标杆神器统一管理和刷脚本的操作流程是什么?
2021-07-26提问
  • 1收藏,852浏览
粉丝:0人 关注:2人
粉丝:226人 关注:0人
您好,参考
过标杆的神器升级设备
    目前版本:
<H3C>dis version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 2221P10
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5500-28C-EI uptime is 0 week, 0 day, 0 hour, 6 minutes
H3C S5500-28C-EI with 1 Processor
256M    bytes SDRAM
32768K  bytes Flash Memory
Hardware Version is REV.C
CPLD Version is 002
Bootrom Version is 721
[SubSlot 0] 24GE+4SFP Hardware Version is REV.C
<H3C>
#Apr 26 12:39:51:503 2000 H3C DEVM/1/REBOOT:
 Reboot device by command.
%Apr 26 12:39:51:595 2000 H3C DEVM/5/SYSTEM_REBOOT: System is rebooting now.
 System is rebooting; can&#39;t respond to your command.
Starting......
            *          H3C S5500-28C-EI BOOTROM, Version 721          *
            Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd.
            Creation date   : Nov 12 2013, 01:59:13
            CPU Clock Speed : 533MHz
            BUS Clock Speed : 133MHz
            Memory Size     : 256MB
            Mac Address     : 000fe28cd787
Press Ctrl-B to enter Boot Menu... 0
Auto-booting...
Decompress Image...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................OK!
User interface aux0 is available.
Press ENTER to get started.
<H3C>
<H3C>
<H3C>
<H3C>
<H3C>
#Apr 26 12:42:23:715 2000 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console
%Apr 26 12:42:23:859 2000 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
<H3C>
<H3C>
<H3C>
<H3C>dis ver
<H3C>dis version
Comware Software, Version 5.20, Release 2221P26
Copyright (c) 2004-2016 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5500-28C-EI uptime is 0 week, 0 day, 0 hour, 2 minutes
256M    bytes SDRAM
CPLD Version is 002
<H3C>
        在添加设备时有几种方式
1、 com口即就是通过console线缆连接时的com串口,这里使用com口连接时保证com口和电脑识别的com口一致
2、telnet方式,这种方式配置时,前提是标杆神器到设备端可达,并且设备端已经配置了telnet功能,用户权限属于最高权限
3、SSH方式,这种方式和telnet基本是一样的,都需要在设备端先进行配置,以便从标杆神器可以登录上去管理
