vlan之间不能互访
2021-07-05提问
  • 1收藏,2847浏览
vlan都在一个设备上,需要做到vlan之间不能互访,但是同事能访问外网怎么做
粉丝:124人 关注:6人
VLAN之间不能互访,可以使用高级ACL来实现,以下是配置案例及链接,请参考:
https://zhiliao.h3c.com/Theme/details/102369
组网说明:
本案例采用H3C HCL模拟器来模拟高级ACL典型组网配置。服务器在网络拓扑图中已有明确的标识。要求VLAN 10仅能访问server1,VLAN 20仅能访问server2。R1与SW1运行OSPF路由协议。
配置步骤
1、按照网络拓扑图正确配置IP地址
2、SW1与R1运行OSPF路由协议
3、在SW1配置高级ACL,VLAN 10仅能访问server1,VLAN 20仅能访问server2。
配置关键点
第一阶段调试(基础网络配置):
SW1:
SW1:
sys
[H3C]sysname SW1
[SW1]int loopback 0
[SW1-LoopBack0]ip address 1.1.1.1 32
[SW1-LoopBack0]quit
[SW1]router id 1.1.1.1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 172.16.10.1 24
[SW1-Vlan-interface10]quit
[SW1]int vlan 20
[SW1-Vlan-interface20]ip address 172.16.20.1 24
[SW1-Vlan-interface20]quit
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-type access
[SW1-GigabitEthernet1/0/2]port access vlan 10
[SW1-GigabitEthernet1/0/2]quit
[SW1]int gi 1/0/3
[SW1-GigabitEthernet1/0/3]port link-type access
[SW1-GigabitEthernet1/0/3]port access vlan 20
[SW1-GigabitEthernet1/0/3]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-mode route
[SW1-GigabitEthernet1/0/1]des
[SW1-GigabitEthernet1/0/1]ip address 10.0.0.1 30
[SW1-GigabitEthernet1/0/1]quit
[SW1]ospf 1 router-id 1.1.1.1
[SW1-ospf-1]area 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 10.0.0.1 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 1.1.1.1 0.0.0.0
[SW1-ospf-1-area-0.0.0.0]network 172.16.10.0 0.0.0.255
[SW1-ospf-1-area-0.0.0.0]network 172.16.20.0 0.0.0.255
[SW1-ospf-1-area-0.0.0.0]quit
[SW1-ospf-1]quit
[SW1]
R1:
sys
[H3C]sysname R1
[R1]int gi 0/0
[R1-GigabitEthernet0/0]des
[R1-GigabitEthernet0/0]ip address 10.0.0.2 30
[R1-GigabitEthernet0/0]quit
[R1]int gi 0/1
[R1-GigabitEthernet0/1]ip address 192.168.1.1 24
[R1-GigabitEthernet0/1]quit
[R1]int gi 0/2
[R1-GigabitEthernet0/2]ip address 192.168.2.1 24
[R1-GigabitEthernet0/2]quit
[R1]int loopback 0
[R1-LoopBack0]ip address 2.2.2.2 32
[R1-LoopBack0]quit
[R1]router id 2.2.2.2
[R1]ospf 1 router-id 2.2.2.2
[R1-ospf-1]area 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 10.0.0.2 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 2.2.2.2 0.0.0.0
[R1-ospf-1-area-0.0.0.0]network 192.168.1.0 0.0.0.255
[R1-ospf-1-area-0.0.0.0]network 192.168.2.0 0.0.0.255
[R1-ospf-1-area-0.0.0.0]quit
[R1-ospf-1]quit
第一阶段测试:
所有PC都填写IP地址,且都能互通:
第二阶段调试(高级ACL关键配置点):
SW1:
[SW1]acl advanced 3000
[SW1-acl-ipv4-adv-3000]rule 0 permit ip source 172.16.10.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[SW1-acl-ipv4-adv-3000]rule 1 permit ip source 172.16.20.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
[SW1-acl-ipv4-adv-3000]rule 3 deny ip source 172.16.10.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
[SW1-acl-ipv4-adv-3000]rule 4 deny ip source 172.16.20.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[SW1-acl-ipv4-adv-3000]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]packet-filter 3000 outbound
第二阶段测试:
VLAN 10的终端能PING通server1,无法Ping通server2:
Vlan 20的终端能PING通server2,PING不通server1:
Server1能PING通VLAN 10的终端,PING不通VLAN 20的终端:
Server2能PING通VLAN 20的终端,PING不通VLAN 10的终端:
查看ACL的匹配情况:
粉丝:226人 关注:0人
您好,设置包过滤
配置步骤
# 创建IPv4基本ACL 2000,配置拒绝源IP地址为10.1.1.1的报文通过的规则。
[H3C] acl basic 2000
[H3C-acl-ipv4-basic-2000] rule deny source 10.1.1.1 0
[H3C-acl-ipv4-basic-2000] quit
说明:如果acl number 2000无法写上去的话可能是由于交换机的软件版本不同导致,此时修改为acl basic 2000的写法就可以了。
# 配置包过滤功能,应用IPv4基本ACL 2000对端口GigabitEthernet1/0/1收到的IPv4报文进行过滤。
[H3C] interface gigabitethernet 1/0/1
[H3C-GigabitEthernet1/0/1] packet-filter 2000 inbound
粉丝:1人 关注:1人
您好,可以开启二层端口隔离https://www.h3c.com/cn/d_201407/834241_30005_0.htm
跨vlan的话可以用acl
平凡的烧年 发表时间:2021-07-05
粉丝:20人 关注:15人
首先要明确是一个vlan还是多个vlan,多个vlan,本身默认就是隔离的,所以你所描述的功能默认实现。一个vlan,要看组网,如果是PC——sw——rt,在rt上做的vlan,那同一vlan二层访问都不经过RT。如果就是PC——Sw,那要看SW能不能做二层隔离,我理解的都不太好搞,上面所说的策略什么的,都是三层策略,同一vlan内就是二层访问,不适合这个场景。
