPU Clock Speed : 560MHz Memory Type : SDRAM Memory Size : 128MB BootWare Size : 512KB Flash Size : 32MB CPLD Version : 002 PCB Version : Ver.E BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa2600a_fit.bin!.......... ...................................................................... The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ....................................................................Done! System application is starting... Startup configuration file does not exist. User interface con0 is available. Press ENTER to get started.
启动无法配置怎么解决?
我需要用tftp刷胖AP,现在无法进入boot
粉丝:219人 关注:0人
您好,开机后按ctrl+b进入
然后刷版本
方法按照软件版本附录的步骤
粉丝:25人 关注:7人
重启吧。在屏幕上提示你可以按ctrl+b的时候快速按下ctrl+b。或者一重启就一直狂按ctrl+b也行。
