WX3024 + wa2612ang
2017-07-21提问
  • 1收藏,2772浏览
一台主机 8台AP 上网速度很慢
<AC>dis cur
 version 5.20, ESS 3120
 sysname AC
 domain default enable system
 telnet server enable
 port-security enable
 portal server local_for_Vlan-interface1 ip 192.168.20.240 server-type imc
 portal local-server http
 oap management-ip 192.168.0.101 slot 0
 wlan auto-ap enable
vlan 1
vlan 10 to 11
vlan 15
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool 15
 network 192.168.15.0 mask 255.255.255.240
 gateway-list 192.168.15.1
 dns-list 202.101.172.35 202.101.172.46
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$UWtFI3ITDQ+MWCceHGrRXlftnHuTzI8V
 authorization-attribute level 3
 service-type telnet
 service-type web
wlan mesh-profile 1
 mesh-id 1
 bind WLAN-MESH 1
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
 load-balance traffic 40
wlan radio-policy 1025
wlan radio-policy 1281
wlan radio-policy 1537
wlan radio-policy 1793
wlan radio-policy 2049
wlan radio-policy 257
wlan radio-policy 513
wlan radio-policy 769
wlan service-template 1 clear
 ssid WNTEST
 bind WLAN-ESS 0
wlan service-template 2 crypto
 ssid ZJwinning-guest
 bind WLAN-ESS 1
 cipher-suite wep40
 wep default-key 1 wep40 raw-key cipher $c$3$MikDIHOHTeGLC57sR++vTc47awhta62DHkCiaDY=
 service-template enable
wlan ap-group default_group
 ap ap1
 ap ap2
 ap ap3
 ap ap4
 ap ap5
 ap ap6
 ap ap7
 ap ap8
 dot11a service-template 1
 dot11a service-template 2
 dot11bg service-template 1
 dot11bg service-template 2
 dot11a radio enable
 dot11bg radio enable
interface NULL0
interface Vlan-interface1
 ip address 12.12.12.10 255.255.255.0
interface Vlan-interface15
 ip address 192.168.15.1 255.255.255.0
 port link-type trunk
 port trunk permit vlan all
interface WLAN-ESS0
 port access vlan 10
interface WLAN-ESS1
 port link-type hybrid
 port hybrid vlan 1 untagged
interface WLAN-MESH1
wlan ap ap1 model WA2612-AGN id 6
 serial-id 210235A35WC11B000075
 radio 1
  channel 10
  radio-policy 1537
  service-template 1 vlan-id 11
  service-template 2 vlan-id 10
  bandwidth-guarantee enable
  radio enable
wlan ap ap2 model WA2612-AGN id 4
 serial-id 210235A35WC11B000071
 radio 1
  channel 10
  radio-policy 1025
  bandwidth-guarantee service-template 2 percent 100
  radio enable
wlan ap ap3 model WA2612-AGN id 5
 serial-id 210235A35WC11B000174
 radio 1
  channel 10
  radio-policy 1281
  radio enable
wlan ap ap4 model WA2612-AGN id 2
 serial-id 210235A35WC11B000146
 country-code CN
 radio 1
  channel 10
  radio-policy 513
  radio enable
wlan ap ap5 model WA2612-AGN id 1
 serial-id 210235A35WC11B000106
 radio 1
  channel 10
  radio-policy 257
  radio enable
wlan ap ap6 model WA2612-AGN id 3
 serial-id 210235A35WC11B000175
 radio 1
  channel 10
  radio-policy 769
  radio enable
wlan ap ap7 model WA2612-AGN id 8
 serial-id 210235A35WC11B000067
 radio 1
  channel 10
  radio-policy 2049
  radio enable
wlan ap ap8 model WA2612-AGN id 7
 serial-id 210235A35WC11B000077
 radio 1
  channel 10
  radio-policy 1793
  radio enable
wlan mobility-group 1
wlan load-balance-group 1
 description 1
 ap ap7 radio 1
 ap ap8 radio 1
 ap ap1 radio 1
 ap ap3 radio 1
 ap ap2 radio 1
 ap ap6 radio 1
 ap ap5 radio 1
 ap ap4 radio 1
 ip route-static 0.0.0.0 0.0.0.0 12.12.12.1
 dhcp enable
 mkd-service enable mesh-profile 1
 wlan ap-authentication method serial-id
 load xml-configuration
user-interface con 0
user-interface vty 0 4
 user privilege level 3
 set authentication password cipher $c$3$OZwqz1sYiahUwtwHOHZQIhGny37zVUZZz9KS
return
粉丝:2人 关注:0人
上网慢原因很多,客户端速率协商低,空口干扰大,客户端数量多等都会造成上网慢,从配置来看,你的配置不规范,所有AP在同一个信道,一些优化都没做,建议打400电话进行问题处理。
过保的机器 400不给支持 机器过保 400让我来这里发帖,wlan小白一枚 只会RS
船到桥头自然沉 发表时间:2017-07-21
大大 比如要做哪些优化
http://kms.h3c.com/View.aspx?id=45058 可以查看此链接的通用优化指南,按照上述做优化。
张家界的小喽喽 发表时间:2017-07-21
4 个回答
余sir 八段
粉丝:25人 关注:0人
radio全部用了相同的信道,会不会干扰比较大,是在同一个大区域覆盖的吗? 可以选择几个AP用11a
-4811 九段
粉丝:28人 关注:1人
所有ap射频都工作在同一个信道10,能正常就怪了,先优化信道1/6/11进行部署吧
 radio 1
  channel 10
感谢大大 信道改了 1 6 11 请问大大其他是否能优化
粉丝:226人 关注:0人
修改信道啊,信道都是10,AP之间互相干扰,能不影响网速吗
fywr 九段
粉丝:49人 关注:3人
这配置也是挺厉害的了
