CAS E0306H21 是否兼容windows 2008 R2 企业版
2018-06-21提问
  • 1收藏,1385浏览
使用中有没有什么异常的情况发生?
粉丝:28人 关注:0人
兼容,没有问题,有具体问题的话贴图出来
莫名其妙就频繁重启了,打了SP1也不起作用,仍然频繁重启,大神帮忙分析下dump。
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\y16249.H3C\Desktop\临时文件夹\20180620\fljflfg-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*DownstreamStore****.***/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: Server, suite: Enterprise TerminalServer SingleUserTS
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`01457000 PsLoadedModuleList = 0xfffff800`0169ce90
Debug session time: Wed Jun 20 17:02:01.937 2018 (UTC + 8:00)
System Uptime: 0 days 10:22:11.015
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 1E, {ffffffffc0000005, fffffae0039de010, 1, 3e5b2b92}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4987d )
Followup: MachineOwner
3: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffffae0039de010, The address that the exception occurred at
Arg3: 0000000000000001, Parameter 0 of the exception
Arg4: 000000003e5b2b92, Parameter 1 of the exception
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - 0x%08lx
FAULTING_IP:
+6465323236383137
fffffae0`039de010 ??              ???
EXCEPTION_PARAMETER1:  0000000000000001
EXCEPTION_PARAMETER2:  000000003e5b2b92
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800017080e8
000000003e5b2b92
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%08lx
BUGCHECK_STR:  0x1E_c0000005
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  DRIVER_FAULT_SERVER_MINIDUMP
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  fffff88004b58800 -- (.trap 0xfffff88004b58800)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffae0039c2000 rbx=0000000000000000 rcx=0000000000000000
rdx=000000004131c372 rsi=0000000000000000 rdi=0000000000000000
rip=fffffae0039de010 rsp=fffff88004b58998 rbp=fffffae002e55000
r8=fffffae003444450  r9=fffff8a006198010 r10=00000000fffffffc
r11=fffff8a00619811c r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80001523028 to fffff800014d7640
STACK_TEXT:
fffff880`04b57f78 fffff800`01523028 : 00000000`0000001e ffffffff`c0000005 fffffae0`039de010 00000000`00000001 : nt!KeBugCheckEx
fffff880`04b57f80 fffff800`014d6cc2 : fffff880`04b58758 00000000`0050f000 fffff880`04b58800 fffffae0`039c2000 : nt! ?? ::FNODOBFM::`string'+0x4987d
fffff880`04b58620 fffff800`014d583a : 00000000`00000001 00000000`3e5b2b92 fffffae0`039c2000 00000000`0050f000 : nt!KiExceptionDispatch+0xc2
fffff880`04b58800 fffffae0`039de010 : fffffae0`02e5517a 00000000`00000000 fffffae0`0240ec50 fffff880`030edcf0 : nt!KiPageFault+0x23a
fffff880`04b58998 fffffae0`02e5517a : 00000000`00000000 fffffae0`0240ec50 fffff880`030edcf0 fffffae0`0240ec50 : 0xfffffae0`039de010
fffff880`04b589a0 00000000`00000000 : fffffae0`0240ec50 fffff880`030edcf0 fffffae0`0240ec50 fffff8a0`00000002 : 0xfffffae0`02e5517a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`01523028 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+4987d
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7951a
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!_??_::FNODOBFM::_string_+4987d
3: kd> !process
GetPointerFromAddress: unable to read from fffff80001708000
PROCESS fffffae000ec79e0
    SessionId: none  Cid: 0004    Peb: 00000000  ParentCid: 0000
    DirBase: 00187000  ObjectTable: fffff8a000001940  HandleCount: <Data Not Accessible>
   Image: System
    VadRoot fffffae0012aa850 Vads 5 Clone 0 Private 8. Modified 41181. Locked 0.
    DeviceMap fffff8a000008b30
    Token                             fffff8a000004040
    ReadMemory error: Cannot get nt!KeMaximumIncrement value.
fffff78000000000: Unable to get shared data
    ElapsedTime                       00:00:00.000
    UserTime                          00:00:00.000
    KernelTime                        00:00:00.000
    QuotaPoolUsage[PagedPool]         0
    QuotaPoolUsage[NonPagedPool]      0
    Working Set Sizes (now,min,max)  (91, 0, 0) (364KB, 0KB, 0KB)
    PeakWorkingSetSize                1423
    VirtualSize                       3 Mb
    PeakVirtualSize                   8 Mb
    PageFaultCount                    12028
    MemoryPriority                    BACKGROUND
    BasePriority                      8
    CommitCharge                      28
        *** Error in reading nt!_ETHREAD @ fffffae000ec7460
