WAP721C 瘦切换胖模式不成功,请求远程处理,非常感谢!
wap712c如何由廋模式切换为胖模式,为什么不成功呢,哪位大侠谁能帮忙远程一下(qq3303375104),谢谢!
(0)
* H3C WAP712C BootWare, Version 7.14 *
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd.
Compiled Date : Oct 15 2018
CPU Type : ATHEROS AR9563
CPU L1 Cache : 32KB
CPU Clock Speed : 775MHz
Memory Type : SDRAM
Memory Size : 128MB
Memory Speed : 560MHz
BootWare Size : 512KB
Flash Size : 16MB
PCB Version : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Download Files(*.*) |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5): 2
Loading.....................................................................
..Done.
11293696 bytes downloaded!
Saving file flash:/wa4300s_fat.bin
The file is exist,will you overwrite it? [Y/N]Y.............................
.............................Done.
Set the file attribute failed!
Enter your choice(0-5): 4
..Done.
...............................Done.
Enter your choice(0-5): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 2
===========================<Enter Serial SubMenu>===========================
|<5> Modify Serial Interface Parameter |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Format success.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :wa4300s_fat.bin
Target File Name :wa4300s_fat.bin
Server IP Address :192.168.1.1
Local IP Address :192.168.1.253
Subnet Mask :0.0.0.0
Gateway IP Address :0.0.0.0
..Done.
Saving file flash:/wa4300s_fat.bin .........................................
............................................................Done.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 4
===============================<File CONTROL>===============================
|<1> Display All File(s) |
|<2> Set Image File type |
|<3> Set Bin File type |
|<4> Set Configuration File type |
|<5> Delete File |
Enter your choice(0-5): 1
Display all file(s) in flash:
'M' = MAIN 'B' = BACKUP 'N/A' = NOT ASSIGNED
|NO. Size(B) Time Type Name |
|1 11293696 Aug/08/2008 20:00:00 N/A flash:/wa4300s_fat.bin |
|<5> Delete File |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 0
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.................................
Done!
CPU L1 Cache : 32KB
Memory Type : SDRAM
Memory Size : 128MB
Flash Size : 16MB
PCB Version : Ver.A
Loading the main boot and system image files...
The system image does not exist!
Loading the backup boot and system image files...
The image does not exist!
Booting image fails!
Trying to get the IP address from the DHCP server......
Getting IP Address Failed, the system will reboot.
[State : Idle] Reset request, rebooting the
Done!
CPU L1 Cache : 32KB
Memory Type : SDRAM
Memory Size : 128MB
Flash Size : 16MB
PCB Version : Ver.A
哪位技术大侠帮忙看看为什么不成功,帮忙教教我,谢谢!QQ3303375104
(0)
wap721c? 是712c吧?用下面这个链接里的版本:https://www.h3c.com/cn/d_201805/1083983_30005_40.htm
瘦切胖案例参考:https://zhiliao.h3c.com/Theme/details/45609
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
