ipsec旁路无法建立sa
2021-08-03提问
  • 1收藏,1159浏览
脚本没传上来,重发一遍。
拓扑是这样,ipsec网关旁挂核心交换机,核心到对端感兴趣流的回程路由已经写好了,总部有固定ip,分支是4G,没有固定ip,采用野蛮模式,分支是在边界发起链接,总部的出口是一台天融信的墙,已经把ipsec网关的500和4500两个udp端口映射到公网ip,且让天融信厂家看过,确保NAT映射正确无误。从下午调到现在,两侧连ike sa都无法建议,不知道问题出在哪里,下边是两侧脚本,还请各位老师帮忙看看,急~!
总部:
[IPsec]dis cur
 version 5.20, Release 2514P04
 sysname IPsec
 ike local-name zongbu
 domain default enable system
 dns proxy enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
acl number 3000
acl number 3001
 rule 0 permit ip source 10.173.129.0 0.0.0.255 destination 10.173.130.64 0.0.0.
15
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
ike proposal 2
ike peer center
 exchange-mode aggressive
 proposal 2
 pre-shared-key cipher $c$3$4KOaQTAjcf0BqGeXiK8JFms/DFOYkYh9kA==
 id-type name
 remote-name branch
 remote-address branch dynamic
 local-address 61.150.106.90
 local-name center
 nat traversal
ipsec transform-set center
 encapsulation-mode tunnel
 transform esp
 esp authentication-algorithm md5
 esp encryption-algorithm 3des
ipsec policy 1048580 1 isakmp
 connection-name center
 security acl 3001
 ike-peer center
 sa duration traffic-based 1843200
 sa duration time-based 3600
ipsec profile 1
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$g6a6AIDd3LJRPAyTYIKyV7DY6nO9imem
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface NULL0
interface Vlan-interface1
interface GigabitEthernet0/0
 port link-mode route
 tcp mss 1024
interface GigabitEthernet0/4
 ip address 10.173.129.53 255.255.255.0
 ipsec no-nat-process enable
interface GigabitEthernet0/1
 port link-mode bridge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
 ip route-static 0.0.0.0 0.0.0.0 10.173.129.3
 dhcp enable
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface tty 13
user-interface vty 0 4
 user privilege level 3
 set authentication password cipher $c$3$A4CPpDaEQjlEiKs0j5cWcE5cKKmxa57/
 protocol inbound telnet
return
[IPsec]
分支:
 version 7.1.064, Release 0615P10
 sysname YuLin_JZT
 dialer-group 1 rule ip permit
 dialer-group 28 rule ip permit
 dialer-group 89 rule ip permit
 ip load-sharing mode per-flow src-ip global
 dhcp enable
 dhcp server always-broadcast
 dns proxy enable
vlan 1
dhcp server ip-pool lan1
 gateway-list 10.173.130.65
 network 10.173.130.64 mask 255.255.255.240
 address range 10.173.130.68 10.173.130.78
 dns-list 10.173.130.65
apn-profile profile69
 apn static cmnet
wlan service-template 1
 ssid YuLin_JZT
 akm mode psk
 preshared-key pass-phrase cipher $c$3$y3nrrQ0Yo3T9p7t3Mlo+TvG68rThWbx6fCB9
 cipher-suite ccmp
 security-ie rsn
 service-template enable
controller Cellular0/0
 description Single_Line1-CMCC
 serial-set 0
controller Cellular1/0
 eth-channel 0
interface Dialer0
interface Dialer1
interface Dialer2
interface Dialer3
interface Dialer4
interface Dialer5
interface Dialer6
interface Dialer7
interface Dialer8
interface Dialer1023
interface Serial0/0:0
 ppp ipcp dns admit-any
 ppp ipcp dns request
 dialer circular enable
 dialer-group 28
 dialer timer autodial 5
 dialer number *99# autodial
 ip address ppp-negotiate
 nat outbound 3001
 ipsec apply policy branch
interface NULL0
 ip address 10.173.130.65 255.255.255.240
 tcp mss 1280
interface GigabitEthernet0/5
interface WLAN-Radio0/0
 service-template 1
interface Eth-channel1/0:0
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 60
 dialer number #777 autodial
 ip address cellular-alloc
 tcp mss 1280
 nat outbound 3001
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
security-zone name Management
 scheduler logfile size 16
line class console
 user-role network-admin
line class tty
 user-role network-operator
line class usb
line class vty
line con 0
line tty 1
 modem enable both
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 Eth-channel1/0:0
 ip route-static 0.0.0.0 0 Serial0/0:0
 ip route-static 10.173.129.0 24 Eth-channel1/0:0
acl advanced 3000
 rule 0 permit ip source 10.173.130.64 0.0.0.15 destination 10.173.129.0 0.0.0.2
55
acl advanced 3001
 rule 0 deny ip source 10.173.130.64 0.0.0.15 destination 10.173.129.0 0.0.0.255
 rule 10000 permit ip
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control update-interval 0
 password-control login idle-time 0
 password-control complexity user-name check
domain system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 service-type telnet http
ipsec transform-set branch
 esp encryption-algorithm 3des-cbc
ipsec policy branch 65535 isakmp
 security acl 3000
 remote-address 61.150.106.90
 ike-profile branch
ike profile branch
 keychain branch
 local-identity fqdn branch
 match remote identity fqdn center
 proposal 65535
ike proposal 65535
ike keychain branch
 pre-shared-key hostname center key cipher $c$3$uLkMumxaOiTLb/gxcgFFV2jaMeCo5rlO
GA==
 ip http enable
wlan global-configuration
return
[YuLin_JZT]
小茶 五段
粉丝:5人 关注:0人
分部指总部地址也添加进去,然后分部触发
ike profile branch
 keychain branch
match remote identity  address  61.150.106.90
 proposal 65535
ike proposal 65535
ike keychain branch
GA==
pre-shared-key  address 61.150.106.90  key simple  密码
你好,请问这个密码是预共享密钥么?如果配了这条,hostname哪条应该可以删了吧
橘子熟了 发表时间:2021-08-03
是的,不用删除,一起配置都可以,不影响
小茶 发表时间:2021-08-03
回复小茶:
感谢!!!加了一条就可以了,以为前边有了 remote-address 指向就可以了呢。
野蛮模式,使用FQDN分部有时候会找不到总部,加个指向地址就问题不大了
小茶 发表时间:2021-08-03
