AC无法发现AP
2018-06-28提问
  • 1收藏,4187浏览
AC无法发现AP,以下是配置.不知道问题出在哪里 按照H3C 无线控制器三层注册典型配置举例(V7)案例来配置的
AC
1.#
2. version 7.1.064, Release 5221
3.#
4. sysname H3C
5.#
6. clock timezone Beijing add 08:00:00
7.#
8. telnet server enable
9.#
10. password-recovery enable
11.#
12.vlan 1
13.#
14.vlan 100
15.#
16.vlan 200
17.#
18.wlan service-template swt
19. ssid sggswt
20. client max-count 50
21. akm mode psk
22. preshared-key pass-phrase cipher $c$3$+W+Jnl8QgQZjWfCUm47LgRDkDTiaYABFowGD
23. cipher-suite ccmp
24. cipher-suite tkip
25. security-ie rsn
26. security-ie wpa
27. service-template enable
28.#
29.interface NULL0
30.#
31.interface Vlan-interface1
32. ip address 192.168.0.100 255.255.255.0
33. undo dhcp select server
34. dhcp relay server-address 192.168.0.50
35.#
36.interface Vlan-interface100
37. ip address 192.168.10.1 255.255.255.0
38. undo dhcp select server
39.#
40.interface GigabitEthernet1/0/7
41. port link-mode route
42. undo dhcp select server
43.#
44.interface GigabitEthernet1/0/8
45. port link-mode route
46. undo dhcp select server
47.#
48.interface GigabitEthernet1/0/1
49. port link-mode bridge
50. port link-type trunk
51. undo port trunk permit vlan 1
52. port trunk permit vlan 100 200
53.#
54.interface GigabitEthernet1/0/2
55. port link-mode bridge
56. port access vlan 100
57.#
58.interface GigabitEthernet1/0/3
59. port link-mode bridge
60. port link-type hybrid
61. port hybrid vlan 1 untagged
62.#
63.interface GigabitEthernet1/0/4
64. port link-mode bridge
65.#
66.interface GigabitEthernet1/0/5
67. port link-mode bridge
68.#
69.interface GigabitEthernet1/0/6
70. port link-mode bridge
71.#
72. scheduler logfile size 16
73.#
74.line class console
75. user-role network-admin
76.#
77.line class vty
78. user-role network-operator
79.#
80.line con 0
81. user-role network-admin
82.#
83.line vty 0 31
84. authentication-mode scheme
85. user-role network-operator
86.#
87. ip route-static 192.168.40.0 24 192.168.10.83
88.#
89. undo info-center logfile enable
90.#
91.domain system
92.#
93. domain default enable system
94.#
95.role name level-0
96. description Predefined level-0 role
97.#
98.role name level-1
99. description Predefined level-1 role
100.#
101.role name level-2
102. description Predefined level-2 role
103.#
104.role name level-3
105. description Predefined level-3 role
106.#
107.role name level-4
108. description Predefined level-4 role
109.#
110.role name level-5
111. description Predefined level-5 role
112.#
113.role name level-6
114. description Predefined level-6 role
115.#
116.role name level-7
117. description Predefined level-7 role
118.#
119.role name level-8
120. description Predefined level-8 role
121.#
122.role name level-9
123. description Predefined level-9 role
124.#
125.role name level-10
126. description Predefined level-10 role
127.#
128.role name level-11
129. description Predefined level-11 role
130.#
131.role name level-12
132. description Predefined level-12 role
133.#
134.role name level-13
135. description Predefined level-13 role
136.#
137.role name level-14
138. description Predefined level-14 role
139.#
140.user-group system
141.#
142.local-user admin class manage
143. password hash 123123123
144. service-type telnet http https
145. authorization-attribute user-role network-admin
146.#
147.portal local-web-server http
148. default-logon-page defaultfile.zip
149.#
150. ip http enable
151. ip https enable
152.#
153. wlan auto-ap enable
154. wlan auto-persistent enable
155.#
156.wlan global-configuration
157. region-code-lock enable
158.#
159.wlan ap-group default-group
160. tunnel encryption enable
161. backup-ac ip 1.1.1.1
162. vlan 1
163.#
164.return
L3 switch
1.#
2. version 7.1.070, Release 6113
3.#
4. sysname H3C
5.#
7. clock protocol none
8.#
9. irf mac-address persistent timer
10. irf auto-update enable
11. undo irf link-delay
12. irf member 1 priority 1
13.#
14. dot1x
15.#
16. dhcp enable
17.#
18. dns server 192.168.0.1
19.#
20. lldp global enable
21.#
22. password-recovery enable
23.#
24.vlan 1
25.#
26.vlan 100
27.#
28.vlan 200
29.#
30.vlan 300
31.#
32.vlan 400
33.#
34. stp global enable
35.#
36.dhcp server ip-pool 1
37. gateway-list 192.168.40.1
38. network 192.168.40.0 mask 255.255.255.0
39. option 43 hex 8007000001c0a80a01
40.#
41.dhcp server ip-pool 2
42. gateway-list 192.168.20.1
43. network 192.168.20.0 mask 255.255.255.0
44.#
45.dhcp server ip-pool 3
46. gateway-list 192.168.30.1
47. network 192.168.30.0 mask 255.255.255.0
48.#
49.interface NULL0
50.#
51.interface Vlan-interface1
52. ip address 192.168.0.201 255.255.255.0
53. undo dhcp select server
54.#
55.interface Vlan-interface100
56. ip address 192.168.10.83 255.255.255.0
57.#
58.interface Vlan-interface200
59. ip address 192.168.20.1 255.255.255.0
60.#
61.interface Vlan-interface300
62. ip address 192.168.30.1 255.255.255.0
63.#
64.interface Vlan-interface400
65. ip address 192.168.40.1 255.255.255.0
66.#
67.interface GigabitEthernet1/0/1
68. port link-type trunk
69. port trunk permit vlan 1 101 201 301
70.#
71.interface GigabitEthernet1/0/2
72.#
73.interface GigabitEthernet1/0/3
74. port access vlan 300
75.#
76.interface GigabitEthernet1/0/4
77. port link-type trunk
78. undo port trunk permit vlan 1
79. port trunk permit vlan 200 400
80. port trunk pvid vlan 400
81.#
82.interface GigabitEthernet1/0/5
83.#
84.interface GigabitEthernet1/0/6
85. port link-type trunk
86. port trunk permit vlan 1 301
87.#
88.interface GigabitEthernet1/0/7
89.#
90.interface GigabitEthernet1/0/8
91.#
92.interface GigabitEthernet1/0/9
93.#
94.interface GigabitEthernet1/0/10
95.#
96.interface GigabitEthernet1/0/11
97.#
98.interface GigabitEthernet1/0/12
99.#
100.interface GigabitEthernet1/0/13
101.#
102.interface GigabitEthernet1/0/14
103.#
104.interface GigabitEthernet1/0/15
105.#
106.interface GigabitEthernet1/0/16
107.#
108.interface GigabitEthernet1/0/17
109. combo enable copper
110.#
111.interface GigabitEthernet1/0/18
112. combo enable copper
113.#
114.interface GigabitEthernet1/0/19
115. combo enable copper
116.#
117.interface GigabitEthernet1/0/20
118. combo enable copper
119.#
120.interface GigabitEthernet1/0/21
121. combo enable copper
122.#
123.interface GigabitEthernet1/0/22
124. combo enable copper
125.#
126.interface GigabitEthernet1/0/23
127. combo enable copper
128.#
129.interface GigabitEthernet1/0/24
130. port link-type trunk
131. undo port trunk permit vlan 1
132. port trunk permit vlan 100 200
133. combo enable copper
134.#
135.interface M-GigabitEthernet0/0/0
136. undo dhcp select server
137.#
138.interface Ten-GigabitEthernet1/0/25
139.#
140.interface Ten-GigabitEthernet1/0/26
141.#
142.interface Ten-GigabitEthernet1/0/27
143.#
144.interface Ten-GigabitEthernet1/0/28
145.#
146. scheduler logfile size 16
147.#
148.line class aux
149. user-role network-admin
150.#
151.line class vty
152. user-role network-operator
153.#
154.line aux 0
155. user-role network-admin
156.#
157.line vty 0 63
158. user-role network-operator
159.#
160.radius scheme system
161. user-name-format without-domain
162.#
163.domain system
164.#
165. domain default enable system
166.#
167.role name level-0
168. description Predefined level-0 role
169.#
170.role name level-1
171. description Predefined level-1 role
172.#
173.role name level-2
174. description Predefined level-2 role
175.#
176.role name level-3
177. description Predefined level-3 role
178.#
179.role name level-4
180. description Predefined level-4 role
181.#
182.role name level-5
183. description Predefined level-5 role
184.#
185.role name level-6
186. description Predefined level-6 role
187.#
188.role name level-7
189. description Predefined level-7 role
190.#
191.role name level-8
192. description Predefined level-8 role
193.#
194.role name level-9
195. description Predefined level-9 role
196.#
197.role name level-10
198. description Predefined level-10 role
199.#
200.role name level-11
201. description Predefined level-11 role
202.#
203.role name level-12
204. description Predefined level-12 role
205.#
206.role name level-13
207. description Predefined level-13 role
208.#
209.role name level-14
210. description Predefined level-14 role
211.#
212.user-group system
213.#
214.local-user admin class manage
215. password hash 123123123
216. service-type https
217. authorization-attribute user-role network-admin
218. authorization-attribute user-role network-operator
219.#
220.pki entity en
221. common-name http-server1
222. fqdn ssl.security.com
223.#
224. ip http enable
225. ip https enable
226.#
227.return
粉丝:147人 关注:3人
AP是否获取到了DHCP 分配的IP地址? AP能ping 通AC吗?
解决了上面两个测试问题,就看AP获取的dhcp option 43有没有写对AC的IP地址,你说的是三层注册。另外在AC上有没有写对AP的模板,写对序列号?
