可以大致参考:https://www.h3c.com/cn/d_201505/869008_30005_0.htm
可能稍微有点复杂,理解一下,其他双机热备的部分可以不参考
(1)
这款墙的透明模式,进入接口下直接改成二层模式即可
inter GigabitEthernet0/1
port link-mode bridge
其它配置,和三层模式配置方法一样,比如将端口加入安全域、域间策略,二层模式和三层模式配置方式和思路都一样的
(0)
以下是防火墙透明模式的配置案例,请参考:
组网说明:
本案例采用H3C HCL模拟器的F1060防火墙来模拟防火墙的透明模式典型组网配置2。为了实现PC之间相互PING通,因此需要在SW1、R1之间通过路由指向来实现路由可达。F1060处在R1、SW1之间,所以将F1060配置为透明模式,采用trunk的方式为R1、SW1透传业务。
1、按照网络拓扑图正确配置IP地址
2、R1与SW1之间运行ospf路由协议
3、将F1060防火墙配置为透明模式,采用trunk的方式为R1、SW1透传业务。
SW1:
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 100
[SW1-vlan100]quit
[SW1]int vlan 100
[SW1-Vlan-interface100]ip address 172.16.1.1 24
[SW1-Vlan-interface100]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-type access
[SW1-GigabitEthernet1/0/1]port access vlan 100
[SW1-GigabitEthernet1/0/1]quit
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 10.0.0.1 30
[SW1-Vlan-interface10]quit
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]des <connect to FW1>
[SW1-GigabitEthernet1/0/2]port link-type trunk
[SW1-GigabitEthernet1/0/2]undo port trunk permit vlan 1
[SW1-GigabitEthernet1/0/2]port trunk permit vlan 10
[SW1-GigabitEthernet1/0/2]quit
[SW1]int loopback 0
[SW1-LoopBack0]ip address 1.1.1.1 32
[SW1-LoopBack0]quit
[SW1]ospf 1 router-id 1.1.1.1
[SW1-ospf-1]area 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 10.0.0.1 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 1.1.1.1 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 172.16.1.0 0.0.0.255
[SW1-ospf-1-area-0.0.0.0]quit
[SW1-ospf-1]quit
[SW1]
R1:
<H3C>sys
[H3C]sysname R1
[R1]int loopback 0
[R1-LoopBack0]ip address 2.2.2.2 32
[R1-LoopBack0]quit
[R1]int gi 0/1
[R1-GigabitEthernet0/1]ip address 192.168.1.1 24
[R1-GigabitEthernet0/1]quit
[R1]vlan 10
[R1-vlan10]quit
[R1]int vlan 10
[R1-Vlan-interface10]ip address 10.0.0.2 30
[R1-Vlan-interface10]quit
[R1]int gi 0/0
[R1-GigabitEthernet0/0]port link-mode bridge
[R1-GigabitEthernet0/0]port link-type trunk
[R1-GigabitEthernet0/0]undo port trunk permit vlan 1
[R1-GigabitEthernet0/0]port trunk permit vlan 10
[R1-GigabitEthernet0/0]quit
[R1]ospf 1 router-id 2.2.2.2
[R1-ospf-1]area 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 10.0.0.2 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 2.2.2.2 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 192.168.1.0 0.0.0.255
[R1-ospf-1-area-0.0.0.0]quit
[R1-ospf-1]quit
FW1 透明模式配置关键点:
<H3C>sys
[H3C]sysname FW1
[FW1]vlan 10
[FW1-vlan10]quit
[FW1]int range gi 1/0/2 to gi 1/0/3
[FW1-if-range]port link-mode bridge
[FW1-if-range]port link-type trunk
[FW1-if-range]undo port trunk permit vlan 1
[FW1-if-range]port trunk permit vlan 10
[FW1-if-range]quit
[FW1]security-zone name Trust
[FW1-security-zone-Trust]import interface GigabitEthernet 1/0/3 vlan 10
[FW1-security-zone-Trust]quit
[FW1]security-zone name Untrust
[FW1-security-zone-Untrust]import interface GigabitEthernet 1/0/2 vlan 10
[FW1-security-zone-Untrust]quit
[FW1]acl basic 2002
[FW1-acl-ipv4-basic-2002]rule 0 permit source any
[FW1-acl-ipv4-basic-2002]quit
[FW1]
[FW1]zone-pair security source trust destination untrust
[FW1-zone-pair-security-Trust-Untrust]packet-filter 2002
[FW1-zone-pair-security-Trust-Untrust]quit
[FW1]
[FW1]zone-pair security source untrust destination trust
[FW1-zone-pair-security-Untrust-Trust]packet-filter 2002
[FW1-zone-pair-security-Untrust-Trust]quit
[FW1]
[FW1]zone-pair security source trust destination local
[FW1-zone-pair-security-Trust-Local]packet-filter 2002
[FW1-zone-pair-security-Trust-Local]quit
[FW1]
[FW1]zone-pair security source local destination trust
[FW1-zone-pair-security-Local-Trust]packet-filter 2002
[FW1-zone-pair-security-Local-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination local
[FW1-zone-pair-security-Untrust-Local]packet-filter 2002
[FW1-zone-pair-security-Untrust-Local]quit
[FW1]
[FW1]zone-pair security source local destination untrust
[FW1-zone-pair-security-Local-Untrust]packet-filter 2002
[FW1-zone-pair-security-Local-Untrust]quit
[FW1]
[FW1]zone-pair security source trust destination trust
[FW1-zone-pair-security-Trust-Trust]packet-filter 2002
[FW1-zone-pair-security-Trust-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination untrust
[FW1-zone-pair-security-Untrust-Untrust]packet-filter 2002
[FW1-zone-pair-security-Untrust-Untrust]quit
测试:
所有PC都填写IP地址:
PC之间可以相互PING通:
分别查看SW1、R1的OSPF邻居信息:
分别查看SW1、R1的路由表:
查看FW1的zone-pair:
(0)
防火墙透明部署非常简单
1、把物理口配置成二层口
2、配置一个BVI接口,二层口都加入这个BVI
3、不同的二层口加入到不同的域
4、配置相应的域间策略即可
(0)
vlan 1 | |
int vlan 1 | |
ip add 192.168.10.2 24 | 管理地址,根据实际需要设置 |
int range g1/0/1 g1/0/2 | |
port link-mode bridge | |
security-zone name Untrust | |
import int g1/0/1 vlan 1 to 4094 | |
security-zone name Trust | |
import interface Vlan-interface1 | |
import int g1/0/2 vlan 1 to 4094 | |
security-policy ip | |
rule 0 name shangwang1 | |
action pass | |
source-zone Trust | |
destination-zone Untrust | |
rule 1 name shangwang2 | |
action pass | |
source-zone Untrust | |
destination-zone Trust | |
rule 2 name trust-local | |
action pass | |
source-zone trust | |
destination-zone local | |
acl advanced 3000 | |
rule 0 permit ip | |
zone-pair security source Trust destination Untrust | |
packet-filter 3000 | |
zone-pair security source Trust destination Local | |
zone-pair security source Local destination Trust | |
zone-pair security source Untrust destination Trust | |
zone-pair security source Untrust destination Local | |
zone-pair security source Local destination Untrust | |
sa f |
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
