MSR5660 ipsec-vpn报错,状态是unknown,请问是怎么看呢?
2021-07-30提问
  • 1收藏,1261浏览
*Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Received ISAKMP Key Exchange Payload.
*Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Received ISAKMP Nonce Payload.
 *Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Received ISAKMP NAT-D Payload.
*Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Process KE payload.
*Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/ERROR: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Invalid KE payload length (128).
*Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Construct notification packet: INVALID_KEY_INFORMATION.
*Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Sending packet to 39.107.254.58 remote port 500, local port 500.
 *Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 I-COOKIE: 9b2b7bf2ff448409 R-COOKIE: 9ae2a9ce7627fe20 next payload: NOTIFY version: ISAKMP Version 1.0 exchange mode: Info flags: message ID: 0 length: 56
 *Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Sending an IPv4 packet.
*Jul 30 14:51:44:913 2021 MN-BJ-MSR5660-DX IKE/7/EVENT: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Sent data to socket successfully.
*Jul 30 14:51:48:858 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Retransmit phase 1 packet.
*Jul 30 14:51:48:859 2021 MN-BJ-MSR5660-DX IKE/7/PACKET: vrf = 0, local = 124.127.192.146, remote = 39.107.254.58/500 Sending packet to 39.107.254.58 remote port 500, local port 500.
粉丝:7人 关注:2人
检查一下key的配置是否正确
正确的
zhiliao_RuX6dq 发表时间:2021-07-30
Connection ID: 5677 Outside VPN: Inside VPN: Profile: aliyun Transmitting entity: Initiator Initiator COOKIE: c076a16c1af8824a Responder COOKIE: c3c6d2308a87b545 ----------------------------------------------- Local IP: 124.127.192.146 Local ID type: Unknown Local ID: Remote IP: 39.107.254.58 Remote ID type: Unknown Remote ID: Authentication-method: PRE-SHARED-KEY Authentication-algorithm: SHA1 Encryption-algorithm: DES-CBC Life duration(sec): 86400 Remaining key duration(sec): 0 Exchange-mode: Main Diffie-Hellman group: Group 1 NAT traversal: Not detected Extend authentication: Disabled Assigned IP address: Vendor ID index:0xffffffff Vendor ID sequence number:0x0
粉丝:39人 关注:7人
检查IPSEC VPN是否能正常建立并是否能互通。
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
粉丝:143人 关注:1人
参考
http://www.h3c.com/cn/d_201411/921533_30005_0.htm
粉丝:95人 关注:1人
密钥对吗
