苹果电脑mac系统安装inode,打开后提示 “libCoreUtils.dylib”将对您的电脑造成伤害。此文件下载于未知日期。
indode client app 意外退出。
------------------------------------- Translated Report (Full Report Below) ------------------------------------- Process: iNodeClient [515] Path: /Applications/iNodeClient/iNodeClient.app/Contents/MacOS/iNodeClient Identifier: H3C.iNodeClient Version: 1.0 (1) Code Type: X86-64 (Native) Parent Process: launchd [1] User ID: 501 Date/Time: 2021-08-25 08:04:39.3438 +0800 OS Version: macOS 12.0 (21A5304g) Report Version: 12 Bridge OS Version: 6.0 (19P50321e) Anonymous UUID: FAE680E0-C9EC-A5DC-E0C2-54E389000CA1 Time Awake Since Boot: 160 seconds System Integrity Protection: enabled Crashed Thread: 0 Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: Namespace DYLD, Code 1 Library missing Library not loaded: @loader_path/libCoreUtils.dylib Referenced from: /Applications/iNodeClient/iNodeClient.app/Contents/MacOS/iNodeClient Reason: tried: '/Applications/iNodeClient/iNodeClient.app/Contents/MacOS/libCoreUtils.dylib' (no such file), '/usr/local/lib/libCoreUtils.dylib' (code signature in <99930907-479B-7B63-E0CC-21807DFF32AE> '/usr/local/lib/libCoreUtils.dylib' not valid for use in process: library load disallowed by system policy), '/usr/lib/libCoreUtils.dylib' (no such file) (terminated at launch; ignore backtrace) Application Specific Information: Library not loaded: @loader_path/libCoreUtils.dylib Referenced from: /Applications/iNodeClient/iNodeClient.app/Contents/MacOS/iNodeClient Reason: tried: '/Applications/iNodeClient/iNodeClient.app/Contents/MacOS/libCoreUtils.dylib' (no such file), '/usr/local/lib/libCoreUtils.dylib' (code signature in <99930907-479B-7B63-E0CC-21807DFF32AE> '/usr/local/lib/libCoreUtils.dylib' not valid for use in process: library load disallowed by system policy), '/usr/lib/libCoreUtils.dylib' (no such file) Thread 0 Crashed: 0 dyld 0x116423c6e __abort_with_payload + 10 1 dyld 0x116439d7f abort_with_payload_wrapper_internal + 80 2 dyld 0x116439db1 abort_with_payload + 9 3 dyld 0x1163e8543 dyld4::halt(char const*) + 375 4 dyld 0x1163e451c dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 3931 5 dyld 0x1163e34b4 start + 388 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000002000209 rbx: 0x0000000000000000 rcx: 0x00007ff7b83f2558 rdx: 0x00007ff7b83f29c0 rdi: 0x0000000000000006 rsi: 0x0000000000000001 rbp: 0x00007ff7b83f25a0 rsp: 0x00007ff7b83f2558 r8: 0x00007ff7b83f25c0 r9: 0x0000000000000000 r10: 0x0000000000000079 r11: 0x0000000000000246 r12: 0x0000000000000079 r13: 0x00007ff7b83f29c0 r14: 0x0000000000000001 r15: 0x0000000000000006 rip: 0x0000000116423c6e rfl: 0x0000000000000246 cr2: 0x00000001163ead6c Logical CPU: 0 Error Code: 0x02000209 Trap Number: 133 Binary Images: 0x1163de000 - 0x116445fff dyld (*) <e604d5fb-9cec-336f-945b-cbda1a199e67> /usr/lib/dyld External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 0 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=12.6M resident=0K(0%) swapped_out_or_unallocated=12.6M(100%) Writable regions: Total=9384K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9384K(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= STACK GUARD 56.0M 1 Stack 8192K 1 VM_ALLOCATE 12K 3 __DATA 1180K 17 __DATA_CONST 48K 1 __LINKEDIT 3804K 12 __TEXT 9160K 11 dyld private memory 1024K 1 shared memory 8K 1 =========== ======= ======= TOTAL 78.9M 48 ----------- Full Report ----------- {"app_name":"iNodeClient","timestamp":"2021-08-25 08:04:39.00 +0800","app_version":"1.0","slice_uuid":"e2a33ab5-9975-3c85-aa0b-ec5625a298f9","build_version":"1","platform":1,"bundleID":"H3C.iNodeClient","share_with_app_devs":1,"is_first_party":0,"etl_key":"3","bug_type":"309","os_version":"macOS 12.0 (21A5304g)","incident_id":"76E5AA34-A551-4A5D-AA4D-C3341E4D4DEF","name":"iNodeClient"} { "uptime" : 160, "procLaunch" : "2021-08-25 08:02:08.0735 +0800", "procRole" : "Background", "version" : 2, "userID" : 501, "deployVersion" : 209, "modelCode" : "MacBookPro15,1", "procStartAbsTime" : 18250058008, "coalitionID" : 601, "osVersion" : { "train" : "macOS 12.0", "build" : "21A5304g", "releaseType" : "User" }, "captureTime" : "2021-08-25 08:04:39.3438 +0800", "incident" : "76E5AA34-A551-4A5D-AA4D-C3341E4D4DEF", "bug_type" : "309", "pid" : 515, "procExitAbsTime" : 169527395557, "cpuType" : "X86-64", "procName" : "iNodeClient", "procPath" : "\/Applications\/iNodeClient\/iNodeClient.app\/Contents\/MacOS\/iNodeClient", "bundleInfo" : {"CFBundleShortVersionString":"1.0","CFBundleVersion":"1","CFBundleIdentifier":"H3C.iNodeClient"}, "storeInfo" : {"deviceIdentifierForVendor":"6E1F6445-7C57-5A63-9310-44D0A6AE8358","thirdParty":true}, "parentProc" : "launchd", "parentPid" : 1, "coalitionName" : "H3C.iNodeClient", "crashReporterKey" : "FAE680E0-C9EC-A5DC-E0C2-54E389000CA1", "bridgeVersion" : {"build":"19P50321e","train":"6.0"}, "sip" : "enabled", "isCorpse" : 1, "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"}, "termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: @loader_path\/libCoreUtils.dylib","Referenced from: \/Applications\/iNodeClient\/iNodeClient.app\/Contents\/MacOS\/iNodeClient","Reason: tried: '\/Applications\/iNodeClient\/iNodeClient.app\/Contents\/MacOS\/libCoreUtils.dylib' (no such file), '\/usr\/local\/lib\/libCoreUtils.dylib' (code signature in <99930907-479B-7B63-E0CC-21807DFF32AE> '\/usr\/local\/lib\/libCoreUtils.dylib' not valid for use in process: library load disallowed by system policy), '\/usr\/lib\/libCoreUtils.dylib' (no such file)"]}, "asi" : {"dyld":["Library not loaded: @loader_path\/libCoreUtils.dylib","Referenced from: \/Applications\/iNodeClient\/iNodeClient.app\/Contents\/MacOS\/iNodeClient","Reason: tried: '\/Applications\/iNodeClient\/iNodeClient.app\/Contents\/MacOS\/libCoreUtils.dylib' (no such file), '\/usr\/local\/lib\/libCoreUtils.dylib' (code signature in <99930907-479B-7B63-E0CC-21807DFF32AE> '\/usr\/local\/lib\/libCoreUtils.dylib' not valid for use in process: library load disallowed by system policy), '\/usr\/lib\/libCoreUtils.dylib' (no such file)"]}, "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0}, "faultingThread" : 0, "threads" : [{"triggered":true,"id":4574,"threadState":{"r13":{"value":140701924796864},"rax":{"value":33554953},"rflags":{"value":582},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":1},"r8":{"value":140701924795840},"cr2":{"value":4668173676},"rdx":{"value":140701924796864},"r10":{"value":121},"r9":{"value":0},"r15":{"value":6},"rbx":{"value":0},"trap":{"value":133},"err":{"value":33554953},"r11":{"value":582},"rip":{"value":4668406894,"matchesCrashFrame":1},"rbp":{"value":140701924795808},"rsp":{"value":140701924795736},"r12":{"value":121},"rcx":{"value":140701924795736},"flavor":"x86_THREAD_STATE","rdi":{"value":6}},"frames":[{"imageOffset":285806,"symbol":"__abort_with_payload","symbolLocation":10,"imageIndex":0},{"imageOffset":376191,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":80,"imageIndex":0},{"imageOffset":376241,"symbol":"abort_with_payload","symbolLocation":9,"imageIndex":0},{"imageOffset":42307,"symbol":"dyld4::halt(char const*)","symbolLocation":375,"imageIndex":0},{"imageOffset":25884,"symbol":"dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)","symbolLocation":3931,"imageIndex":0},{"imageOffset":21684,"symbol":"start","symbolLocation":388,"imageIndex":0}]}], "usedImages" : [ { "source" : "P", "arch" : "x86_64", "base" : 4668121088, "size" : 425984, "uuid" : "e604d5fb-9cec-336f-945b-cbda1a199e67", "path" : "\/usr\/lib\/dyld", "name" : "dyld" } ], "sharedCache" : { "base" : 140703614824448, "size" : 15207858176, "uuid" : "324539cd-c9dd-3993-adad-7bc5013aaea4" }, "vmSummary" : "ReadOnly portion of Libraries: Total=12.6M resident=0K(0%) swapped_out_or_unallocated=12.6M(100%)\nWritable regions: Total=9384K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9384K(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8192K 1 \nVM_ALLOCATE 12K 3 \n__DATA 1180K 17 \n__DATA_CONST 48K 1 \n__LINKEDIT 3804K 12 \n__TEXT 9160K 11 \ndyld private memory 1024K 1 \nshared memory 8K 1 \n=========== ======= ======= \nTOTAL 78.9M 48 \n", "legacyInfo" : { "threadTriggered" : { } }, "trialInfo" : { "rollouts" : [ { "rolloutId" : "607844aa04477260f58a8077", "factorPackIds" : { "SIRI_MORPHUN_ASSETS" : "60ef663fa2f864203caf575c" }, "deploymentId" : 250000055 }, { "rolloutId" : "60356660bbe37970735c5624", "factorPackIds" : { }, "deploymentId" : 250000016 }, { "rolloutId" : "5fc94383418129005b4e9ae0", "factorPackIds" : { }, "deploymentId" : 250000110 }, { "rolloutId" : "602ad4dac86151000cf27e46", "factorPackIds" : { "SIRI_DICTATION_ASSETS" : "610c869137f5d11121dcd114" }, "deploymentId" : 250000156 }, { "rolloutId" : "60da5e84ab0ca017dace9abf", "factorPackIds" : { }, "deploymentId" : 250000007 }, { "rolloutId" : "601d9415f79519000ccd4b69", "factorPackIds" : { "SIRI_TEXT_TO_SPEECH" : "611ad37537f5d11121dcd81b" }, "deploymentId" : 250000160 } ], "experiments" : [ ] } } Model: MacBookPro15,1, BootROM 1715.30.2.0.0 (iBridge: 19.16.10321.5.5,0), 6 processors, 6-Core Intel Core i7, 2.6 GHz, 16 GB, SMC Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In Display: Color LCD, 2880 x 1800 Retina, Main, MirrorOff, Online Graphics: Radeon Pro 560X, Radeon Pro 560X, PCIe, 4 GB Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, DDR4, 2400 MHz, Micron, 8ATF1G64HZ-2G6E1 Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, DDR4, 2400 MHz, Micron, 8ATF1G64HZ-2G6E1 AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports Network Service: Wi-Fi, AirPort, en0 USB Device: USB31Bus USB Device: iPhone USB Device: T2Bus USB Device: Touch Bar Backlight USB Device: Touch Bar Display USB Device: Apple Internal Keyboard / Trackpad USB Device: Headset USB Device: Ambient Light Sensor USB Device: FaceTime HD Camera (Built-in) USB Device: Apple T2 Controller Thunderbolt Bus: MacBook Pro, Apple Inc., 47.5 Thunderbolt Bus: MacBook Pro, Apple Inc., 47.5
(0)
您好:
可以从官网下载最新版本iNode按照以下方式安装试一下能否正常使用
登录新华三(www.h3c.com)官网,选择“产品支持与服务” > “软件下载”。
选择“管理软件”>“iNode PC(PC客户端)”。
在用户栏中输入用户名yx800,密码01230123。
下载安装包
依次展开inode—MacOS就可以看到管理中心安装包了,双击压缩包进行解压
双击进入iNodeManager文件夹
进入文件夹后点击上方齿轮按钮,选择“将inodeManager拷贝为路径名称”
进入终端应用
输入“open”,然后空格右键粘贴刚才拷贝的路径,继续在后方输入“/iNodeManager.App/Contents/MacOS” 如下图:
双击弹出页面中的“iNodeManager”
在新窗口中根据需要选择vpn类型,高级定制中可以预先配置vpn的网关地址及端口。
添加完成后点击完成,选择生成定制的客户端安装程序,然后点击确定
成功后可以看到如下界面,在文件中按如下顺序展开即可看到iNode安装包
双击上面看到的压缩包,解压后点击iNodeClient
进行系统偏好设置
重启完成后即可看到客户端快捷方式
使用iNode客户端拨号,添加拨号信息,完成拨号。
(0)
ok,问题解决了。就是SIP问题。SIP莫名其妙被打开了
在我们开发过程中,有时候我们安装一些工具软件需要将文件拷贝到系统限制更改的文件夹中,甚至有时需要更改系统限制的文件,而这时Mac会提示系统文件不能修改之类的内容,而这时我们想要继续操作必须关闭Mac电脑的“系统完整性保护”机制(SIP)
在终端中输入csrutil status,就可以看到是enabled还是disabled。
1 重启MAC,按住cmd+R直到屏幕上出现苹果的标志和进度条,进入Recovery模式;
2 在屏幕最上方的工具栏找到实用工具(左数第3个),打开终端,输入:csrutil disable;
3 关掉终端,重启mac;
4 重启以后可以在终端中查看状态确认。
与关闭的步骤类似,只是在S2中输入csrutil enable即可。
(1)
mac上的inode装上去需要把文件再拉出来的,不会可以联系我
(0)
你好,请问您是怎么操作的
同问如何进行操作
到哪一步了
你好我重新去官网下了inode 连接网络失败。。。。
昨天还好好的,今早就这样
(0)
大家好, 解决了
分享下:
重M1的芯片电脑在关机状态下长按开机键,直到出现设置那个⚙后松开,就进入恢复模式,打开终端,输入 csrutil disable 然后回车 ,然后再输入Y 然后回车 在此输入密码执行 SIP就关闭 可以直接重启
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
仍存在同样问题
试了最新版E583,任然同样问题!
已解决,感谢!
你好 我用了你的办法但是还是不行诶 连接网络失败
