第二个wan口没有流量通过
(0)
第二个端口无流量通过,以下是排查要点,请参考:
1、检查拨号是否链接正常。
2、检查物理链路是否有问题。
3、检查是否已配置了默认路由的指向。
4、其次可配置策略路由实现特定网段走特定出口。
(0)
interface GigabitEthernet0/0
port link-mode route
description TO_WAN
pppoe-client dial-bundle-number 1
tcp mss 1024
interface GigabitEthernet0/1
description TO_WAN
pppoe-client dial-bundle-number 2
tcp mss 1024
interface GigabitEthernet0/2
port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
ip route-static 0.0.0.0 0.0.0.0 Dialer1
ip route-static 0.0.0.0 0.0.0.0 Dialer2 preference 70
ip route-static 10.0.0.0 255.255.255.0 Dialer1
ip route-static 172.16.0.0 255.255.252.0 Dialer1
ip route-static 192.168.0.0 255.255.255.0 Dialer1
ip route-static 193.168.0.0 255.255.0.0 Dialer1
配置了静态路由,是否命令不正确。
是否需要配置策略路由,或者配置负载均衡
大神可以给个配置吗
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
# interface GigabitEthernet0/0 port link-mode route description TO_WAN pppoe-client dial-bundle-number 1 tcp mss 1024 # interface GigabitEthernet0/1 port link-mode route description TO_WAN pppoe-client dial-bundle-number 2 tcp mss 1024 # interface GigabitEthernet0/2 port link-mode bridge # interface GigabitEthernet0/3 port link-mode bridge # interface GigabitEthernet0/4 port link-mode bridge # interface GigabitEthernet0/5 port link-mode bridge # interface GigabitEthernet0/6 port link-mode bridge # interface GigabitEthernet0/7 port link-mode bridge # interface GigabitEthernet0/8 port link-mode bridge # interface GigabitEthernet0/9 port link-mode bridge # ip route-static 0.0.0.0 0.0.0.0 Dialer1 ip route-static 0.0.0.0 0.0.0.0 Dialer2 preference 70 ip route-static 10.0.0.0 255.255.255.0 Dialer1 ip route-static 172.16.0.0 255.255.252.0 Dialer1 ip route-static 192.168.0.0 255.255.255.0 Dialer1 ip route-static 193.168.0.0 255.255.0.0 Dialer1 只配了静态路由,是否需要配置策略路由,或者配置负载均衡
需要配置策略路由
