GRE OVER IPSEC野蛮模式
2018-06-21提问
  • 4关注
  • 2收藏,5178浏览
在gre over ipsec中,ipsec用野蛮模式,华三V7的gre配置
int tunnel 0 mode gre
sourec
destination
地址怎么写,如果是固定公网ip是写公网,不是固定的怎么写呢
还有ipsec的 acl 怎么抓数据流?
需要固定地址
GRE Over IPSec野蛮模式
蓝色:GRE关键配置
红色:IPSec关键配置
[RTA]display current-configuration
 version 7.1.059, Alpha 7159
 sysname RTA
 interface LoopBack0
 ip address 172.16.1.1 255.255.255.255
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
interface GigabitEthernet0/1
 combo enable copper
 ip address dhcp-alloc
 ipsec apply policy my
interface Tunnel0 mode gre
 source 172.16.1.1
 destination 172.16.1.2
ip route-static 192.168.2.0 24 Tunnel0
acl advanced 3000
 rule 0 permit ip source 172.16.1.1 0 destination 172.16.1.2 0
ipsec transform-set 1
 esp encryption-algorithm des-cbc
 esp authentication-algorithm md5
ipsec policy my 10 isakmp
 transform-set 1
 security acl 3000
 remote-address 2.2.2.1
 ike-profile 1
ike identity user-fqdn
ike profile 1
 keychain 1
 exchange-mode aggressive
 local-identity user-fqdn rta
 match remote identity user-fqdn rtb
ike keychain 1
 pre-shared-key address 2.2.2.1 255.255.255.255 key simple h3c
[RTB]display current-configuration
 sysname RTB
interface LoopBack0
 ip address 172.16.1.2 255.255.255.255
 combo enable copper
 ip address 192.168.2.1 255.255.255.0
 combo enable copper
 ip address 2.2.2.1 255.255.255.0
 source 172.16.1.2
 destination 172.16.1.1
 ip route-static 0.0.0.0 0 2.2.2.2
 ip route-static 192.168.1.0 24 Tunnel0
ipsec policy-template rta 1
 transform-set 1
 ike-profile 1
ipsec policy my 10 isakmp template rta
ike profile 1
 keychain 1
 local-identity user-fqdn rtb
 match remote identity user-fqdn rta
ike keychain 1
 pre-shared-key hostname rta key simple h3c
如果dhcp地址刷新了,那不是还要重新配置?
彡伞人 发表时间:2018-06-21
噢噢,source跟destination写的不是公网地址呀
彡伞人 发表时间:2018-06-21
