MSR2600-10 软件版本丢失,应该怎么做
2018-06-26提问
  • 1收藏,1508浏览
MSR2600-10 软件版本丢失,应该怎么做,有没有大师比较详细的步骤给自导一下呢,
li 四段
粉丝:2人 关注:0人
当出现“Press Ctrl+B to enter extended boot menu...”时,键入<Ctrl+B>,系统提示:
BootWare password: Not required. Please press Enter to continue.
Enter键系统进入BootWare主菜单:
The current mode is password recovery.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System        |
|<2> Enter Serial SubMenu                                                         |
|<3> Enter Ethernet SubMenu                                                       |
|<4> File Control        |
|<5> Restore to Factory Default Configuration                                     |
|<6> Skip Current System Configuration                                            |
|<7> BootWare Operation Menu                                                      |
|<8> Clear Super Password                                                         |
|<9> Storage Device Operation                                                     |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9):
 通过以太网口利用TFTP/FTP升级启动文件
(2)      以太网口参数配置:在BootWare主菜单下键入<3>可以进入以太网口子菜单,然后键入<5>就可以进入以太网口配置菜单:
=========================<ETHERNET PARAMETER SET>=========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :tftp
Load File Name         :main.bin
Target File Name       :main.bin
Server IP Address      :192.168.1.1
Local IP Address       :192.168.1.253
Gateway IP Address     :0.0.0.0
FTP User Name          :user
FTP User Password      :password
以升级主启动文件为例,键入<2>为升级主启动文件:
Loading.....................................................................
.........................Done!
31911744 bytes downloaded!
Updating File flash:/main.bin...............................................
....................................................Done!
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Update Backup Application File                                        |
|<4> Update Secure Application File                                        |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5):
(4)      选择<0>,返回BootWare主菜单。选择<1>,引导系统。
粉丝:7人 关注:3人
在bootware里导入,可以参考官网的升级指导
