import-route命令用来从其它路由协议或其它IS-IS进程引入路由信息。
undo import-route命令用来取消从其它路由协议或其它IS-IS进程引入路由信息。
IS-IS IPv4单播地址族视图/IS-IS IPv4单播拓扑视图:
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static } [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
undo import-route { bgp | direct | eigrp [ eigrp-as | all-as ] | { isis | ospf | rip } [ process-id | all-processes ] | static }
IS-IS IPv6单播地址族视图:
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isisv6 | ospfv3 | ripng } [ process-id ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
undo import-route { bgp4+ | direct | { isisv6 | ospfv3 | ripng } [ process-id | all-processes ] | static }
IS-IS不引入其它协议的路由信息。
IS-IS IPv4单播地址族视图
IS-IS IPv4单播拓扑视图
IS-IS IPv6单播地址族视图
(0)
在ISIS下使用Import-route命令重分布即可。
以下是配置案例,请参考:
组网说明:
本案例采用H3C HCL模拟器的S5820来模拟IPV6 静态路由与ISIS路由重分布的典型组网配置。SW1与SW2运行静态路由协议,SW2与SW3运行ISIS路由协议,为了实现物理机能够PING通SW3,因此需要在SW2配置静态路由与ISIS路由重分布。
1、按照网络拓扑图正确配置IP地址
2、SW1与SW2运行静态路由协议
3、SW2与SW3运行ISIS路由协议
4、SW2配置静态与ISIS路由重分布
SW1:
<H3C>sys
[H3C]sysname SW1
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-mode route
[SW1-GigabitEthernet1/0/2]ipv6 address 1::1 64
[SW1-GigabitEthernet1/0/2]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-mode route
[SW1-GigabitEthernet1/0/1]description <connect to SW2>
[SW1-GigabitEthernet1/0/1]ipv6 address 2::1 64
[SW1-GigabitEthernet1/0/1]quit
[SW1]int loopback 0
[SW1-LoopBack0]ip address 1.1.1.1 32
[SW1-LoopBack0]quit
[SW1]int loopback 1
[SW1-LoopBack1]ipv6 address 4::1 64
[SW1-LoopBack1]quit
SW1 静态路由关键配置点:
[SW1]ipv6 route-static 3:: 64 2::2
[SW1]ipv6 route-static 6:: 64 2::2
SW2:
<H3C>sys
[H3C]sysname SW2
[SW2]int loopback 0
[SW2-LoopBack0]ip address 2.2.2.2 32
[SW2-LoopBack0]quit
[SW2]int loopback 1
[SW2-LoopBack1]ipv6 address 5::1 64
[SW2-LoopBack1]quit
[SW2]int gi 1/0/1
[SW2-GigabitEthernet1/0/1]port link-mode route
[SW2-GigabitEthernet1/0/1]des <connect to SW1>
[SW2-GigabitEthernet1/0/1]ipv6 address 2::2 64
[SW2-GigabitEthernet1/0/1]quit
[SW2]int gi 1/0/2
[SW2-GigabitEthernet1/0/2]port link-mode route
[SW2-GigabitEthernet1/0/2]des <connect to SW3>
[SW2-GigabitEthernet1/0/2]ipv6 address 3::2 64
[SW2-GigabitEthernet1/0/2]quit
SW2 静态与ISIS重分布关键配置点:
[SW2]isis 1
[SW2-isis-1]is-level level-1
[SW2-isis-1]network-entity 10.0000.0000.0001.00
[SW2-isis-1]address-family ipv6 unicast
[SW2-isis-1-ipv6]import-route direct
[SW2-isis-1-ipv6]import-route static level-1
[SW2-isis-1-ipv6]quit
[SW2-isis-1]quit
[SW2]ipv6 route-static 1:: 64 2::1
SW3:
<H3C>sys
[H3C]sysname SW3
[SW3]int loopback 0
[SW3-LoopBack0]ip address 3.3.3.3 32
[SW3-LoopBack0]quit
[SW3]int loopback 1
[SW3-LoopBack1]ipv6 address 6::1 64
[SW3-LoopBack1]quit
[SW3]int gi 1/0/2
[SW3-GigabitEthernet1/0/2]port link-mode route
[SW3-GigabitEthernet1/0/2]des <connect to SW2>
[SW3-GigabitEthernet1/0/2]ipv6 address 3::1 64
[SW3-GigabitEthernet1/0/2]quit
SW3 ISIS关键配置点:
[SW3]isis 1
[SW3-isis-1]is-level level-1
[SW3-isis-1]network-entity 10.0000.0000.0002.00
[SW3-isis-1]address-family ipv6 unicast
[SW3-isis-1-ipv6]import-route direct
[SW3-isis-1-ipv6]quit
[SW3-isis-1]quit
[SW3]int LoopBack 1
[SW3-LoopBack1]isis ipv6 enable 1
[SW3-LoopBack1]quit
[SW3]int gi 1/0/2
[SW3-GigabitEthernet1/0/2]isis ipv6 enable 1
测试:
物理机填写IPV6地址:
物理机能PING通SW3的loopback 1:
分别查看SW2、SW3的ISIS邻居信息:
分别查看SW1、SW2、SW3的IPV6路由表:
[SW1]dis ipv6 routing-table
Destinations : 11 Routes : 11
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 1::/64 Protocol : Direct
NextHop : :: Preference: 0
Interface : GE1/0/2 Cost : 0
Destination: 1::1/128 Protocol : Direct
Destination: 2::/64 Protocol : Direct
Interface : GE1/0/1 Cost : 0
Destination: 2::1/128 Protocol : Direct
Destination: 3::/64 Protocol : Static
NextHop : 2::2 Preference: 60
Destination: 4::/64 Protocol : Direct
Interface : Loop1 Cost : 0
Destination: 4::1/128 Protocol : Direct
Destination: 6::/64 Protocol : Static
Destination: FE80::/10 Protocol : Direct
Destination: FF00::/8 Protocol : Direct
Interface : NULL0 Cost : 0
[SW1]
[SW2]dis ipv6 routing-table
Destination: 1::/64 Protocol : Static
NextHop : 2::1 Preference: 60
Destination: 2::2/128 Protocol : Direct
Destination: 3::/64 Protocol : Direct
Destination: 3::2/128 Protocol : Direct
Destination: 5::/64 Protocol : Direct
Destination: 5::1/128 Protocol : Direct
Destination: 6::/64 Protocol : IS_L1
NextHop : FE80::50BB:B1FF:FED0:307 Preference: 15
Interface : GE1/0/2 Cost : 10
[SW2]
<SW3>dis ipv6 routing-table
Destinations : 8 Routes : 8
Destination: 1::/64 Protocol : IS_L1
NextHop : FE80::50BB:ADFF:FE4E:207 Preference: 15
Destination: 3::1/128 Protocol : Direct
Destination: 6::/64 Protocol : Direct
Destination: 6::1/128 Protocol : Direct
<SW3>
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
我试了,敲不进去
