BFD MAD检测端口存在闪断情况
2021-07-05提问
  • 0收藏,263浏览
两台M9008-S设备做堆叠,三层路由聚合口bfd mad做检测,检测端口频繁up_down,但是很快就能恢复,以下是设备告警信息,恢复时间不到一秒钟%Jul  5 20:05:14:790 2021 ZQ-UBXFA-BA-CMNET-FW01&02-M9008 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/2/2/1 changed to down.
%Jul  5 20:05:14:791 2021 ZQ-UBXFA-BA-CMNET-FW01&02-M9008 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/2/2/1 changed to down.
%Jul  5 20:05:14:795 2021 ZQ-UBXFA-BA-CMNET-FW01&02-M9008 LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/2/2/1 of aggregation group RAGG1024 changed to the inactive state, because the physical state of the port is down.
%Jul  5 20:05:14:880 2021 ZQ-UBXFA-BA-CMNET-FW01&02-M9008 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/2/2/1 changed to up.
%Jul  5 20:05:14:883 2021 ZQ-UBXFA-BA-CMNET-FW01&02-M9008 LAGG/6/LAGG_ACTIVE: Member port GE1/2/2/1 of aggregation group RAGG1024 changed to the active state.
%Jul  5 20:05:14:925 2021 ZQ-UBXFA-BA-CMNET-FW01&02-M9008 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/2/2/1 changed to up.
粉丝: 关注:
端口频繁UP DOWN,以下是排查要点,请参考:
1、检查物理链路是否正确。
2、检查两边端口速率、双工模式是否一致。
3、检查端口的STP是否已关闭。
4、检查用于BFD MAD检测的VLAN,是否有在其他端口进行了trunk透传。
粉丝: 关注:
物理链路up/down,检查一下中间网线或者强制一下两端设备双工速率试一下
知了小白
粉丝: 关注:
您好,以下参考
1.检查链路是否正常
2.检查端口速率是否一致
