脚本没传上来,重发一遍。
拓扑是这样,ipsec网关旁挂核心交换机,核心到对端感兴趣流的回程路由已经写好了,总部有固定ip,分支是4G,没有固定ip,采用野蛮模式,分支是在边界发起链接,总部的出口是一台天融信的墙,已经把ipsec网关的500和4500两个udp端口映射到公网ip,且让天融信厂家看过,确保NAT映射正确无误。从下午调到现在,两侧连ike sa都无法建议,不知道问题出在哪里,下边是两侧脚本,还请各位老师帮忙看看,急~!
总部:
[IPsec]dis cur
version 5.20, Release 2514P04
sysname IPsec
ike local-name zongbu
domain default enable system
dns proxy enable
telnet server enable
dar p2p signature-file flash:/p2p_default.mtd
ndp enable
ntdp enable
cluster enable
port-security enable
password-recovery enable
acl number 3000
acl number 3001
rule 0 permit ip source 10.173.129.0 0.0.0.255 destination 10.173.130.64 0.0.0.
15
vlan 1
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
ike proposal 2
ike peer center
exchange-mode aggressive
proposal 2
pre-shared-key cipher $c$3$4KOaQTAjcf0BqGeXiK8JFms/DFOYkYh9kA==
id-type name
remote-name branch
remote-address branch dynamic
local-address 61.150.106.90
local-name center
nat traversal
ipsec transform-set center
encapsulation-mode tunnel
transform esp
esp authentication-algorithm md5
esp encryption-algorithm 3des
ipsec policy 1048580 1 isakmp
connection-name center
security acl 3001
ike-peer center
sa duration traffic-based 1843200
sa duration time-based 3600
ipsec profile 1
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$g6a6AIDd3LJRPAyTYIKyV7DY6nO9imem
authorization-attribute level 3
service-type telnet
service-type web
cwmp
undo cwmp enable
interface Cellular0/0
async mode protocol
link-protocol ppp
tcp mss 1024
interface NULL0
interface Vlan-interface1
interface GigabitEthernet0/0
port link-mode route
tcp mss 1024
interface GigabitEthernet0/4
ip address 10.173.129.53 255.255.255.0
ipsec no-nat-process enable
interface GigabitEthernet0/1
port link-mode bridge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
ip route-static 0.0.0.0 0.0.0.0 10.173.129.3
dhcp enable
load xml-configuration
load tr069-configuration
user-interface con 0
user-interface tty 13
user-interface vty 0 4
user privilege level 3
set authentication password cipher $c$3$A4CPpDaEQjlEiKs0j5cWcE5cKKmxa57/
protocol inbound telnet
return
[IPsec]
分支:
version 7.1.064, Release 0615P10
sysname YuLin_JZT
dialer-group 1 rule ip permit
dialer-group 28 rule ip permit
dialer-group 89 rule ip permit
ip load-sharing mode per-flow src-ip global
dhcp enable
dhcp server always-broadcast
dns proxy enable
vlan 1
dhcp server ip-pool lan1
gateway-list 10.173.130.65
network 10.173.130.64 mask 255.255.255.240
address range 10.173.130.68 10.173.130.78
dns-list 10.173.130.65
apn-profile profile69
apn static cmnet
wlan service-template 1
ssid YuLin_JZT
akm mode psk
preshared-key pass-phrase cipher $c$3$y3nrrQ0Yo3T9p7t3Mlo+TvG68rThWbx6fCB9
cipher-suite ccmp
security-ie rsn
service-template enable
controller Cellular0/0
description Single_Line1-CMCC
serial-set 0
controller Cellular1/0
eth-channel 0
interface Dialer0
interface Dialer1
interface Dialer2
interface Dialer3
interface Dialer4
interface Dialer5
interface Dialer6
interface Dialer7
interface Dialer8
interface Dialer1023
interface Serial0/0:0
ppp ipcp dns admit-any
ppp ipcp dns request
dialer circular enable
dialer-group 28
dialer timer autodial 5
dialer number *99# autodial
ip address ppp-negotiate
nat outbound 3001
ipsec apply policy branch
interface NULL0
ip address 10.173.130.65 255.255.255.240
tcp mss 1280
interface GigabitEthernet0/5
interface WLAN-Radio0/0
service-template 1
interface Eth-channel1/0:0
dialer-group 1
dialer timer idle 0
dialer timer autodial 60
dialer number #777 autodial
ip address cellular-alloc
tcp mss 1280
nat outbound 3001
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
security-zone name Management
scheduler logfile size 16
line class console
user-role network-admin
line class tty
user-role network-operator
line class usb
line class vty
line con 0
line tty 1
modem enable both
line vty 0 63
authentication-mode scheme
ip route-static 0.0.0.0 0 Eth-channel1/0:0
ip route-static 0.0.0.0 0 Serial0/0:0
ip route-static 10.173.129.0 24 Eth-channel1/0:0
acl advanced 3000
rule 0 permit ip source 10.173.130.64 0.0.0.15 destination 10.173.129.0 0.0.0.2
55
acl advanced 3001
rule 0 deny ip source 10.173.130.64 0.0.0.15 destination 10.173.129.0 0.0.0.255
rule 10000 permit ip
password-control enable
undo password-control aging enable
undo password-control history enable
password-control length 6
password-control login-attempt 3 exceed lock-time 10
password-control update-interval 0
password-control login idle-time 0
password-control complexity user-name check
domain system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
service-type telnet http
ipsec transform-set branch
esp encryption-algorithm 3des-cbc
ipsec policy branch 65535 isakmp
security acl 3000
remote-address 61.150.106.90
ike-profile branch
ike profile branch
keychain branch
local-identity fqdn branch
match remote identity fqdn center
proposal 65535
ike proposal 65535
ike keychain branch
pre-shared-key hostname center key cipher $c$3$uLkMumxaOiTLb/gxcgFFV2jaMeCo5rlO
GA==
ip http enable
wlan global-configuration
return
[YuLin_JZT]
(0)
分部指总部地址也添加进去,然后分部触发
ike profile branch
keychain branch
match remote identity address 61.150.106.90
proposal 65535
ike proposal 65535
ike keychain branch
GA==
pre-shared-key address 61.150.106.90 key simple 密码
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
你好,请问这个密码是预共享密钥么?如果配了这条,hostname哪条应该可以删了吧
是的,不用删除,一起配置都可以,不影响
感谢!!!加了一条就可以了,以为前边有了 remote-address 指向就可以了呢。
野蛮模式,使用FQDN分部有时候会找不到总部,加个指向地址就问题不大了
