求救, password-control的login idle-time问题
2018-06-15提问
  • 1收藏,2187浏览
 password-control enable
 password-control composition type-number 4 type-length 1
 password-control length 12
 undo password-control aging enable
 undo password-control history enable
 undo password-control login-attempt
 undo password-control alert-before-expire
 undo password-control authentication-timeout
 undo password-control expired-user-login
 undo password-control login idle-time
 undo password-control password update interval
undo password-control super aging
上面是配置。做实验,起初,ssh登录正常。手动修改时间为一年以后,发现ssh登录不上啦,提示“Failed to log in because the login idle timer expired
有没有高手,知道这啥原因
仁风 四段
看报错是账号的闲置时间到了
 undo password-control login idle-time 是恢复账号的缺省闲置时间 90天,并不是删除这个功能,password-control功能使能之后,有一些功能可以禁止,有些功能无法禁止,具体可以参考命令手册
http://www.h3c.com/cn/d_201805/1079741_30005_0.htm#_Toc511815170
这样子,感觉有点奇葩
zhiliao_LUcHI 发表时间:2018-06-15
idle-time设置成0
