f100-m-g2防火墙做网关设备,配置完ssl vpn后,能拨号成功,但是一直提示认真失败,
2021-06-25提问
  • 1收藏,685浏览
做完ssl vpn后,连接上,但是认证失败,通过web配置的,照着案例文档,不知道问题出在哪,
粉丝:0人 关注:2人
可以参照这个链接中的手册进行对照排查
https://www.h3c.com/cn/d_202001/1271976_30005_0.htm#_Toc30509075
一、检查配置
interface SSLVPN-AC1
 ip address 19.x.x.1 255.255.255.0
sslvpn gateway gw
 ip address 123.x.x.74 port 4430
 ssl server-policy ssl
 service enable
sslvpn context ctx
 gateway gw
 ip-tunnel interface SSLVPN-AC1
 ip-tunnel address-pool pool1 mask 255.255.255.0
 ip-route-list rtlist
  include 19.x.x.0 255.255.255.0
 policy-group pgroup
  filter ip-tunnel acl 3700
  filter web-access acl 3700
  filter tcp-access acl 3700
  ip-tunnel access-route ip-route-list rtlist
 service enable
检查配置没有问题。
二、查看证书状态
[FW]pki validate-certificate domain sslvpn ca
Verifying certificates......
        Serial Number:
            12:77:61:df:a6:01:45:a7:47:5e:61:a7:5b:20:0a:31
        Issuer:
            CN=H3CTS-Security-CA
        Subject:
Verify result: OK
[FW]pki validate-certificate domain sslvpn lo
[FW]pki validate-certificate domain sslvpn local
        Serial Number:
            61:07:d6:de:00:00:00:00:00:05
        Issuer:
        Subject:
            C=CN
            ST=ZheJiang
            L=HangZhou
            O=H3C
            OU=TSC
            CN=Security
Verify result: OK
证书状态正常。
三、查看SSL VPN状态
[FW]dis sslvpn gateway
Gateway name: gw
  Operation state: Up
  IP: 123.x.x.74 Port: 4430
  SSL server policy configured: ssl
  SSL server policy in use: ssl
  Front VPN instance: Not configured
[FW]dis sslvpn context
Context name: ctx
  Operation state: Up
  AAA domain: Not specified
  Certificate authentication: Disabled
  Dynamic password: Disabled
  Code verification: Disabled
  Default policy group: pgroup
  Associated SSL VPN gateway: gw
  Maximum users allowed: 1048575
  Idle timeout: 30 min
SSL VPN状态正常。
四、查看会话
[FW]display session table ipv4 destination-ip 123.x.x.74 destination-port 4430 verbose
Slot 1:
Initiator:
  Source      IP/port: 221.12.4.143/29039
  Destination IP/port: 123.x.x.74/4430
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Route-Aggregation2
  Source security zone: Untrust
Responder:
  Source      IP/port: 123.x.x.74/4430
  Destination IP/port: 221.12.4.143/29039
  Protocol: TCP(6)
  Inbound interface: InLoopBack0
  Source security zone: Local
State: TCP_CLOSE
Application: GENERAL_TCP
Start time: 2017-06-13 15:32:30  TTL: 0s
Initiator->Responder:            2 packets        140 bytes
Responder->Initiator:            2 packets         80 bytes
Total sessions found: 1
Slot 2:
Initiator:
  Protocol: TCP(6)
Responder:
  Protocol: TCP(6)
State: TCP_SYN_RECV
Start time: 2017-06-13 15:32:30  TTL: 27s
Initiator->Responder:            1 packets         60 bytes
Responder->Initiator:            1 packets         60 bytes
粉丝:124人 关注:6人
SSL VPN链接失败,以下是排查要点,请参考:
1、检查终端到SSL VPN网关的路由是否可达。
2、防火墙上涉及到的物理端口、SSL-AC1端口需要加入安全域并放通安全策略或域间策略,尤其是LOCAL域,需分别作为源和目的进行放通。
3、进一步检查SSL VPN的配置,以下是参考配置:
SSL VPN IP接入配置关键点:
SSL_VPN:
[SSL_VPN]acl advanced 3000
[SSL_VPN-acl-ipv4-adv-3000]rule 0 permit ip source any
[SSL_VPN-acl-ipv4-adv-3000]quit
[SSL_VPN]sslvpn ip address-pool weijianing 172.16.1.2 172.16.1.254
[SSL_VPN]int SSLVPN-AC 1
[SSL_VPN-SSLVPN-AC1]ip address 172.16.1.1 24
[SSL_VPN-SSLVPN-AC1]quit
[SSL_VPN]sslvpn gateway james
[SSL_VPN-sslvpn-gateway-james]ip address 192.168.200.200
[SSL_VPN-sslvpn-gateway-james]service enable
[SSL_VPN-sslvpn-gateway-james]quit
[SSL_VPN]sslvpn context james
[SSL_VPN-sslvpn-context-james]gateway james
[SSL_VPN-sslvpn-context-james]ip-tunnel address-pool weijianing mask 24
[SSL_VPN-sslvpn-context-james]ip-tunnel interface SSLVPN-AC 1
[SSL_VPN-sslvpn-context-james]ip-route-list james
[SSL_VPN-sslvpn-context-james-route-list-james]include 10.0.0.0 24
[SSL_VPN-sslvpn-context-james-route-list-james]quit
[SSL_VPN-sslvpn-context-james]policy-group ip
[SSL_VPN-sslvpn-context-james-policy-group-ip]filter ip-tunnel acl 3000
[SSL_VPN-sslvpn-context-james-policy-group-ip]ip-tunnel access-route ip-route-list james
[SSL_VPN-sslvpn-context-james-policy-group-ip]quit
[SSL_VPN-sslvpn-context-james]service enable
[SSL_VPN-sslvpn-context-james]quit
[SSL_VPN]local-user weijianing class network
New local user added.
[SSL_VPN-luser-network-weijianing]password simple weijianing
[SSL_VPN-luser-network-weijianing]service-type sslvpn
[SSL_VPN-luser-network-weijianing]authorization-attribute sslvpn-policy-group ip
[SSL_VPN-luser-network-weijianing]quit
[SSL_VPN]security-zone name Untrust
[SSL_VPN-security-zone-Untrust]import interface SSLVPN-AC 1
[SSL_VPN-security-zone-Untrust]quit
zhiliao_VUP4v1 知了小白
有没有相关web配置案例,
可以参照这个链接中的手册进行对照排查
